Old 10-01-2009, 11:24 AM   #1 (permalink)
R&T
R&T's Avatar
Winter Storage Tire Pressure
Quick question. This is the first time I will have to store a car for the winter. I am not using jacks or dolly's and I see everyone seems it is best for the tires to have more air when stored.
How much air? Will I be safe at 35 psi or are we talking like 40 or 45? Thanks for the info.
2008 GXP Manual, every option and more to come....
R&T is offline   Reply With Quote
Old 10-01-2009, 01:13 PM   #2 (permalink)
rlhammon's Avatar
I've only upped mine a few PSI every winter... so 35 should be just fine. You just want to protect the sidewalls from being crushed when the temperature drops (and so does the PSI in the tire). If you see it's low in the winter, put some more air in there...
My Mod Information Page
Old 10-01-2009, 03:07 PM   #3 (permalink)
typhoon's Avatar
I use 29psi. As it says on the sticker.
2008 GXP 5 speed Brazen GMPP upgrade
typhoon is offline   Reply With Quote
Old 10-06-2009, 04:57 PM   #4 (permalink)
kennysabarese's Avatar
Send a message via AIM to kennysabarese Send a message via Yahoo to kennysabarese
Put it on jackstands and not worry about it?
2007 Sky RL - Black on Black
Purchased used with 8,500 miles 5/7/08
GMPP LNF Turbo Upgrade Kit
RMR Style Bar - Silver
kennysabarese is offline   Reply With Quote
Old 10-06-2009, 05:33 PM   #5 (permalink)
Envious06's Avatar
Sure, so when you put it back down all of the pitting that took place over the winter on the components that shouldn't be exposed can rip up all of your seals causing all of your shocks to leak. All newer tires are built to handle winter storage. Leave it down, add a few psi. you'll be fine.
Envious06 is offline   Reply With Quote
