Old 12-08-2006, 09:08 AM
   Spec Clutches and flywheels now available!!!!
Supporting Tuner
Just in time for your winter projects - Spec Clutches and lightweight aluminum flywheels are now available!!!!
Perfect companion to those higher horsepower turbo setups (shameless plug - including ours which will be available soon )
We have the entire line from Stage 1 through Stage 5 available right now!
Check them out and order here -
http://www.performanceautowerks.com/...&filter_id=104
Here is the pricing info -
Spec Sosltice/Sky Aluminum Flywheel $425.00
Spec Sosltice/Sky Stage 1 Clutch $445.00
Spec Sosltice/Sky Stage 2 Clutch $495.00
Spec Sosltice/Sky Stage 2+ Clutch $545.00
Spec Sosltice/Sky Stage 3 Clutch $495.00
Spec Sosltice/Sky Stage 3+ Clutch $645.00
Spec Sosltice/Sky Stage 4 Clutch $495.00
Spec Sosltice/Sky Stage 5 Clutch $645.00
Dave Gilbert
Midwest Solstice/Sky Headquarters!
www.werksracing.net
815-439-4547
werks is offline
Old 12-08-2006, 09:40 AM
Gizmo's Avatar
That's great, werks! I'll be contacting you in awhile with my order.
But in the meantime, how about laying out for us what the differences are in the various stages. I know that when you get to the higher stages, they're designed for racing, since they are not driver-friendly for daily commutes, right? You could include the prices, if you like, so we have that info out in front of us instead of having to go to your website. Or maybe that's the idea, eh?
Her name is MariSOL
VIN 6Y101319, delivered 10/15/05. 65,684 miles.
Link- Gizmo's Modification Page
NASSOA Founding Member #77
Team Solstice 2008
I am Officially recognized by GM
Gizmo is offline
Old 12-13-2006, 05:29 AM
Supporting Tuner
Sounds good! I updated the original thread with pricing information.
Dave Gilbert
www.werksracing.net
815-439-4547
werks is offline
Old 07-08-2008, 11:23 AM
anglipop's Avatar
Hello Werks,
I understand that the above links are for the Solstice with the Base 2.4 Engine. Has Spec released flywheels/pressure plate/clutch disc/thowout parts or kits for the 2.0 turbo Ecotec with Aisen 5 speed manual transmission? Do you recommend the aluminum flywheel ?
Thanks,
Anglipop
anglipop is offline
Old 07-08-2008, 12:49 PM
Supporting Tuner
Originally Posted by anglipop View Post
Hello Werks,
Thanks,
Anglipop
Yes, they have the same clutch/flywheel line up available for the 2.0T and I would strongly reccomend the aluminum flywheel, it helps out a ton with engine response. It is a bit noisier than stock however so if you can put up with the added noise it is for you!
Dave Gilbert
www.werksracing.net
815-439-4547
werks is offline
Old 07-08-2008, 05:48 PM
anglipop's Avatar
Hello Werks,
Thankyou for your quick reply. Please confirm if the 2.0 and 2.4 clutch assembly parts are the same - my information (possibly wrong) is that they are different. If they are the same, does that mean a Solstice 2.4 starter (also shared with my other GM vehicles) is the same as a 2.0 starter ? The price difference is $40 for a 2.4 used starter compared to $180 for a new 2.0 starter. Finally, I am very interested in using the aluminum flywheel in my Anglia but have sticker shock at the clutch cost. What is included with the clutch kit: pressure plate, clutch, hydraulic throwout, pilot bearing, alignment tool etc. I will need your recommendation on what clutch to buy, but will leave this for a followup email. Thanks for your help ...
Anglipop
anglipop is offline
