Old 03-05-2006, 02:28 AM   #1 (permalink)
SF Celebrity?
dori-san's Avatar
Send a message via AIM to dori-san
First time using clay OR wax! (pics inside)
First allow me to apologize for the poor quality of the pics.
If you know me then you know I take great photographs. Something happened with the memory card on my camera and I was not able to get the pictures off of it. The only option I had was to plug the camera into our projection TV and view the pictures on there, then I took ANOTHER camera and took pictures of the pictures being displayed.
Nightmare situation, I know.
Anyway, on to the post...
I've never waxed a car before, but I knew with one this awesome that I definitely wanted to make a habit of it. After reading numerous posts by Gary and studying up over at Autopia's guidetodetailing.com I also decided that I should claybar as well. So this whole thing was a learning process for me and I decided to share it with everyone else as a write-up of sorts to let people know that they don't need to be afraid of detailing their own car.
After washing and thoroughly drying your car you can begin the process of clay barring and/or waxing your car. If you have an empty garage that you can keep your car in during this process it is definitely a good idea to do so as it's best to keep it out of direct sunlight and also keep it from getting airborn contaminants (like pollen) blown onto your car while you're working. Before we begin, after you've washed and dried your car you should touch it. Feel the surface with clean hands and just store that feeling for future reference.
Here is the claybar product that I used. I've never clayed before, so I can't give a preference as to which product you should use. Most claybar kits cost roughly 14-16 bucks at a number of auto places and this one comes with the bar of clay, a bottle of quick detailing spray, and some scratch removing product that I didn't bother with:
After a good bit of trial and error, I found that I was making a mess and wasting the detailing spray by spraying it right on the car and then using the claybar. I discovered that the best method for me was to spray a couple squirts onto the claybar in my hand and use it that way:
Start by rubbing the clay back and forth over a small section of the car. If it feels like it doesn't want to slide very well don't worry, that's because there are contaminants on the surface. After your push it back and forth a few times applying mild pressure, it should noticeably feel slicker and the clay will glide easily. This means you've gotten everything up, now move to another portion:
Rewetting the claybar as often as necessary and working in 2' x 2' sections until the entire car is finished, most of the rest of the car should be dry by now and look pretty gross:
Don't worry about that, it's not like hard water spots that will damage your paint. Just get a good microfiber detailing cloth to wipe it off with. (I use microfiber cloths that I get from Target by a company called Vroom. There isn't a website and they can't really even be found on Target's website, so finding them requires going to the store and even then I can't guarantee that you have them locally.) The detailing cloth I have is soft and has a VERY small pattern to it... this one when you run your hand across it should feel kinda prickly, because it's picking up the microscopic imperfections in your skin and snagging on them. This towel will NOT mar your car's surface, it only FEELS rough because your hands aren't buttery smooth like your car. So just wipe up all the dried claybar/quick detailer residue, you may want to flip the towel to a clean side for the final swipe just to make sure you got it all up:
Now that you've cleaned it all up, take a step back and admire the gleaming surface of your car. If you are fortunate enough to have a garage to do this in you better be doing it in the garage because you wouldn't want any airborn contaminants to lay rest on your fresh clean car. If you like, go inside and wash your hands real good. Then come back out to the car and run your fingers along the surface. If you did this before you started like I said, then you should definitely notice a difference in the feel now. The car is now smoother than a baby's bottom and, personally, that smooth glassy feeling is almost enough to send me over the edge. I sometimes just rub the car for minutes on end because it's so smooth and sexy.
Now, on to waxing. It's best to wash the car again to make sure you've got all the clay residue cleaned off.
The product I'm using is Meguiars Gold Class wax, my father gave it to me for my birthday before I even got the car. Again, I don't have any experience with any other products so I can't compare.
I've never waxed before, so I'm not sure if I'm using too much or not. Hopefully Gary can chime in here and add some insight. I usually put a dab about the size of a dime and rub it on for a bit, re-applying the dab a few times throughout the process. Usually, to give a bit of perspective; I probably re-apply the blob onto the applicator 3 or 4 times just for the hood, twice per door, twice per bumper, 2 or 3 for the decklid, and 1 or 2 for each fender.
This dab size is a bit larger than I usually use now:
When applying, make sure you get a good even layer all over and don't miss any spots. Here I am applying in a circular pattern as I have always thought how you were supposed to wax ever since Mr. Miagi taught me how. However, since reading up on Autopia I've learned that circular patterns can create swirl marks and that you really should wax in a back and forth motion. I've waxed the car 3 times now and these pics are from the first time, the other two times I did a back and forth waxing. I must say, it just feels weird as I'm really tempted to make the circular motion. Perhaps Gary can shed some light as to wether or not there is any validity to these claims. Because if circular patterns aren't bad for the car, then I'm definitely going back to that.
Applying the wax:
Now make sure to follow the directions with your wax, because different kinds/brands call for different procedures. Some waxes require that you buff them off almost immediately, others must dry and haze over before you remove them. Meguiars Gold Class requires that the wax haze over first, which I read somewhere that it usually takes around 15-20 minutes. I'm not sure if it's the humidity here in Florida or (lack thereof in my garage) but it takes about an hour for my wax to set up real good. The best way to tell is to rub your finger on a waxed surface; if you run your finger over it and leave a streak with a waxy residue then the wax hasn't set up yet, but if you run your finger and the car surface is completely clean in the swipe spot then your wax has finished curing.
Hazy, cured wax:
Now I used a good polishing towel to buff off the hazed wax. The polishing towel is more fine and doesn't snag on your hand, in fact it feels a lot like deerskin. (Again, I'm using towel products by Vroom which I found at Target.) Then you just wipe until the haze is gone, turning to a clean side for the final wipe to make sure its good and spotless:
I hope everyone enjoyed this post and found it beneficial.
I enjoyed writing it and again I'm sorry about the poor picture quality.
Keep an eye out as I have two other picture threads to post soon and I'll cross link them here. I did a slight mod at the same time as the clay/wax that I also got pictures of. They're not that great, but I'll post that soon. I also had a photoshoot of the car right afterwards and of course all those pictures got stuck in the camera as well, but I have re-waxed since and went out to redo the photoshoot, so look out for that thread as well.
Here is my second picture thread of the mod I did: Buttocks Enhancement [painting the rear grille]
The photoshoot thread is now up, check it out: Work that Camera! [#1599's second photoshoot]
#17313 | Scarlett! | AC | ABS | LSD | Pwr | Conv | Single MP3 | Monsoon! | All but lost...
dori-san is offline   Reply With Quote
Old 03-05-2006, 06:03 AM   #2 (permalink)
Ex-Miata Man's Avatar
Great post!!! I'm going to clay bar mine just before the NEO/PA run on the 25th. Now I see what I will have to do.
AKA xmm
DEEP with Steel/Sand leather,
88,000+ miles on the odo and still goin' strong- Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"Goin' on a Turkey Run !!!"
Ex-Miata Man is offline   Reply With Quote
Old 03-05-2006, 06:11 AM   #3 (permalink)
FireSol's Avatar
What a great explanation. I'm going to try "claying". It sounds like it is a very fine abrasive to clean the surface before waxing.
2007 MEAN GXP
2006 AGGRESSIVE - traded in for GXP!
NASSOA Founding Member #88
North Coast Kappa Club
FireSol is offline   Reply With Quote
Old 03-05-2006, 06:27 AM   #4 (permalink)
mceb's Avatar
Great post Dori It's very important to keep the clay very well lubed to reduce friction. Once you've clayed it don't think it has to be done for a while again.
Here's a link to another good how to:
http://www.autopia-carcare.com/inf-clay.html
Pontiac RIP 1926-2009
Old 03-05-2006, 10:06 AM   #5 (permalink)
LOST SOL
MSG_McKee's Avatar
Nice post I would like to see some pictures of the wax job, once you have a chance to post them.
Current sMiles: 21,622
Click Here To See My Mod Page
Old 03-05-2006, 10:20 AM   #6 (permalink)
PURE_Fun's Avatar
Thanks Dori-san good how-to. Would love to see the car pictures outside in the sun.
Pure, Ebony, PWR, CNV.PKG, CD-MP3, XM, #4769 10/DEC/05
Mods: Calipers*Shaved*Caps*Chromies*Rear Fascia*GM-CAI*Eibach Sportline*Borla Exhaust*Headers*RazziWing*Lthr Visors*Eng Cover
Future: ProBeam, Homemade Backbone, GXP Swaybars, DDM Stage 2
1984 Blk Porsche 928S 196k
my PURE Pics upDated 28/Aug/06
PURE_Fun is offline   Reply With Quote
Old 03-05-2006, 10:54 AM   #7 (permalink)
stang's Avatar
Way to got the extra mile Dori.
stang is offline   Reply With Quote
Old 03-05-2006, 10:58 AM   #8 (permalink)
Happily In The Club
newman27's Avatar
Dori-san,
Thanks for the info from the perspective of someone that hasn't done this before (like me). I'm curious to hear about how much time you estimate the whole process took?
Thanks!
Newman27
Atlanta, Georgia
VIN 113486
Mina
Envious / Ebony Leather / Manual Transmission / Polished Wheels
All Options Except: On-Star, Premium Headliner, 6 CD Changer
6" Antenna, Door Sills, Fujita CAI, Kappashield, License Plate Frame, 'Lil Chromies, Seat Belt Extenders, reBAR Reinforcement, Splash Guards, Valve Stem Caps, Vector ECM Tune
Other Vehicles: '72 Opel GT, '99 Oldsmobile Intrigue GLS, '09 Pontiac G8 GT
newman27 is offline   Reply With Quote
Old 03-05-2006, 12:16 PM   #9 (permalink)
jimmyo's Avatar
I agree that claying your car makes a world of difference in the finish. I had been reading about other forum members praising clay bar, but until I tried it about 2 months ago, I was skeptical. Not any more! This is definitely the thing to do.
JimmyO
They call it the Bumble Bee
jimmyo is online now   Reply With Quote
Old 03-05-2006, 05:42 PM   #10 (permalink)
buckeyewilky's Avatar
Great job dori-san, a couple things I would advise and that would be when you are claying your car make sure you knead the clay frequently. The contaminants that are picked up should be work into the clay. Just knead the clay as if you are playing with Playdoo. Also, I would wash your car again after the clay bar, this will help make sure you removed all the clay. Then I would proceed with the waxing ect. Again great job Dori-san!!!!!!!!
buckeyewilky is offline   Reply With Quote
Old 03-05-2006, 05:47 PM   #11 (permalink)
RODEO's Avatar
I had a detailer tell me the "blue clay" bar is better than the Yellow Clay. I understand there's a third color available also.
He said it was less abrasive? Not my area of expertise, but thought I'd add the comment - maybe turbomangt will give us his opinion.
RODEO is offline   Reply With Quote
Old 03-05-2006, 05:54 PM   #12 (permalink)
Hey Folks,
Clay is not an abrasive. It is "sticky" and removes particles such as rail dust from the paint prior to waxing. The difference in the feel of the paint before you wax is amazing. Most folks don't use clay more than two or three times per year. The different colors relate to the stickyness of the clay and how well it removes different size particles. It takes awhile but is certainly worth it.
Blackdog
blackdog is offline   Reply With Quote
Old 03-05-2006, 06:15 PM   #13 (permalink)
firedup's Avatar
I ordered my Mother's clay bar on Ebay today. I have rail dust on my car from the trip out here on the train. You can feel it when your rubyour hand over it with a plastic bag.
COOL MAGGIE. 2006 Polished wheels. Steel /Sand. #3458 Premium, Power, and Convenience. Monsoon.
Her Name is Maggie. Her personalized plates are MAGNIFY
firedup is offline   Reply With Quote
Old 03-05-2006, 06:55 PM   #14 (permalink)
Helios's Avatar
Big difference with the new car?
I've only used the bar once, and it was on an older car. I was REALLY taking off the minor road tar, etc. Was there really a big difference from a newer car? Or did it come from the factory with some imperfections?
Helios is offline   Reply With Quote
Old 03-05-2006, 07:28 PM   #15 (permalink)
druid-2's Avatar
Location: buzzard..what buzzard..do you see a buzzard..I didn't see a buzzard...or that little sparrow either- or dat squirrel
konichi wa...dori.san..nice job
I just did a job on Merlin ...he was claybarred by the dealership and given a coat of zaino....but after doing a lot of checking I switched over the Maguier's NXT...which works on the color swirls and stuff.
I'm a lefty like you (think I didn't notice)...but I used the paste whereas you went with liquid...very little dry "after dust"
One other point in the NEO SOS thread I talked about grape jelly...It is also a Maguier's product called Gold Class Endurance high gloss tire gel
Never use armor all..use this stuff.... put an old sock on your hand and soak it with the grape jelly...put it on your hoops (tires) and anything else rubber...like gasketing etc..I also did the rear fascia..and the air dam with it
On saturday I "detailed" Merlin and uses the grape jelly on all the door and window gasketing...the rubber on the top of the windshield...everything in the trunk...plus everything black under the hood ...hoses ...hydraulic supports ...lines etc Just ask anybody who saw it today how it looks
just my 2 cents worth
NEOKappa.com
WINTER TRAINING SCHEDULE 2009-10
2010NASSM.COM
Some people grow old before their time...I choose to die before I grow old !
Druid (Cool) MERLIN came home 11-15-05 VIN 4495
Clear bra, Stubby antenna, Kappshield, mudguards, Chrome wheels with GS-2's...CAI..SOLO SQR-2 exhaust with free flow CAT & SS header ..painted calipers and wheel centre decals. 25% tint windshield ... Vertical Chrome billet grille .. stay tuned
druid-2 is offline   Reply With Quote
