Auto-x tires - Pontiac Solstice Forum
post #1 of 24 (permalink) Old 06-26-2009, 01:07 PM Thread Starter
GoDog's Avatar
Auto-x tires
I final corded my cheap test and tune tires (Hoosier 245/35 definitely the wrong tire) and am going to step up to a Hoosier A6 295/30 or a A6 275/35.
I run A-Stock so I am wondering if anyone has had trouble getting the 295 on the 8" wheel.
Anyone run the 275, looks to be a little taller.
What pressures are you running your Hoosiers at?
I had the 245/35 at 30-32 front and 26-28 rear
Go Dog Go!
2007 Sly GXP
GoDog is offline
post #2 of 24 (permalink) Old 06-26-2009, 04:07 PM
snaponbob's Avatar
I started on 245s and changed to 295s when I killed the 245s. HUGE difference. I have also tried 285s. Don't waste your time, get the 295s. The 275s offer NOTHING on the LNF Kappas.
Pressures are a function of car set up and surface (concrete or asphalt) as well as preference. I get smoother I need LESS pressure. No surprise there. I like the "feel" of higher pressure, but lower pressurees deliver better times.
snaponbob is offline
post #3 of 24 (permalink) Old 06-26-2009, 04:26 PM
KappaKadet's Avatar
You're not squeezing those 295s on the 18" X 8" stock wheels are you SoB.
KappaKadet is offline
post #4 of 24 (permalink) Old 06-26-2009, 07:14 PM
I think he is...he was trying to sell his 18 x 8 Ultraleggeras a little while ago so that he could get the 18 x 9 Allegerittas
07 2.4L/5-Spd, Mysterious, Premium & Preferred Pkg, Remote Keyless, Fog Lts, AM/FM/CD
MODS:
DDM S/C Stage II, Exedy Stage II Clutch & Lightweight Flywheel,
DDM Probeam, Eibach Front & Rear Anti-roll bars, 3.73 Rear w/LSD,
Kappasphere Lowering Springs, Koni Sport Adjustable Shocks,
B & B (Billy Boat) Catback Dual Exhaust, Hawk HPS Brake Pads
GXP Dual Exhaust Valance
245/40/18 Dunlop Direzza Sport Z1 Star Specs
Dashhawk, Stubby Antenna, Custom Alignment
"Maine"-iac is offline
post #5 of 24 (permalink) Old 06-26-2009, 08:38 PM
shabby's Avatar
They slip on just like a stock tire
shabby is offline
post #6 of 24 (permalink) Old 06-27-2009, 09:51 AM
Krazed Kanary's Avatar
Been using the 295 A6s on the 18 x 8s for 2 years. Just had set #7 mounted. They fit fine. Don't try it with the same size Kumhos tho, won't work. The only sure way to determine correct air pressure is with a probe type tire temp meter. Chalking the sidewalls is a waste of chalk and sure sign of a novice, especially with street tires. Look at the tread after running if it looks like oatmeal (not counting the OPR rubber you picked up) you are overdriving the tires. I'd suggest picking a pressure something between 30- 45 # and sticking with it, bleeding the tires to that pressure after each run until they stop changing. Playing with the pressures will just confuse you are to what is really needed (change of shock adjustment, change of driving style. The latter is usually the one that needs changing most often.) until you are running very consistant times, then make one adjustment per event and evaluate the effect it makes. It takes a very skilled and consistant driver to appreciate the difference a couple #s of air pressure change might make.
Team Dynamics AX racing
2007 GXP ZOK Mean
Top finishing Solstice 2009 SCCA National Championship
Solo Performance Race catback
Rick Hendrick Pontiac
Solo Performance
CHARLES FRANK goldsmith
Krazed Kanary is offline
post #7 of 24 (permalink) Old 06-27-2009, 08:29 PM
snaponbob's Avatar
A6 Hoosiers. No other 295s will pinch down on an 18X8" wheel. I now have 315/30X18 A6s on 18x9 OZs with no problems.
post #8 of 24 (permalink) Old 06-27-2009, 08:31 PM
snaponbob's Avatar
Done, but it was for 18X9 Ultraleggeras. They are on the car now with 315s on the back and 295s on the front. VERY good.
post #9 of 24 (permalink) Old 06-29-2009, 05:24 AM
DrJones's Avatar
As a tire engineer I would not recomend putting a 315/30R18 on a 9" width rim. As I've told Bob before I think the 295 on the 9" rims would give you better performance (even though it's still 1/2" narrower then Hoosier recomended rim widths). The tire profile shape will be compromised mounting the tire on a 2" narrow rim and the chance of debeading the tire goes up.
2007 - GXP - White
F-Prepared - Crazy Monkey Racing
Westers Garage/Norms Fiberglass/AVON TYRES
DrJones is offline
post #10 of 24 (permalink) Old 06-29-2009, 07:03 AM
snaponbob's Avatar
With all respect, Alex, I spoke with Hoosier about this. They agreed that while 10 or 11 inch rims would be better, 9 inch rims would work. My logic was, and is, that 295s have been working WITHOUT issues on Kappas for three seasons on 18x8" rims on our cars. There is NOT other "DOT" tires that will do that as the Hoosiers are so pliable. The 315 is .8" wider than the 295 and is mounted on an inch wider rim. The 295s on the 18X9 rims ARE working somewhat better than the on the 8s, but at the same pressures they are show the same types of temps and wear across the faces of the tires. The rears showed identical types of wear and temps as the 295s on 8s. Pressures use this weekend were the same as I used on 295s on 8s and it worked great. The rear traction was significantly improved (tire width) while the fronts were better (better side wall support). As a point of reference I ran a Divisional this weekend at Salina, Ks., on on old municipal runway. It is clearly THE stickiest surface anybody knows of. It's like racing on Velcro. This impression of traction is backed up by data recorders and multiple Nat Solo Champs (Greg Reno, Ron Williams, Andy Hollis, Mike Johnson, etc.). If there are going to be "issues", this would be the place. Would I prefer 10 or 11 inch rims? Absolutely. For now, cash flow does not allow the luxury. Do I feel unsafe? ABSOLUTELY not. But I would NEVER attempt this on ANY other tire than a Hoosier, because nothing else will tolerate "pinching" like this, yet the A6s DO and work. Hoosiers are just a different breed of tire.
post #11 of 24 (permalink) Old 06-29-2009, 07:28 AM
shabby's Avatar
Any rubbing issues? Especially in the back near the frame?
shabby is offline
post #12 of 24 (permalink) Old 06-29-2009, 11:01 AM
snaponbob's Avatar
Yup, but it can easily be resolved.
post #13 of 24 (permalink) Old 06-29-2009, 12:19 PM
shabby's Avatar
With a big hammer or...?
shabby is offline
post #14 of 24 (permalink) Old 06-30-2009, 06:46 AM
snaponbob's Avatar
And here is how the 295f/315r look under high side load. REAL hard transition, VERY high grip surface, ~36psi (MUCH lower on asphalt), well into 2nd (probably 5000 or so at about 50ish mph).
post #15 of 24 (permalink) Old 06-30-2009, 09:59 AM
shabby's Avatar
No 315's up front? Did you use a spacer out back to get rid of the rubbing by any chance?
shabby is offline
