Old 12-16-2006, 12:22 AM
   GRAVANA Coil-Over Suspension PRE-ORDER PROMOTION
Supporting Tuner
gravana1's Avatar
Pontiac Solstice & Saturn Sky enthusiasts currently suffer the pain of not being able to find a true engineered adjustable suspension solution for a car that begs to be driven hard. From the first day we had the opportunity to see GM's new Kappa platform suspension, we knew we were looking at one of the best suspension systems to come out of GM in quite some time. We just made it better!!! After nearly six months in development, and another 2 months of road and track testing, Gravana is announcing the release of our new Gravana/B+G Coil-Overs for the Sky. This is the ultimate coil-over system for the Kappa. Hands-Down! Designed for street, yet ready for the track, Gravana/B+G Coil-Overs offer the best of both worlds in terms of ride quality and performance.
Finally, a complete engineered coil-over suspension solution is available exclusively from Gravana! Introducing, the Gravana/B+G Coilover System!
  • Double Ride Height Adjustability
  • 32-Level Damping Adjustability
  • High Quality European Design
  • Anodized Steel Bodies and Lower Brackets
  • 6061 T6 Aluminum Components
  • Progressive Rate Springs
  • Lifetime Warranty! (Yes, Lifetime!)
Most coil-overs force you to lower the spring perch to adjust height, which reduces the shock travel and performance. Gravana/B+G Coil-Overs allow you to lower the car without reducing the shock performance. How? Each shock body is fully-threaded for precise ride height and weight transfer, and inserts into threaded steel lower brackets. Thus, the stroke of the shock rod does not change. Additionally, the Gravana/B+G coil-over has billet adjustable spring perches which can be lowered, giving the Gravana/B+G Coil-Overs Double Ride Height Adjustability. This separate height adjustability via spring perches allows you to fine-tune your stance and ride or even slam the car for shows. For those who have been torn trying to figure out which suspension is best, Gravana has the Answer! The shock bodies, perches and brackets are all anodized steel for maximum strength and corrosion resistance. Component pieces are made from 6061 T6 aluminum alloy for a combination of strength and light weight.
Quite often, companies try passing off coil-over conversion kits (a threaded sleeve and collar with springs) as true coil-overs. Unlike the sleeve kits that serve as more of a bandaid and often click and make noise as you drive, this is a True Coil-Over System engineered on the car. Each shock body houses a Monotube Gas Charged damper for quick response and steering control without loss of performance during high stress use. Unlike twin-tube dampers that experience oil-foaming, the monotube design provides a reliable and consistent level of damping force. Each shock incorporates 32 levels of bump & rebound damping adjustment (16 clicks adjusting both compression & rebound simltaneously on each click), allowing you to dial in the best combination of rebound and compression for any driving environment. In our testing, click settings 1-5 are excellent for most street environments. 6-9 are for the more aggressive drivers, looking for the competitive edge. 10-12 is for the driver who wants track-level performance for that smooth mountain road or even Autocross. Levels 13-16 are for those of us who like to wake up on a Saturday morning, bypass breakfast and coffee, and load our helmets in the car for a day at the track. Most people who drive the test car liked the 7-12 range to achieve the ultimate combination of comfort and performance for daily driving!
The progressive rate coil springs included in the kit are specifically designed to work with the Gravana/B+G Coil-Overs to provide the best combination of performance and ride quality in an effort to provide you with a finely-tuned coil-over suspension system. As a policy set forth by B+G, we do not publish spring rates. However, higher and lower rate springs are available; email us if you need them. Ride height adjustability will range from 0" - 2.0" and can vary slightly from car to car.
The Gravana/B+G Coil-Over System is a direct bolt-in for all Pontiac Solstice, Pontiac Solstice GXP, Saturn Sky and Saturn Sky Redline models.
WHAT'S THE DEAL?
MSRP is $1499.99. Gravana is offering the kit for only $1250.
PRE-ORDER YOURS TODAY AND LOCK-IN YOUR PRIORITY ON THIS LOW PRICE AND FREE SHIPPING!!!
Your credit card will not be processed until the item ships.
Gravana Wheels ON SALE! Check website for details!
Gravana/B+G Coil-Overs Are NOW SHIPPING!
CLICK HERE TO CHECK OUT OUR MYSPACE-ONLY PROMOTIONS!
FOR SALE:
- 2006 Gravana/Hahn Turbo Saturn Sky Project Car With One-Off GM Designed Body Kit
- 2006 Gravana/Boston Acoustics Pontiac Solstice Project Car
Email Us @ Gravana Tuning
www.GravanaTuning.com
gravana1 is offline
Old 12-16-2006, 01:32 AM
Gizmo's Avatar
Dear Santa:
I know I haven't been a good boy this year,
but please, please, please, bring me this, Santa!
I'll be good, I promise!
Her name is MariSOL
Link- Gizmo's Modification Page
NASSOA Founding Member #77
Team Solstice 2008
I am Officially recognized by GM
Gizmo is online now
Old 12-16-2006, 01:47 AM
Supporting Tuner
gravana1's Avatar
Originally Posted by JuanPablo View Post
Dear Santa:
You will need 4 long stockings for these...
Jim
PS - Our new wheels may not fit under the tree, but they make a great gift, as well...
FOR SALE:
gravana1 is offline
Old 12-20-2007, 09:51 PM
Supporting Tuner
gravana1's Avatar
After being pushed back for 9 months due to other coil-over projects, our first shipment of Solstice & Sky coil-overs is due on 12/26/07. We will be calling all of our pre-order customers first to verify information and start shipping ASAP.
Thank you all for your patience. As some of you know from driving my Solstices and Sky, the reward is in the product itself!
Jim
FOR SALE:
gravana1 is offline
Old 12-21-2007, 04:31 PM
Yamatr3's Avatar
How are these different from the K&W's? I thought the K&W's were made for our cars too.
Yamatr3 is offline
Old 12-24-2007, 01:34 PM
meat's Avatar
Can you get the K & W's?
2007 gxp solstice loaded + smokers package
2006 cobalt
2007 Corvette
2006 lotus exige
2005 hayabusa
Red Bull Drift team 2008
Team Yankee!
meat is offline
Old 12-25-2007, 12:26 AM
mena661's Avatar
I think Werks sells them.
mena661 is offline
Old 12-27-2007, 03:44 PM
Yamatr3's Avatar
Jim, I get no response to my question above?????? I think my question is a good one. These are $500 cheaper than the KW's. How about a comparison.
Yamatr3 is offline
Old 12-27-2007, 04:23 PM
I would second that request.
I would also like to see a comparison myself.
Also as a reference point to include the GMPP suspension, even though they are not adjustable.
LatinVenom is offline
Old 01-03-2008, 04:27 PM
My-Low-Sol's Avatar
very
From a features comparison standpoint...
GMPP: non-adjustable, mono-tube dampers, painted steel housings
Gravana/B+G: ride height adjustable, 16 position single adjusting knob (affects low-speed rebound and compression together), mono-tube damper, anodized steel housings
KW: ride height adjustable, infinitely adjustable (no clicks) rebound damping, 14- level adjustable compression damping, mono-tube dampers, inox-line stainless steel housings
Red Bull Drift Team 2008
Formerly Miles@Tirerack
My-Low-Sol is offline
