Old 05-11-2006, 08:06 AM   #46 (permalink)
SolsticeMan's Avatar
Originally Posted by LBJay
The GM graph is from an engine brake dyno. The engine is run at full throttle and the dyno places a load on the engine to hold it at an RPM and take a torque measurement.
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
Old 05-11-2006, 10:15 AM   #47 (permalink)
Send a message via AIM to Buzz Lightyear Send a message via Yahoo to Buzz Lightyear
I realize it's on an engine dyno. They still have to quit making the dyno run at some point.
Buzz Lightyear is offline   Reply With Quote
Old 05-11-2006, 10:53 AM   #48 (permalink)
LBJay's Avatar
When they stop (close throttle) it doesnt take any more measurements. The dyno ploting ends at whatever RPM they set.
LBJay is offline   Reply With Quote
Old 07-11-2006, 03:19 PM   #49 (permalink)
Does anyone know what the rod length is in the LNF? The stroke x bore lends itself to high RPM power, and if the rod ratio is high enough (1.70 - 1.75), this could be a KILLER engine with a bigger turbo. I have a feeling that the powerband is limited by the turbo. I would be disappointed if GM put short rods in it.
Spooled is offline   Reply With Quote
Old 07-12-2006, 04:34 AM   #50 (permalink)
Assuming the deck heigth stays the same(I bet it does) theyd almost have to put in longer rods.
DugsGMs is offline   Reply With Quote
Old 07-12-2006, 08:35 AM   #51 (permalink)
mena661's Avatar
Spooled,
Start a seperate thread for this. Maybe FrankC5R knows the answer to your question.
Old 11-23-2006, 12:33 PM   #52 (permalink)
I have never seen a torque curve like that - that can't be for real
mbsolsticeguy is offline   Reply With Quote
Old 11-23-2006, 01:41 PM   #53 (permalink)
mena661's Avatar
Magnaflow posted a dyno sheet showing stock and 3" exhaust. Check out the GXP section.
Old 02-03-2007, 07:29 PM   #54 (permalink)
Originally Posted by WasRexPsiFi View Post
I am currently the owner of a heavily modified WRX, suspension, brakes, HP (>400). I don't *plan* on doing that again, but what a ride!
This GXP looks like my next ride. Just hope my WRX last long enough ... 400 + HP takes its toll over 60K miles. I am convinced turbos are THE way to go. Conservative gas mileage with an easy foot, but a blast of HP when you want. The WRX forums taught me what WOT means.
This torque curve is clearly limited by the ECU. Its easy to imagine simple changes to let it open up. This flat curve is definitely controlled by the ECU so someone will soon figure out how to reprogram.
D@mn you forums!!! My life was so simble, so ... ... boring before!!!
my thoughts exactly, only I have an srt4
masssrt is offline   Reply With Quote
