Old 06-21-2008, 08:46 PM
   First time at the dragstrip with my GXP
I took my GXP [auto] down the strip for the first time this weekend. Only mod is the GMPP intake. All three runs were with no powerbraking.
1) 14.593 @ 96.04 / 60': 2.41 / TC&ECS Off
2) 14.587 @ 96.03 / 60': 2.37 / Competition Mode
3) 14.606 @ 95.27 / 60': 2.39 / TC&ECS Off
The track is 1500ft above sealevel, so with NHRA altitutde corrections, the times are
1) 14.38 @ 97.41
2) 14.37 @ 97.40
3) 14.39 @ 96.63
I really need to work on my launches to lower my 60' time.
2007 Aggressive GXP "Natsumi"
GMPP Intake
Lithium Lotus is offline
Old 06-21-2008, 09:14 PM
1) 14.38 @ 97.41
2) 14.37 @ 97.40
3) 14.39 @ 96.63
Your mph shows that your power is off.
Jack B is offline
Old 06-21-2008, 09:17 PM
silversolstice's Avatar
That's still quick for a car that can get 30mpg. Is comp mode TC & ECS on and it was your fastest time? Were you spinning the tires too much slowing down your 60' times?
Mileage as of Sept 27 16210 miles
silversolstice is offline
Can you elaborate?
When wearing a helmet and lined up next to a loud V8, it's hard to tell if I'm spinning my tires or not. I'm sure that's what is causing my high 60' though. It just doesn't feel like I'm spinning them off the line.
GMPP Intake
Old 06-22-2008, 09:37 PM
[quote=Lithium Lotus;709973]Can you elaborate?
Please don't take this the wrong way, I am trying to be constructive, there is something happening that is not right. Your MPH should be a bit higher.
You are right, your 60's are hurting your ET, but, something else is hurting the MPH. I hope you are turning off both ESC and TC, they will both interfere with a clean run and mph. I have made about 20 passes with the GXP and logged several of those runs and only saw the interference when reviewing the logs, I would not have known from the SOP.
The DashHawk is a nice tool and if you log RPM, real and actual throttle position, boost and real MAF you will see how the car is running. I hope you get your sixties under 2.0 and get the ET under 14.0. At our ET level, you might see your ET improve twice your reduction in 60' time. I believe you will see a 98-99 mph at your altitude if everything is right.
Good Luck
Jack B is offline
Old 06-23-2008, 10:49 AM
That's the thing. When I'm wearing a helmet and have a loud v8 next to me at the line, I can't hear if my tires spin. I had my TC/ESC off for those two runs marked, but somehow I had my fastest time in competition mode.
When I made all three runs, I believe the competition mode was run during the coolest part of the day, in the low-70's. I know the other two runs where around noon, not the greatest times to make a pass.
GMPP Intake
Old 06-23-2008, 01:31 PM
Deepbluegxp's Avatar
Nice times. Enter your times on this web site. I ran a 14.03 last September. Track elevation 325ft. My slip is posted on the site.
Fast Pontiac Solstices 1/4 Mile 0-60 Drag Racing - DragTimes.com
Team Solstice 2008
Click My modifications
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is offline
Old 06-23-2008, 10:29 PM
I have a stick and in the competition mode it would pull the throttle during the the launch. I also saw a big notch where it would pull boost as the car was about 60' out. I have gven up with the comp mode for both auto x and the strip.
Jack B is offline
Old 06-23-2008, 11:28 PM
mena661's Avatar
Good info to know, thanks.
mena661 is offline
Old 06-24-2008, 05:45 AM
So do you turn of TC completely?
Team Solstice 2008
Old 06-24-2008, 09:52 PM
Hold it for ten seconds, turn it all off!!
Jack B is offline
Old 06-25-2008, 06:03 AM
I knew that, I was inquiring if you did your runs with it off completely?
Team Solstice 2008
Old 06-25-2008, 05:37 PM
If it matters any, I do remember hitting 17psi for a split second on one run.
GMPP Intake
Old 06-25-2008, 09:16 PM
IMHO you have to have them all off when you hit the limits of performance. I could get no consistency at auto X or drag strip with either TC or Comp mode on. The only time I would use either is on a slippery auto X course.
Jack B is offline
Old 07-01-2008, 09:34 AM
You did better than I did. My first trip to the track got me a best of 14.6 at 96.
Craig Lewis is offline
Old 07-01-2008, 09:53 AM
I'll turn mine off completely then on the next run.
Team Solstice 2008
