Old 07-21-2008, 06:50 AM
   Wheel size question???
Yamatr3's Avatar
Will a 9.5 18 inch wheel with a 45 offset work on our car with a 275 35 18? Or is 9.0 18 the widest we can go?
Yamatr3 is offline
Old 07-21-2008, 02:37 PM
I do believe the wheel will fit fine, however, please note that the tire size you want to use will be small diameter than stock. Use a 275/40/18 to retain stock diameter.
08 GXP 5 speed Brazen
08 Cadillac SRX V8 AWD (13mpg in town)
02 Chevy Trailblazer
00 Pontiac Grand Prix GTP
96 Suburban
2002 Snapper Zero turn lawn tractor
1988 Trek Antelope mountain bike
2000 Trek R 200 Recumbent Bike
2004 Roller Blades
2006 Nike Gortex running shoes
2007 Limer Backpacking shoes
http://home.earthlink.net/~eroomekim/
typhoon is offline
Old 07-21-2008, 02:56 PM
Deepbluegxp's Avatar
Send a message via Yahoo to Deepbluegxp
You would have to do a front end check for rubbing when turning at the full radius. Even though a 45 offset moves the tire out about a 1/2 inch, it still may rub. I have 42mm offset 18x8s
Team Solstice 2008
Click My MODS link - updated 05 Audust 2008 - Added Side Marker / Turnsignal mod / See my car on cardomain.com
www.NASSOA.org Founding Member #48
Deepbluegxp is offline
Old 07-21-2008, 08:48 PM
Yamatr3's Avatar
Thanks for the reply guys. I am going to run 8's on the front and 9.5's on the back. Reason for that tire size, is because it is the same diameter as I am running now, 25.6".
Yamatr3 is offline
Old 07-22-2008, 05:52 AM
My-Low-Sol's Avatar
You may be surprised to find that those 18x9.5 ET45 wheels may fit in the front too. I ran a 18x9 ET55 wheel up front with a 265/40R18 tire and your proposed rear wheel extends into the wheel well less than my old wheels did by 4mm. Of course those wheels will also extend about 16-17mm further out from the car than my old wheels did too. You'll need to check the outer radius for clearance to the wheel well liner but I think that you'll find no interference problems on the inside of the wheel.
Red Bull Drift Team 2008
Formerly Miles@Tirerack
My-Low-Sol is offline
