Old 01-12-2007, 11:48 AM
RobL's Avatar
Originally Posted by AlanBDahl View Post
The questions are whether the FE3 in the GXP has those same short springs/spacers or if GM either gave the GXP longer springs or found a way to ship the cars without the additional spacers. If the GXP also has the spacers then the Z0K TSB will need to be extended to cover the GXP as well (how's that for a bunch of TLA's in one post, GXP, Z0K, FE3 and TSB, LOL)
Let me check...
There is definately a 1/4" or so blue plastic spacer at the top of the spring (only checked the LF) that is between the spring and the housing.
(and it felt good to finally touch the car in an autocross sort of way)
RobL is online now
Old 01-12-2007, 03:41 PM
93AS's Avatar
Since suspension motion ratios have come up.... has anyone taken the time to actually measure/calculate them for the Solstice?
Eric
93AS is offline
Old 01-12-2007, 09:57 PM
Administrator
SolsticeMan's Avatar
Originally Posted by RobL View Post
Let me check...
Ah, that's the upper spring seat - part of the shock upper mount.
The spacer referred to looks exactly like (i'm told) a second lower aluminum spring seat.
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 01-15-2007, 10:39 PM
AlanBDahl:
I have not seen the TSB on the spacer, can you post the link. Are you saying the spacer has to be removed?
Jack B is offline
Old 01-16-2007, 03:08 PM
MemphisReighns's Avatar
OK so i've done some research on the GXP Solstice VS the Honda S2000 (which is what I ran before). And I have reached some interesting conclusions:
First I think the GXPs are relatively softly sprung (175/225 lb/in F/R), especially compared to the MY00 S2000 (218/291) however I think that the stock GXP shocks are better damped than the stock S2000 shocks.
Also, the GXP has a significantly larger front bar than any stock S2000 (33.4 vs 28.4).
What this has lead me to believe is that the GXP, especially when compared to the S2000 is softly sprung but more firmly damped; this is a good reciepe for very secure handling; coupled with the large tires we can run (245/285) and you also have a car that has significantly better mid-turn grip than the S2000 but maybe not as good at tranisient response.
Obvisouly this discussion only applies to Stock Class autoXers, but it is interesting. I think that the car will benefit from adjustable shocks, mostly because I'll want to dial in some rotation; however with the large stock bar, I will most likely not need to do the radical alignments we did on the S2000.
If you can't be a good example, be a terrible warning!
Current Stable:
1998 Toyota FJ62 "Bruce"
2006 VW Mk5 GTI DSG "Ingraine"
2007 Mean GXP, Team Zissou!
MemphisReighns is offline
Old 01-16-2007, 10:47 PM
ULLLOSE's Avatar
Apples and Oranges.... There are a ton a variables. The motion ratio, where are the spring/suspension pick up points on each car? What is the length of the A Arm? Are both swaybars solid or hollow? If they are hollow what is the wall thickness of each? How long is the lever arm on each bar? Where does it attach on each car?
You can not just look at springs, bars and shocks and come up with any kind of conclusion unless they all attach in the same spot and fashion on each car. A car with softer spring rates may actually be stiffer due to the motion ratio of the suspension.
Also keep in mind the the weight of each car, both sprung and unsprung are a factor.
Aside from that a stock class autox car can change the front bar and shocks, so if one is better from the factory or not is not an issue.
2005-2006-2007 SCCA BS Natl Champ
ULLLOSE is offline
Old 01-17-2007, 07:31 AM
I think your missing my point; I know all of that, and I'm not discussing the inherent differences between the suspension designs (which in many ways are very similar). I'm simply comparing what is clearly a difference in philosophy between the design of the S2000 and that of the Solstice.
And you are absolutely right, given my stock class asperations, all of this is mute if one is inherantly better than the other.
Current Stable:
Old 01-17-2007, 07:38 AM
Administrator
Motion ratios on an SLA suspension are pretty straightforward, especially for a coilover.
Someone just measure the distance from the bushing center to the balljoint, then the bushing center to the shock attachment bolt.
Balljoint to bushing center
Shock attach to bushing center
= motion ratio (at least close enough for what we're doing).
I've just been too lazy to do it when I've had the chance.
Old 01-17-2007, 07:41 AM
I will also say this, the suspension designs between the S2000 and the Solstice are surprising similar, except that the Sols suspension peices are significantly larger - especially the lower control arm; i believe this leads to its superior suspension geometry.
Current Stable:
Old 01-28-2007, 08:46 AM
RobL's Avatar
Just to bring this back to topic a little. I was over Joes shop with my son and he got to play in Don Knowles Solstice.
RobL is online now
Old 01-30-2007, 02:47 AM
Temple's Avatar
Actually at this point in time the suspensions would not be identical because of the TSB that allows '06 Z0K owners to remove the spacers in the suspension which would not apply to the GXP at this point. Of course that's assuming that the '06 Z0K FE3 package is the same as the '07 GXP's suspension. Does anyone know if the same spacers come with the GXP and if so whether there is a TSB that allows them to be removed?
I am wondering the same thing. Someone mentioned to me in the past that the GXP comes with spacers and that removing them would lower the car a bit and improve handling. Wonder if this is true...
Temple is offline
Old 01-30-2007, 09:20 AM
I have looked at mine and did not see any spacers.
LatinVenom is offline
Old 01-31-2007, 01:25 PM
Administrator
brentil's Avatar
There are spacers on the car during transportation that are removed once delivered.
brentil is offline
Old 01-31-2007, 01:38 PM
Miles@tirerack's Avatar
Mine weren't, I had to remove them myself. It's a fairly big ordeal, I don't think there is a dealership on the planet who will do it for free.
Miles@tirerack is offline
Old 01-31-2007, 03:14 PM
jimbo's Avatar
