Wobble nuts! Anybody using them? - Pontiac Solstice Forum
 3Likes
post #1 of 21 (permalink) Old 01-29-2017, 04:21 PM Thread Starter
stungjoe's Avatar
Wobble nuts AKA PCD variation nuts......
I have a line on a good looking wheel/tire package but the bolt pattern is 112mm and using some centric hub adapters as well. The wheels are HUGE! 18x9.5 using 275/40X18 tires with a 53 offset. he showed me some pics of his Solstice and the tires did not poke out from the fender. I'm just concerned about the use of those wobble nuts. Any stories good or bad??
Joe
FLASHED
2008 Red Line Carbon Flash SE Naked!
stungjoe is offline
post #2 of 21 (permalink) Old 01-30-2017, 11:33 AM
cartmann32's Avatar
Just reading the word 'wobble' makes me shiver
I took my hubs/disks down to a machine shop and they widened my bolt pattern to the correct size....I went 5x114.3
This is the correct and safest way I believe
(running 19x9.5 front and 19x11 rear)
Trax Customs
www.traxcustoms.com
cartmann32 is offline
post #3 of 21 (permalink) Old 01-30-2017, 12:30 PM
AKA SolWhat?
DaveOC's Avatar
If.you are just going to do a static display at a car show, wobble nuts are OK.
If you are planning to drive the car, relying on the car to deliver you safely to your destination, no way would I use wobble nuts.
Read cartmann's comments above, i agree with him!
1st 1K - #741
DaveOC is offline
post #4 of 21 (permalink) Old 01-30-2017, 12:53 PM
vcliment89's Avatar
Sources:
Wheel Separation Accidents - Metallurgy Expert, Mark Bailey, PE
http://www.croberts.com/Automotive-wheel-detachment.htm
If I'm understanding things correctly, here is my synopsis of what these and other articles have said.
Although very informative, I am still not totally sure of my answer yet in regard to wobble nuts/wobble bolts, but feel that I have a better idea now. It seems that the main determining factor for the dangerous situation that people seem to talk about but never specify, is a lack of clamping force to sandwich the rim to the (spacer)/brake and the hub that the wheel studs are attached to. Based on these articles, it's more clear to me how the friction from the sandwiched wheel/(spacer)/brake/hub components are what take the force of accelerating, braking, etc. rather than the lug bolts or lug nuts. This makes sense as the threads on the lug bolts or studs after hard driving would be marred and mangled, but after hard driving they remain in good shape. The lug bolts/nuts only job is to create enough clamping force in a horizontal direction (or the same direction they are screwed in) with the proper factory specified torque they were engineered to work at, in order to clamp the wheel/(spacer)/brake/hub together. I would also assume that they take some of the force when turning as well, but it seems this is less of the issue compared to just coming loose going in a straight line due to improper torquing or failed/compromised lug nuts/bolts/studs.
Based on the articles, it seems the most common times that wheel separation from a car happens due to:
Improper torquing of lug nuts or lug bolts
-Over tightening stretches/stresses the bolts or studs which can cause failure
-Under tightening means there isn't enough friction between the wheel/brake/hub or spacer if also used causing the weight of the car to sit more on the lug bolts or studs causing failure
Running aftermarket lug centric wheels or not using properly sized centering rings on a car designed to be hub centric causing the weight of the car to deform the rim stud/bolt holes which leads to loosening and failure
-MisterJJ, this seems to be more of what you are talking about, but not actually how things work
Surface changes between the wheel/(spacer)/brake/stud due to paint/coating deterioration, corrosion, or otherwise causing a loosening of lug nuts/bolts
These things reiterate the importance of running aftermarket parts that are designed to work in the same way your factory parts were designed to work if you desire to use aftermarket parts. Using hub centric wheels and spacers, and proper centering rings on our cars seems to be very important (of course). Also, ensuring a clean smooth surface between wheel/(spacer)/brake/hub, as well as properly torquing lug nuts/bolts and using high quality components should mean safe operation. Properly torquing wheels and then re-torquing wheels to their proper torque value after installation between 15 and 500 miles should mean that proper clamping force will be achieved and a wheel separation would be very unlikely at that point.
Steelmesh likes this.
'07 Solstice GXP (Angry Beast) / Black - 5 Speed - OnStar - Monsoon 6 Disk
- GSM/GPS Tracker System. BlackVue DR500GW-HD & rear view camera
- GMPP CAI, 3" SOLO Catless & Street Race, Fujita IC Piping, WOT Box
- Sprint Springs
- WERKSracing PS Reservoir Relocation Kit
- ZZP Fuel Injectors
- SS Brake Lines
- EBC RedStuff Pads & R1 Rotors
- Bosch 3 Bar Map Sensors
- DDMWorks Venom & Backbone Brace
Next
- OEM Bluetooth & USB
- Duraflex GT Concept Fenders
- WERKS Valve Springs
vcliment89 is offline
post #5 of 21 (permalink) Old 01-30-2017, 12:57 PM
vcliment89's Avatar
stungjoe I'm the guy selling them. That's part of the reading I did before buying them, as said I spent some time digging on this and yes a lot of people say how dangerous they are. I agree if you don't use them correctly they can be dangerous but the bolts on the wheels are only used to clamp the wheel to the hub, and not to hold the rotation of the wheel. That is why you MUST run the hub centric rings so the wheel does not move around and you torque the wheels to the correct spec.
stungjoe likes this.
- Sprint Springs
- SS Brake Lines
Next
post #6 of 21 (permalink) Old 01-30-2017, 01:18 PM
Sting Ya's Avatar
Sting Ya is offline
post #7 of 21 (permalink) Old 01-30-2017, 04:07 PM
WintR's Avatar
If the only forces were acceleration and braking, I don't see why they wouldn't be more than adequate. But, in Solo II, there is a considerable amount of lateral force applied to the wheels in hard cornering, so I'd be concerned that the floating threads inside the nut don't have the support that a properly fitted nut would have.
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension, wood grain dash, Solo Quiet cat-back exhaust, deleted:Solo high-flow cat
WintR is offline
post #8 of 21 (permalink) Old 01-30-2017, 06:03 PM Thread Starter
stungjoe's Avatar
I guess wobble nuts is a bit of a misnomer and they should actually be called lug nuts with wobble cones or seats. Where a regular nut has a tapered cone to center itself against the wheel's tapered lug hole seat the wobble nut's cone...wobbles allowing it to properly align the cone in the wheel's tapered seat while the stud is not directly centered in the hole. For an old school lug centric wheel (like my ol' Cragars back in the day...you may remember the extra long wheel nuts??) this would be a major no-no! But for today's hub centric wheels it may not be as bad as it sounds.
Here's pic of a wobble nut:
EDIT the pic i had was HUGE so i used the above instead. Original in link form to better illustrate.
http://www.serpentautosport.com/varinuts_edited-1.jpg
You can see how the seat is allowed to move while the nut is tightened
Joe
FLASHED
stungjoe is offline
post #9 of 21 (permalink) Old 01-31-2017, 10:17 AM
Tom White Coupe's Avatar
The nuts (or bolts) clamp the wheel to the hub and control lateral movement. The hub locates/centers the wheel. The studs should not be in shear, only tension to prevent motion by clamping the wheel to the hub. If you don't think so, just torque your rear lug nuts to about 10 ft lbs and make a pass at the drag strip. You might loose a wheel. Be sure to check your studs for cracks before you call me crazy. Wobble nuts with rings will be fine, just check the torque - frequently if you have concerns. Most aftermarket aluminum wheels don't use tapered nuts, just washers and nuts to clamp the wheel to the hub.
Tom White Coupe is offline
post #10 of 21 (permalink) Old 01-31-2017, 04:42 PM
WintR's Avatar
I'd have to see one cut in half, or a dimensioned drawing, before accepting that they are as strong against the increased tension created by hard cornering.
WintR is offline
post #11 of 21 (permalink) Old 02-01-2017, 01:44 PM
They are simply a tapered washer and regular nut that are encased so they will stay together when removed. They only allwo ~ 2mm of offset per nut.
post #12 of 21 (permalink) Old 02-01-2017, 04:36 PM
WintR's Avatar
So, the internal nut floats against a washer that is held by the outer shell. Certainly less strong than a standard lug nut, since the outer shell is either welded or formed around the washer.
WintR is offline
post #13 of 21 (permalink) Old 02-01-2017, 04:57 PM Thread Starter
stungjoe's Avatar
It's more like the "cone" washer floats against the flange made on the nut. The nut threads directly onto the bolt of course while the "cone" washer is allowed to float to allow itself to seat in the tapered portion of the wheel's lug hole. If you click on the link in post #8 and look at the wobble nuts. The cone is positioned so that each nut shows the extremes to which the cone can float. The two outer nuts are a top view showing how the flanged section of the nut still covers all portions of the hole of the coned section. This, to me, illustrates how the cone section is never allowed to tilt in relation to the nut due to the hole in the cone being exposed; i.e. the cone is always held flat against the flange of the nut. The nuts just inside of those shows how the cone is allowed to float around the threaded portion of the nut. The middle nut shows how thick the head or top portion of the cone is.
Joe
FLASHED
stungjoe is offline
post #14 of 21 (permalink) Old 02-02-2017, 04:09 PM
WintR's Avatar
Still, in the photos that show the extreme of motion, it can be seen that the nut has very little material holding it within the overall assembly, and it is clearly less strong than a standard lug nut. Probably more than adequate for 'normal' driving, but autocross is a different set of loads.
WintR is offline
post #15 of 21 (permalink) Old 02-02-2017, 05:11 PM
cartmann32's Avatar
Here....do this.
should cost you anywhere from $200-$400
Trax Customs
www.traxcustoms.com
