Old 03-24-2008, 08:31 PM   #166 (permalink)
Deepbluegxp's Avatar
Do you have a default scan setup we, dashhawk users, can do to send to him?
See my car on cardomain.com
NASSOA Founding Member #48
Old 03-24-2008, 08:58 PM   #167 (permalink)
HotScott's Avatar
Send a message via Yahoo to HotScott
Knock
I got a little knock in 4th gear going hard from about 55-60 mph. But that only happens on occasion. I do still have the WG mod all the way up. So I am going to back it off a few threads just to be sure. Probably a good Idea for everyone to not to run it to the end that is getting this tune.
ARRIVED - DEEP 2007 GXP Solstice - 5 spd stick, Chrome wheels, Upgraded stereo & sound, A/C, Black top. MODs: Painted Calipers, ED IC pipes, DEJON BOV Spring, Waste gate mod. Westers Hot Tune, K&N Drop in, 35% Tinted windows
HotScott is offline   Reply With Quote
Old 03-24-2008, 09:06 PM   #168 (permalink)
I am not sure Lyndon can read a Dashawk scan, someone thats knows more about the Dashawk can answer that. what he wants to see are MAP, MAF, BOOST, and when the timing gets pulled to prevent knock. I am not sure how to set the Dashawk up for that. I bet JustMike or Shabby will know. Wester is trying to do a tune that will work on every car, the more data he can get from cars with different mods the better off we are. It would seem that backing off the wastegate should take care of any problems with knock, or adding octane booster This is where the larger intercooler helps, knock is caused by preignition which is caused by heat, a cooler charge will help reduce heat and preignition. I think I will back off my wastegate to stock just to see what kind of a change I notice. It maybe with the HOT tune the wastegate mod is not necessary.
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
Old 03-25-2008, 06:48 AM   #169 (permalink)
JustMike's Avatar
The logs from the Dashhawk are CSV files at the end of the day so you can just dump them in Excel if you have to. Jim there are some PIDs that are in HP Tunes that are not in the Dashhawk IAT2 for example. I also think that there are also some PIDs that are in the Dashhawk that are not in HP Tunes. It would help if we coculd get a list of must have PIDs from Lyndon along with the nice to have and then I can work up some configs. Keep in mind that the Dashhawk is limited on the number of PIDs that can be recorded. It is pretty low compaired to HP Tuners, 5 or 6 at the most.
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline   Reply With Quote
Old 03-25-2008, 07:42 AM   #170 (permalink)
spiky3480's Avatar
Lil goat,
I have my wastegate backed off about 6 threads so far with no MAP codes. The newest tune that I am testing for the automatic is learning in. I have sent Lyndon 2 scans also, which he has been looking at. He sent me an updated file yesterday and I am letting it learn in before I scan it. I am a bit impatient when it comes to this, but I am holding myself together...lol. I was able to run the car to 120mph on the latest scan, and that thing was there quick, let me tell you. I am reducing the threads on the wastegate mod one by one until I throw a code or knock, and then I will back off one and know that I am at the threshold. I also have the intercooler, SOLO RCD exhaust, and HF cat.
SOLO Performance
goingsolo2@hotmail.com
2007 Mysterious GXP
INTRUDER Modifications
TEAM SOLSTICE 2009
TEAM SAVE THE TA-TA'S
Exhaust Sound Clips
Old 03-25-2008, 09:24 AM   #171 (permalink)
Lyndon can tell you better what he wants to see from the Dashawk, I am just using my HPT, send him an email.
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
HKS Coilovers
Old 03-25-2008, 09:27 AM   #172 (permalink)
spiky3480's Avatar
Lyndon can tell you better what he wants to see form the Dashawk, I am just using my HPT, send him an email
I am using HP Tuners to run the scans.
SOLO Performance
2007 Mysterious GXP
TEAM SOLSTICE 2009
Exhaust Sound Clips
Old 03-25-2008, 09:28 AM   #173 (permalink)
JustMike's Avatar
What config file are you using? The stock one?
#1922 12/03/05
Dover DE
Old 03-25-2008, 10:03 AM   #174 (permalink)
I just use the stock file with the laptop. I have a 12V power cord for my laptop so I can run scans all day.
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
HKS Coilovers
Old 03-25-2008, 10:15 AM   #175 (permalink)
spiky3480's Avatar
I use the VCM Scanner and I did not change anything so I guess I am using the strock configuration. Lyndon uses something on his end to make the results more accurate. I think he had said a cfg file or something.
SOLO Performance
2007 Mysterious GXP
TEAM SOLSTICE 2009
Exhaust Sound Clips
Old 03-25-2008, 01:49 PM   #176 (permalink)
I just got an email from Lyndon and he is recommending that when you do the tune you set the wastegate to stock and then move it a little if you want and see what happens. Like Spikey is doing, with the variance in gasoline and altitudes and temps around the country this is a good way to start. I set mine to stock and will most likely just move it up a little. It is a bit smoother at the stock setting but I lost 1lb of boost. I don't miss it, I can still get completely sideways from a stop with the traction control off. It has plenty of power. If you want to push it just add some octane booster and have at it, like before going to the track.
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
HKS Coilovers
Old 03-25-2008, 02:19 PM   #177 (permalink)
I have a 2008 GXP. Is there a new chip/program available? How much do they cost? Are there instructions on where and how to take out the chip and reinstall?
Thanks
orangegxp is offline   Reply With Quote
Old 03-25-2008, 02:29 PM   #178 (permalink)
Where is the meeting on 12 April. I too, wish to attend and get the Wester's chip and a few other upgrades. And, looking forward to meeting all of the NASSOA members. ( sending in my application today!)
Orangegxp
Old 03-25-2008, 04:05 PM   #179 (permalink)
Topcat's Avatar
Location: Extreme North Western PA Waterford (Erie), PA
I faxed my paperwork and paid for my tune today. I will mail my ECM next week.
Weather permitting I will go on the NEO SOS 3-29-08 run.
I haven't modded my wastegate yet.
I recieved my Dejon Intercooler and piping today. I plan on installing them Thursday.
I have the Solo Hi-flo Cat and Mach 'Shorty'
I don't have a Dashhawk or HPtuner...I plan on getting a dashhawk. Will the dashhawk allow me to clear codes...
With the upcoming changes that I am going to make, installing intercooler and piping and ECM, should I get any codes?
07 Aggressive GXP
Solo Hi-Flo Cat, Street Race Exhaust
Dejon Intercooler, Piping & Coupler Kit
Wester's HOT Tune
Song of the Week: UNDER CONSTRUCTION
Movie Quote of the Week: Under Construction
Topcat is offline   Reply With Quote
Old 03-25-2008, 04:20 PM   #180 (permalink)
Go-N Def's Avatar
Orangegxp
Where are you located at? The Mod-Meet on the 12th is in Southern Maryland.
Pics on MySpace
Go-N Def is offline   Reply With Quote
