Old 02-01-2006, 04:13 PM
   Argument end point
Little Red #531's Avatar
Originally Posted by PbFut
Just visiting. It is curious as to the idea of what a flywheel will and will not provide. I offer this information for those who may wish to understand the effects in greater detail.
From my own experience. The average driver will not like a lightened flywheel. You get a small but noticeable performance gain in lower gears at the expense of smooth ideal and possibly increased transmission gear lash or chatter. The clutch can also chatter during slow launch engagement. The engine is much easier to stall at launch. You get a snappier sounding engine. You know, rap, rap, rap, as the RPM quickly goes up and down much more quickly. Fast shifting can be easier and I find heel and tow shifting to be much easier.
This link will explain the effects, as well as provide mathematical calcs for those needing engineering proof. http://www.uucmotorwerks.com/flywhee...heel_works.htm
The site is for the BMW engine, but the principals are the same.
Positive proof why every high performance car from smallest class (H Modified) to largest (unlimited) run light flywheels on all tracks where you find a corner, and of course the drags. I believe dry lakes and Bonnaville would be the exceptions.
So, it looks like this one can be put to bed.
If you can remember to give it a little throtle when you take off, go with the light one. I wouldn't pull the engine just for this though. However, if I was going to pull it for any reason I would install the flywheel and clutch package. Just like we did in the good old Hot Rod days. Ah, -- that was before most of you were born.
Mark Twain.
Ponder that awhile.
Little Red #531 is offline
Old 02-01-2006, 04:21 PM
mabrylm's Avatar
Hmmm... clutch package. Do tell. I haven't heard anyone bringing up the clutch. What exactly would a new clutch package do? Where do you find one? How much? Installation?
VIN# 8902 Arrived 9 Feb 06
Deep, loaded. No smokers/XM/Onstar
Need info on an accessory or modification? Look no further!
Click here:
Mod Picture Index
mabrylm is offline
Old 02-01-2006, 04:51 PM
mena661's Avatar
You basically replace your OEM clutch (clutch disk, pressure plate and throw out bearing) with an aftermarket one. Some packages include a lightweight flywheel. You would do this when you've exceeded (or are going to exceed) the clamping force of the stock clutch.
mena661 is offline
Old 02-01-2006, 05:03 PM
Administrator
brentil's Avatar
Yeah, light weight 18x8 wheels in our bolt pattern are going to easily run $2000+ for four wheels. We haven't even started talking about tires ye to put on them.
brentil is offline
Old 02-02-2006, 03:56 PM
uncivilracer's Avatar
Send a message via AIM to uncivilracer
Just think of it like an underdrive pulley. It isnt gonna give u actual horsepower, but it will help free up horsepower from other mods. On these cars it is well worth it. I have done it on everyone of my cars.
Now as stated above, they want a stock one on a completely different HEAVY car.
2006 Pontiac Solstice
uncivilracer is offline
Old 02-02-2006, 05:35 PM
Critterman's Avatar
Clutch package is what you replace when you have worn the old one out with all the upgrades
NOT WAITING ANY MORE!
Critterman is offline
