Go Back   Pontiac Solstice Forum > Technical Solstice Discussion > Tires & Wheels
Old 11-08-2006, 05:52 PM   #1 (permalink)
Per Diem Administrator
brentil's Avatar
245/45 x18 for the very budget minded
I decided to look into various cheap tires after the Riken Raptor ZR thread. LV had pointed out the Nexen N3000 before which is also a cheap tire in our stock size. I've found 6 Summer only tires that can be had for under $115 each online. I don't know if any of these tires are good or how they compare to the highly rated Goodyear Eagle F1 GS-D3, Michelin Pilot Sport PS2, or Bridgestone Potenza RE050A Pole Position performance wise, but I can tell you some of these cost half as much as the cheapest of those three. Prices are from various places all easily found on google.
  • Federal - 595 (SS595)
  • GT Radial - CHAMPIRO 328
  • Hankook - Ventus Sport K104
  • Nankang - NS-II
  • Nexen - N3000
  • Riken - Raptor ZR
Save the Kappa!
NASSOA (TM)
Old 11-08-2006, 10:07 PM   #2 (permalink)
brentil's Avatar
Federal - SS-595
http://www.tyretest.com/pkw_sommerre...595/index.html
Ultra High Performance Summer
260 A A
The SS595 is Federal's international ultra-high performance tire, developed for flagship sports cars requiring flat-out per-formance as well as excellent riding comfort. While Federal's latest fundamental tire technology, TTIC, gives you smoother, faster and safer driving, the newly developed M.P.O.(Magnify Performance Optimization) technology also offers the driver a more consistent performance not just when new but through-out the whole life of the federal tire.
595 - Drift Competition
Federal's extremely successful UHP, the former ss595, has been repositioned and renamed simply as the 595. Slight technical changes have been made by FTC to the tire to suit the purposes and take the abuse of drifting competition.
Combat-bred. Performance-driven. For those requiring flat-out performance, no other tire grips like the 595, yet still provides for the basic comforts of everyday driving. Aggressive V-shaped tread and innovative silica compound maximizes level of adhesion, resistance to aquaplaning, and gives your car ultimate control in acceleration, cornering and braking. Unparalleled comfort in its class.
  • Our latest tire technology, TTIC, for smoothness, speed, and safety
  • M.P.O. (Magnified Performance Optimization) technology – for consistent performance throughout the tire's life
  • Three Radius Tread Arc delivers even pressure across the contact area
  • Flange Protector protects expensive rims from potholes and curb damage
  • Steel Sidewall and Belts for optimum performance in all temperatures
  • Opti-Noise Technology for a quiet, comfortable ride
  • Aggressive uni-directional tread pattern enhances high speed stability and traction
  • Unique shoulder block design for predictable handling in different driving conditions
http://www.tyretest.com/pkw_sommerre...328/index.html
280 A A
The champiro hpz tire is The Ultimate Ultra High Performance Tire with Ultra-Low Profile, Gives You Astounding Performance, Exceptional Grip on Wet and Dry Roads and Incredibly Excellent Handling. Developed to Meet the Stringent Needs of the Most Demanding Motorists for Ultra-High Performance Tires, GT Radial Champiro HPZ Has All the Answers to Your Requirements. DRIVING AT DAZZLING SPEED CAN BECOME AMAZINGLY EASY......ONLY WITH CHAMPIRO HPZ.The Solid Centre Rib on the champiro hpz Ensures Good Directional Stability and Fast Steering Response. Superwide, Arrow-shaped Main Grooves The champiro hpz Channels Water Effectively to the outside of the tire, and Drains the Water from the Center of the Tire.
Hankook Ventus Sport K104
http://www.tyretest.com/pkw_sommerre...104/index.html
UTQG=280 AA
A Y-rated, ultra-high performance tire developed with racing tire technology. Triple-radius profile design, innovative tread and Silica compounds provides superior precise control and responsiveness required for performance under extreme driving conditions.
Tread Pattern
An aggressive unidirectional tread pattern with center ribs ensures steering stability and superb handling on the open road.
Main & Lateral Grooves
Two grooves in the tread center and unidirectional lateral grooves deliver excellent drainage to minimize the possibility of hydroplaning.
3R System
The Ventus Sports K104 features a triple-radius profile that maintains maximum grip at top speeds or during sharp turns.
Tire Structure
1. Jointless Bead Wire & High Hardness Bead Filler
Improves high speed stability and provides ride comfort.
Maximizes steering response, high speed stability and durability.
2. Wide, High-Tensile Steel Belts & Jointless Two-Cap Ply
Enhances tread strength for steering response and wear. Improves uniformity for smooth ride and durability.
3. Rim Protector
Provides better protection against outer shock or scratches.
Nankang - NS-II (Taiwan)
http://www.tyretest.com/pkw_sommerre...s_2/index.html
340 A A
Ultra High Performance directional tread design. Superior Handling. Quiet comfortable ride.
NS-II is designed to meet the needs of consumers. High performance of gripping and stability, comfort and quiet.
  • Two center circumferential grooves design can efficiently direct water away and enhance superior wet handling.
  • Computer-designed v-shaped drainage sub-grooves increase resistance to hydroplaning in high speed running on deep water.
  • Two-in-one pitches and variable-width tread design help to reduce pattern noise and promote a quieter comfort ride.
  • Shoulder edge sipes design promotes even and long treadwear.
Nexen - N3000 (Korean)
http://www.tyretest.com/pkw_sommerre...000/index.html
340 AA A
“V” type symmetrical aqua groove designed specially connecting from center to shoulder Part.
Maximization of running performance on the surface in the rain with its perfect water drainage.
Unique and sporty design of “V” type tire for high speed running.
Riken - Raptor ZR
http://www.tyretest.com/pkw_sommerre...tor/index.html
High Performance All-Season
300 AA A
Riken is introducing the Riken Raptor ZR tire, a new line of ultra-high performance (UHP) tires that are initially being introduced for Michelin's Alliance dealers. The new tire combines cutting-edge looks with high-performance design and construction designed to appeal to consumers looking for a high-quality performance tire at an affordable price.
Initially, Riken will be introducing 27 sizes in the Raptor ZR line to the company's Alliance dealers on June 1, 2005 ranging from 16 to 18 inch dimensions (eight 16-inch, twelve 17-inch and seven 18-inch sizes). Following early in July 2005 will be two 20-inch sizes. When fully introduced, the Raptor ZR line will cover 78 percent of the UHP marketplace. The new tire is designed to compete in performance and price with other lower tier UHP tires including Toyo/Nitto, Kumho, Falken, Hankook and Cooper.
"This tire line is designed to provide our dealers with a tire that will deliver the right performance at the right price for the consumer looking to customize and improve the look and performance of their vehicle," said Thom Peebles, brand director Riken Tires. "This is a significant step for Riken as we are introducing the deepest UHP line in the brand's history and we won't stop there. We will continue to build Riken by introducing new sizes and new lines to provide our customers with the product they need to capitalize on the profitable lower price tier of the UHP market".
Riken Raptor ZR Tire Features:
  • - Directional tread design formulated using advance computed-aided design software combined with extensive laboratory and track testing.
  • - W speed rating.
  • - A "waved" center rib to help channel water away from the footprint, while providing additional support, on-center steering feel, responsiveness and overall traction.
  • - Oversized swept-back lateral rib elements designed to maximize grip during cornering.
  • - Specially-designed material and rubber compounds to help the tire maintain its shape and deliver added progressivity feeling to the driver in both high- and low-speed driving situations.
Riken tires are designed to deliver ultra-high performance at an affordable price. Featuring the Riken Raptor ZR ultra-high performance tire, Riken tires are sold at select dealers and locations throughout the United States.
Old 11-09-2006, 04:20 PM   #3 (permalink)
brentil's Avatar
Do any of our members own any of these tires? I'm very interested in your thoughts of them as would a lot of our other members I bet too.
Save the Kappa!
NASSOA (TM)
Old 11-09-2006, 05:32 PM   #4 (permalink)
JustMike's Avatar
Riken - Raptor ZR ... High Performance All-Season ... 300 AA A
I gotta tell you that when the stock tires on my NA Solstice need replacing this will get a serious look. Tread pattern looks much more rain friendly then the RSA ... or is it just me?
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline   Reply With Quote
Old 11-10-2006, 08:48 PM   #5 (permalink)
slowandlow's Avatar
i own the Nankang - NS-II
they are a solid tire with good grip lateral and strait the olny thing is they do break lose and they do it fast with little or no warneing you are getting to the limit of the tire.
tire is a 225/40/18
car is a olds alero with some power mods and air ride
slowandlow is offline   Reply With Quote
Old 11-10-2006, 10:58 PM   #6 (permalink)
VIN2020's Avatar
brentil,
Nice work on collecting the data. I hate these stock all season tires, and have been wondering about these exact same tires.
I hope we get quite a few to weigh in on this, because I'm anxiously waiting to pull the trigger on something good and cheap.
VIN2020 is offline   Reply With Quote
Old 11-12-2006, 09:13 AM   #7 (permalink)
z3404's Avatar
Tire Feedback
I think this is an excellent idea a place where we can get feedback on some of the more affordable tires out there.
Here is a link to a tyre test site that has some info on a few of the tires mentioned here so far.
The Riken Raptor gets the nod for best test but I still want to point out the country of orgin of these tires is Indonesia. Riken is a sub brand of Michelin so that adds some credence to them.
The best bang for the buck right now would be the Dunlop Sport Max at Tire Rack for 124.00 that tire gets rave reviews from just about everyone.
Of the very budget tires I have found quite a few good reviews on the Nexus N 3000 at several different web sites at this point I would most likely try them when its time to retire.
z3404 is offline   Reply With Quote
Old 11-12-2006, 11:11 AM   #8 (permalink)
AustinTashis's Avatar
You can't tell a lot by looking at the tread pattern.
Take a look at the Bridgestone Potenza RE050A Pole Position vs. the Goodyear Eagle F1 GS-D3. Both are Max Performance Summer tires. You can do a detailed comparison online at the Tire Rack Web site.
Both are very highly rated for wet and dry traction and anti-hydroplaning, yet they look nothing like each other. You can find tires that have tread patterns that closely resemble the tread patterns of each of these tires, yet which aren't even in the same league when it comes to performance.
When you think about it, the superficial appearance of a tire's tread pattern is the easiest thing to imitate, so the resemblance is probably not a coincidence, it's just their attempt to make people think the tire will perform similarly to the one they're imitating. Don't fall for it.
AustinTashis is offline   Reply With Quote
Old 11-12-2006, 11:14 AM   #9 (permalink)
tire is a 225/40/18
Does this car have a limited-slip rear end by any chance?
Old 11-12-2006, 05:37 PM   #10 (permalink)
brentil's Avatar
Originally Posted by z3404 View Post
I think this is an excellent idea a place where we can get feedback on some of the more affordable tores out there.
Good idea. I went in and added links to their review pages for each tire.
Save the Kappa!
NASSOA (TM)
Old 11-12-2006, 05:38 PM   #11 (permalink)
slowandlow's Avatar
olds alero 200+whp after mods frount wheel drive. engine 3400 v6 cai headders cat back exhost underdrive pullies
http://www.geocities.com/theirishgon...?1018844984354
Old 11-13-2006, 09:41 PM   #12 (permalink)
VIN2020's Avatar
A friend just put a pair of Riken - Raptor's on his BMW M5 over the weekend. So far he is extremely happy, much better grip than the expensive tires he had. Although he doesnt know about the rain performance yet.
I think this will end up tipping the scales for me towards the Riken
Old 11-14-2006, 05:45 AM   #13 (permalink)
JustMike's Avatar
I be interested to hear about the rain performance
#1922 12/03/05
Dover DE
Old 11-14-2006, 08:51 PM   #14 (permalink)
VIN2020's Avatar
I will let you as soon as we get some rain down here. TX right now is known for the rain.
Old 11-15-2006, 08:07 AM   #15 (permalink)
AztekzRpurty's Avatar
Me three.
I drove my Solstice back from Louisiana a few weeks ago and got caught in a gusher on a louisiana 2 lane. Every puddle was an adventure with the rs-a's. I had a death grip on the steering wheel.
(Also known as Hal 9000)
My Mod Page
