SPIKY3480 HAS PUT THE HP TUNERS IN 3 OF THE CLUBS CARS AND EVERYONE THINK ITS GREAT . MY BOOST WAS 24 AND THE CAR IS BETTER THEN A VET THANKS AGAIN 3480
What about an update or recall that the dealer may need to do on my original build, how does the western deal with those? Should I just ask Western? Thanks ( last question - then we'll talk about mixing my fuels ).
Thanks
2008 GXP-Mysterious / GMPP (Stage II)
5- speed, On-Star, XM Radio, Premium Package, Leather Seats, Monsoon 7 Speaker High Performance Stereo with 6 Disk CD Changer, 18" Chrome Wheels, Rear Spoiler and Sport Metallic Pedals.
Did Lyndon had to done anything to the tune so the Meth will run properly, or no tune adjustment needed?
Arsenal:
2009 G8 GXP / Soon to be converted to Holden-Chevy Impala SS
2008 Nissan Armada LE: Fully Loaded, White on White 24"s, Flowmaster Super 40's, Volant CAI, Timming Advanced 3 degrees...
1995 Chevy Impala SS 407 Twin Turbo: 1500HP of pure American Muscle (Assembled by: TBK Performance in Miami FL) [/color]
2008 Magnetic (Carbon Flash Metallic) GXP: Fully Loaded...
Wester's RACE tune
Solo High Flow Cat
Custom 3" exhaust.
K&N Filter **SOLD**
I believe you can change the timing when you use water/meth. The water/meth itself has a separate computer that you can set to spray at certain levels depending on the boost (progressive spraying) level. The Westers tune really doesnt have anything to do with the spraying of the water/meth, it simply allows it to unleash its maximum potential by adding timing and some minor additional tweaks.
1Sgt Modifications:
Total Mods to Date 46:01/04/2009
Stubbie Ant, Painted Calipers with Decals, Vanity Plate, GM Club Decal, Painted Gas Cap, 5 Mean Engine Caps Red Lettering, Stainless Fuse Box Plate and Turbo Heat Shield Etched, Cold Air Intake, Solo Exhaust, Splash Guards, Wind Restrictor, Painted Engine Cover, Polished IC Pipes, GM Caps Red, Liner Mural, Intercooler, Sunviser covers, Diamond Stitch Center Console.
Lyndon has no control on the AEM kit, since it is up to the user what boost level the min spraying, and what boost level will be the max spray.
The AEM computer can be set from .5psi - 31 psi.
My min spray is at 11psi and progressively go up until 20psi max spray.
Lyndon and I have been going back and forth with different tunes to eliminate the KRs.
too much advance timing or too much wat/meth spraying will both produce tons of KRs.
And yes, the most total KRs I am seeing now on my HPT logs is only 1.5 degree KR. which is very very minimal.....and only occurs once in a while on low rpms. I used to have up to 7 degree KR, and that was completely eliminated
so u pretty much have to set the meth to shot always so it will not run crappy then? i guess that , means u buying meth really often...
Originally Posted by sky888
He advanced the timing even more....and very very aggressive, compared to the regular Race Tune.
The water/meth tune is only used when there's water/meth involved...........if not, the car runs crappy.
Arsenal:
Wester's RACE tune
Solo High Flow Cat
Custom 3" exhaust.
K&N Filter **SOLD**
my water/meth is always ON.
but I also connected an off/on switch.......just in case I ran out of water/meth in the middle of the desert or something freaky happened to my kit.....I can turn off the water/meth so the pump will not burn.......and I can just go back to my OEM tune
i use windshield washer fluid. It has about 30% methanol. That's the cheapest way...and most convenient way.
but if I feel like going fast during the week-end, and going to the track.............I only pour windshield washer fluid up to 70% of my 1 gallon container. The remaining 30% I fill it up with pure methanol. I stock tons of methanol in my condo!
Thats not bad, dam what would happend if i put that on my Impala SS, nevermind, i think ill blow the engine, 1500HP (1230WHP) is already pushing it to its limits... But on the Stice, ima sure do it...
Originally Posted by spiky3480
it lasts a week or two, and it costs $3 to fill up the tank
Arsenal:
Wester's RACE tune
Solo High Flow Cat
Custom 3" exhaust.
K&N Filter **SOLD**
And the best part that I hear is that your gas mileage slightly goes up, paying off the methanol kit over time and making up the $3 difference in washer fluid.
yeah 1-2 week, if you don't hammer the car.......hahahaha!
but if you drive about 40 miles a day........and a whacko like me who boost 23 psi for 10 secs or more on the highway.....then that one gallon tank will only last for 4 days......
AEM has three nozzles that they provide the consumer (small - large).
for our cars.....we can use the small (130cc/min) and middle (315cc/min) nozzles.
I am currently using the middle nozzle and start spraying at 11psi.
I guess, if you want to conserve the water/meth and have it last longer......you can use the small nozzle, and tune your car that way......
