Old 02-06-2008, 08:31 PM
   Power source for illuminated Wind Restrictor . . .
Rixtoy1's Avatar
I see the illuminated WR comes with an 8 battery pack for the LED's (?).
Can it also draw power from the car if you use the brake light module and wiring?
How long does a set of batteries last? I don't believe these LEDs draw much power.
Any user experiences?
Thanks.
"Misery is Optional"
Rixtoy1 is offline
Old 02-06-2008, 09:03 PM
rlhammon's Avatar
Thanks.
Just so you know.. you do not need the brake light module in order to power the LED's. It only allows you to adjust the brightness of the LED's. You can wire the LED's into the brake lights, or license plate light.
I hooked mine up with a relay... and it draws power from the license plate light. This way, when the headlights turn on (the license plate turns on too), my LED's light up. But, with the relay... when I put the car into reverse, it kills the power so I can see clearly to back up.
rlhammon is offline
Old 02-07-2008, 01:57 PM
You can pick up any source of 12 v power as long as its switched. Personally I tapped into the tail light on the passanger side at the plug. It comes on when the tail lights come on. I found this was the minimum energy path and very easy to do.
Old 02-07-2008, 05:29 PM
JustMike's Avatar
I think someone also disconnected the rear window defroster and then used that as a switched power source. You could set it up so that you could also plug and unplug as needed ...
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline
Old 02-07-2008, 06:01 PM
Windrestrictor!'s Avatar
We do not recommend powering your illumination with simply a battery pack. The battery packs are meant for use when at a car show or meet and you dont want to leave your engine on.
If someone does not want to use the 12V wires that are in the harness that Rob was talking about then we recommend using a 12V adapter plug that fits into the 12V source in your dash. We will send these with any order at no additional cost however to my knowledge the preferred way is the running lights or brake light wire......
Please dont hesitate to call us at anytime with questions or comments
HOLIDAY SPECIAL NOW AVAILABLE!
SEE DETAILS HERE>>>http://www.windrestrictor.com/holiday
The perfect accessory to personalize your solstice.
WINDRESTRICTOR TM.
Order online 24/7 or by phone at 972-487-5987
Windrestrictor! is offline
Old 02-07-2008, 06:05 PM
Brentils BLM from Windrestrictor
WINDRESTRICTOR TM.
