I'm will be on my 3rd summer(when I put them back on next month) w/ KDW's. 1000% better than stock..
After I get back from the Nationals I'll probably be in need of new sneaks, looking for an asymetric performance tire otherwise I'd buy them again.
Ken - cousin from Skyroadster.com
Mean Green Wolverine
'07 Redline Green/Tan/3 pedals/1 CD Monsoon/Spoiler
Ordered 6/6/06 Del. 4/7/07
Just so you can rotate left to right? Why is that important?
2007 Sky RL - Black on Black
Purchased used with 8,500 miles 5/7/08
Wester's Race tune with GMPP Sensors
RMR Style Bar - Silver
i dont know about it being a drift tire. i know a few people that road race and autocross them with good results.
and low tread life is what you get with a good tire. but i have a friend that has autocrossed most weeks last year and did a track day and the direzzas lasted longer than that. maybe not a lot longer, but longer.
2007 solstice gxp:gmpp; turbo upgrade, cai, PAW; intercooler, pipes, z0k; rear sway bar, rear brace. magnaflow, 18x9 ultraleggeras, 275 kumho xs, brake pads, kw v3's w/6k springs, energy suspension bushings, hp tuners, solo high flow cat TEAM FAIL RACING
When you run a lot of camber the inside edges wear out pretty quick with a softer tire compound like the Direzza Star Specs. Having a tire with an asymetrical tread pattern allows you to place the inside edge of the left side tires to the outside edge on the right side and vice versa. Of course it means having them unmounted and remounted but at least it's cheaper than buying a new set of tires.
Location: -- Billy Ocean once said, "Get outta of my dreams, get into my car."
Druid - for what it's worth...my 2 cents
I have 2 sets of Hankook's and we love them (H725 and H727) on our daily drivers. I would have gotten the Ventus for the Sky but got a package deal on new rims with Kumho Ecsta ASX tires instead.
I am impressed with the Kumho's for the $. They are 100x times better than the GY F1's on the Redline/GXP, IMOP. When I was driving sweep last fall at the Dells in the pouring rain doing "catch up speed", these held the corners like nobody's business.
Best of luck on sorting out the options,
-Rob
-Roadie Rob
....__o
._ \<,
(_)/(_)
Biking / Driving Miles
Legs = 63,250 miles
Car = 12,158 miles
"Devil's Delight" 2008 SKY REDLINE
SKY #2 = NEW 8/22/08, Chili Pepper red w/ black leather and a bunch of goodies...
I just put the Hankook ventus on my car so I can't really give a review yet. I can tell you why I chose them though.
1) fairly highly rated dry traction (not quite as good as the direnza)
2) highly rated wet traction (important up here in the PNW)
3) price
4) available in my staggered setup (the BFG KDW wasn't)
5) supposed to be quieter than the Direnza (the roads here are a really rough concrete leading to a lot of road noise)
LiquidPT aka Matt
driving Black Sun
"Maine"-iac : When you run a lot of camber the inside edges wear out pretty quick with a softer tire compound like the Direzza Star Specs. Having a tire with an asymetrical tread pattern allows you to place the inside edge of the left side tires to the outside edge on the right side and vice versa. Of course it means having them unmounted and remounted but at least it's cheaper than buying a new set of tires.
I think you have that backwards.
As I understand it there are two main descriptors for tires: Directional means a tire can only rotate in one direction. Symmetric means that it can be mounted with either side facing out.
1) A non-directional, symmetric tire can be used on any corner of the car, and rotated in any manner desired. It can also be mounted with either side facing out.
2) A directional, symmetric tire can be mounted for use on any corner of the car but, once mounted, can only be rotated fore and aft. To switch sides of the car it must be dismounted and reversed on the wheel.
3) A non-directional asymmetric tire can be used on any corner of the car, and rotated in any manner desired. It must be mounted with a particular side facing out.
4) A directional, asymmetric tire is supplied in LH and RH versions, must be mounted with the proper side out, and can only be rotated fore and aft. Even with dismounting, it cannot be used on the other side of the car.
Please, someone, correct me if I am wrong.
Sky VIN 00252
5-Sp Manual
Midnight Blue
