Old 01-03-2008, 01:05 PM
   DDMworks Stage 2 Supercharger
Supporting Tuner
Dave@ddmworks's Avatar
As most of you know by now we have been testing intercoolers and set-ups for the intercooled, or stage II SC. The biggest thing about this upgrade kit is the intercooler. We worked with a local company who have supplied many OEM's with performance Intercoolers and other parts for their show cars and production vehicles and all I can say is WOW!! The intercooler is easily the highest tech and best intercooler I have seen out there. The extruded tubes allow air to pass easily through the intercooler to make sure that we do not have any of the overheating issues. Also the fins that are used for heat transfer are an engineered piece on this intercooler and have little louvers on them to increase the surface area available for heat transfer even more. The internal extruded design maximizes flow and heat transfer. With careful design we are only only seeing around 1 psi pressure drop from the supercharger outlet all the way over to the MAP sensor at the head, which is very very good on a set-up like this.
So now the part that everyone is waiting on the numbers. 235HP and 245ft/lbs of torque at the wheels and that torque comes in very low. This thing really is a torque monster and very very fun to drive around town. Need to pass? even in 5th gear there is so much torque available instantly that there is no need to downshift. No need to wait for a turbo to spool at 2K, the power is instantly there. The intercooler only makes this an even more ideal street set-up for those looking for great drivability and something with an immediate kick in the pants of big torque fun!
Here is a comparison graph of stock vs. modded Solstice vs. DDM Stage 1 (non-intercooled) vs. DDM Stage 2 (intercooled):
The red line is the DDM SC intercooled
The smaller purple line just below is a turbo kit for the 2.4L
The orange line is the DDM SC non-intercooled
The Dark blue line is a modded Solstice
The Dark green line is a Stock Solstice
And the second question that you have is going to be price. The intercooler kit is $1250, but we will be offering special package pricing and initial offering. The full intercooled supercharger kit seperately is $4495, but we are offering the first full kits for $4250.
We have talked with the intercooler manufacturer and they are telling us that the first production batch of intercoolers will be completed by the end of January.
As for all of you that have purchased a supercharger kit already, just give Ivy a call and she will put you on the list for the intercooler, there will be a small deposit of $100 just to secure your spot. Those that have not purchased a kit already, give us a call and we will put you on the list for the first intercooled kits. The deposit on the intercooled kits is $1000.
I think that the wait has been worth it, Randy's car is really a blast to drive right now.
Now time to start on stage III
Dave@ddmworks is offline
Old 01-03-2008, 01:16 PM
SolScuba's Avatar
Send a message via MSN to SolScuba
My order is in!!
2004 Dodge Ram SRT-10 - 500HP/525 ft/lbs!!
SolScuba is online now
Old 01-03-2008, 04:35 PM
1KULSOL's Avatar
Send a message via Yahoo to 1KULSOL
Originally Posted by SolScuba View Post
My order is in!!
mine as well
DDMWorks Supercharger kit #11 - STAGE II - DDMWorks 3 guage pod with PLX gauges (boost/afr/oil temp)- Koni Sport shocks f/r-DDM ProBeam-DDM upgraded brake kit(drilled/slotted rotors-ss brake lines-ceramic pads)-DDMWorks 4-1 long tube headers and hiflow converter-JPM padded and customized center console-Pioneer DEH-P880PRS head unit-Pioneer GEX-P920 XM receiver-Garmin Nuvi 350 GPS-SOLO SQR-2 dual center exhaust-Norms Painted (SLY) rear valence-Dashhawk Gen II-BEL STi Driver radar detector
1KULSOL is online now
Old 01-03-2008, 04:48 PM
Dave can you give us an up date on the pulley system. Still can't post on the DDM.
SCISOLSTICE is offline
Old 01-03-2008, 05:03 PM
Mr. Stone's Avatar
This is a Solstice with this kit alone, correct?
No headers, exhaust, etc?
The Boogeyman
Stone's modification page
Mr. Stone is offline
Old 01-03-2008, 05:23 PM
Supporting Tuner
That dyno does have headers and an exhaust. Actually randy is running the entire DDM set-up right now.
Dave - DDMWorks - South Carolina the home of the supercharged Kappas.
Old 01-03-2008, 05:27 PM
Supercharged !
DA 1234's Avatar
What does the install entail ?
DDM Supercharger #2
DDM Stage II Intercooler
DDM Pro-Beam
JPM Shifter
Clear Image Long Tube Header
Flow-Thru Cat
B&B Dual Exhuast Muffler
Eibach Lowering Springs
SSB Brakes Front & Back
BF Goodrich G-Force 255/45 Tires
DA 1234 is offline
Old 01-03-2008, 06:29 PM
   This changes everything.
bigblau's Avatar
Wow…this is very interesting. I’m going to have to take a second look at S/C over Turbo for NA Solstice. Looks like S/C may have the advantage for street driving.
I like the immediate torque (no spooling). That and the 3.90 rear-end gear should blow the doors off any Turbo Solstice.
I’m also thinking that longevity issues give the S/C the advantage –more power @ low RPM.
bigblau is offline
Old 01-03-2008, 06:32 PM
69T/A's Avatar
Here we go again!!!!!
07 SLY 5SPD. -- DDM STAGE II SUPERCHARGED #10, DDM Pro Beam, SOLO Shorty Header, Werks Cat, Magnaflow CatBack, AfterShock Rear Spoiler, Upshield, Sport pedals, 18" Gravana J2 Staggered wheels. Cooper Zeon 2XS tires(275/40R, 245/45F)--
69T/A is online now
Old 01-03-2008, 11:07 PM
Mr. Stone's Avatar
I agree.
This is getting to be a very hard decision to make.
The Boogeyman
Old 01-03-2008, 11:12 PM
Jackknife's Avatar
I'm in! Number 3 on the list. WOW, 285 flywheel!
Jackknife
FE3 sway bar ... Car. Cust. Rests and Pockets
Blacked-out Grills ... Debadged
DDM Pro-Beam
Jackknife is online now
Old 01-04-2008, 12:07 AM
Colorado Kid's Avatar
Are there any pictures of the full set up?
2007 Solstice N/A, Color: Sly, Optons: Loaded
Plus Solo Performance SQR2, GM CAI, Wood Dash Kit, Konig Hot Swap Rims, Custom Fog Light And Back Up Light Covers, Custom one off hood, Escalade side vents, Custom paint.
Colorado Kid is offline
Old 01-04-2008, 07:54 AM
Supporting Tuner
We will get some production pics up when we get the first run of production pieces back. There will be some pictures of the prototype set-up on Randy's car that will make it up here in a few days.
Old 01-04-2008, 08:07 AM
Chemist's Avatar
Jackknife
Go, Jack, go!
I've got to see/sit/ride in your Sol soon.
--Chemist (I've got $4 in the S/C fund, just a few more to go! )
"Muirne" --- Envious, ebony leather, LSD/ABS/AC/Monsoon w/6CD changer, mats, splash guards, black "stubby" antenna, Lil' Chromies, K-sphere pedals, K-sphere CAI, VectorSports ECM, RED center cap decals, the TWEETY door unlock/lock button, Garmin c330 GPS, Flowmaster 40 performance muffler w/GM OEM tip, RED calipers with white decals, High Note horn mod, Brushed aluminum door sills, ClearImage shorty headers/hi-flow cat, etched/lighted WindRestrictor. --- She growls!
NASSOA Founding Member
Chemist is online now
Old 01-04-2008, 08:14 AM
Rowan1008's Avatar
Dave that is great news. I'm looking forward to coming down in July to have mine done. I was curious to see if I out money down now, would I still be able to get the discount ???
Rowan1008 is offline
Old 01-04-2008, 08:15 AM
