TPMS Reset on 2008 ARGH!! - Pontiac Solstice Forum
Go Back   Pontiac Solstice Forum > Technical Solstice Discussion > Tires & Wheels
Old 02-13-2010, 01:53 PM   #1 (permalink)
billyharless's Avatar
I just replaced my wheels and tires with a new set from tire rack. They came with TPMS installed. Now I cannot get my DIC to reset/relearn the new TMPS. I have a Sol with the Remote Keyless entry but it has not been working, so I have tried the procedure for cars without a RKE.
Has anyone else had problems getting new TPMS to relearn??
More pictures of my Solstice here: http://www.cardomain.com/ride/2840579
My Solstice Forum Gallery of Pictures
2008 Mysterious Solstice NA. Sand interior. XM/Onstar. Auto trans. Mods: Windrestrictor, painted calipers, KS2 exhaust, GM CAI, Merker Liquid Metal Rims, 15% Window Tinting, Debadged, Norms FIberglass fascia, stubby anntenna, and smoked taillights.
billyharless is offline   Reply With Quote
Old 02-13-2010, 05:00 PM   #2 (permalink)
ROBOWO's Avatar
I haven't been able to get mine reset since I first rotated my tires. I've followed the instructions to the letter with no success either.
2008 Sly 2.4L
Mods: VDI vertical door hinges, GM catback exhaust, CAI, black painted calipers, splash guards, seat back swap, waterfall organizer, custom gauge pod with Dakota Digital oil pressure, voltmeter and temperature gauges, Vector tune, shortened antenna, JPM shifter & diamond stitched center console, Solo Hi flow cat & shorty headers, DDM backbone brace, Probeam, cross bay brace & coil cover, LED footwell lights, wood grain dash, custom cupholders.
ROBOWO is offline   Reply With Quote
Old 02-14-2010, 01:52 PM   #3 (permalink)
typhoon's Avatar
I had the same problem with mine. Take it to the dealer as there is a TSB for this. It will need a software update and then everything will work fine.
From Small Dealer:
There is a possible issue with some early 2008 Solstices, where the TPMS can not be updated by the add/release pressure method in the learn mode.
Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR)
2008 Chevrolet Cobalt, HHR, Malibu
2008 Pontiac G5, G6, Solstice
2008 Saturn AURA, SKY
Condition
Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires.
Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module.
In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode.
Cause
These conditions may be caused by the following:
• The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle.
• The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR.
Correction
Reprogram the RCDLR with an updated software calibration to address both issues listed above.
Once the RCDLR module has been reflashed with the latest software and calibrations, the following may also be necessary:
• Relearn all keyless entry transmitters.
• Reconfigure the tire pressure placards and the tire type.
• Relearn the tire pressure sensors.
Refer to SI for the procedures to relearn transmitters, placard and tire type configuration and tire pressure sensor learn.
2008 GXP 5 speed manual Brazen GMPP upgrade
2008 Malibu LTZ 3.6 6 speed
2008 Cadillac SRX AWD N*
2002 GMC Denali Quadrasteer
2002 Chev Trailblazer
2012 Suzuki Burgman Executive
1965 Bolens tractor. w/new 13hp crate motor
2000 pair of roller blades
2008 Limer backpacking shoes
typhoon is offline   Reply With Quote
Old 02-16-2010, 07:09 PM   #4 (permalink)
When i purchased my 08 GXP in July the key fobs ,door unlock and tire press were not functioning. My local dealer reprogramed them, no problems since.
Hattrick is offline   Reply With Quote
Old 02-27-2010, 04:14 PM   #5 (permalink)
Resoldered my key fob and put a new battery in it. So I re-tried setting my TPMS with no luck again. I guess I am going to have to take it to the dealer.
Old 02-28-2010, 01:01 PM   #6 (permalink)
typhoon's Avatar
Originally Posted by billyharless View Post
Resoldered my key fob .......
Old 02-28-2010, 03:45 PM   #7 (permalink)
Originally Posted by typhoon View Post
Both of my key fob's had bad connections. You can solder the connections to get them working again.
The key fob is needed to reset the TPMS.
Old 03-03-2010, 08:49 AM   #8 (permalink)
Argh!!! Broke down and called the local GM dealer. They are going to charge me $46 to reset the sensors.
Old 03-03-2010, 03:12 PM   #9 (permalink)
typhoon's Avatar
DO NOT let them charge you a penny. It's all covered under your warranty.
Old 03-03-2010, 03:38 PM   #10 (permalink)
These are not the original sensors. They are new sensors that came with my tires and rims.
Old 03-03-2010, 04:05 PM   #11 (permalink)
Canuck Sol's Avatar
The point is rather moot, tire rotation is normal maintenance which needs a reset (there is even a space on the service req for TPMS).
It's a feature I'm glad I don't have. If it was done right there would be two receivers which could triangulate.
How can I be old if I never grew up?
Team Solstice Folding@Home
2007 Solstice GXP - Yeller, Ebony Top, AC, NO spoiler, MSRP - ordered 06/09/15 - delivered 07/04/02 and it's pronounced zed, not zee! ;-)
Mods: Street edition headlights, Windrestrictor, Clearbra, Kitt brake light, chicklets removed, fake chrome turn signals
Canuck Sol is offline   Reply With Quote
Old 03-03-2010, 05:17 PM   #12 (permalink)
Actually it is a very nice feature to have and works well once they are properly set.
Old 03-05-2010, 08:10 AM   #13 (permalink)
UPDATE: I took my car to a Goodyear tire shop in Annapolis. With their "special tool" they were able to "wake up" the sensors and reset them in about 5 minutes. They charged me $25. The GM Dealership was going to charge $45.
If you are buying new rims and tires and have them installed by someone else, ask them to ensure your stock TPMS will fit the new rims first. If you can keep your original TPM sensors then you probably will not have this issue.
Old 03-05-2010, 03:12 PM   #14 (permalink)
typhoon's Avatar
Makes no difference if they are original sensors or not. Read my first post above. You should be able to reset the TPMS with your remote.
Your dealer should have fixed this for nothing.
Old 03-05-2010, 03:19 PM   #15 (permalink)
Negative ghostrider... the TPM's could not be reset with the key fob because they needed to be "woke up" which requires a special tool. They are after market parts so they are not included in the warranty. Anyway, $25 certainly does not make or break me and not worth the hassle of arguing with the dealer about.
