Coolant Drain Procedure - Pontiac Solstice Forum
Old 03-19-2012, 05:54 PM   #1 (permalink)
Charlie W's Avatar
My 2007 GXP turned 5 late last November so the coolant needs changed. I've been waiting for better weather to do it myself. I've seen the thread on how to fill the system but nothing on how to drain it. Is there a petcock on the radiator, are there drain plugs in the block? Can anyone give me some help please?
Aggressive, 5-speed Manual.
Mods: Westers Race Tune, K&N Drop In Filter, Dejon SS BOV Spring, JPM Visor Covers, 3M Clear Bra, GM Splash Guards, Shorty Antenna, Silver Painted Calipers W/Red GXP Letters, Red Arrow Decals, JPM Stitched Console, Silver Painted Rotors, Mirror Polished Stainless Engine Cover, Fuse Box Cover and Visor Mirrors, DIY Tunnel Brace, Dual Horns, DDM Pro-Beam.
Charlie W is offline   Reply With Quote
Old 03-19-2012, 06:03 PM   #2 (permalink)
shabby's Avatar
Theres one on the rad at the passenger side and one at the bottom of the water pump.
Old 03-20-2012, 06:21 PM   #3 (permalink)
Charlie W's Avatar
Thanks shabby thats what I needed to know.
Old 04-01-2012, 08:25 PM   #4 (permalink)
SBUTCHER2's Avatar
The drain release on the passenger side is real easy to get at. It is a white plastice valve. most fluid drain pans will slide right under the radiator.
Steve Sol
2008 Solstice GXP, Cool.
Hp Tune; GMPP Turbo Upgrade Kit, GM Perfomance Brake Reservior, ZOK Anti-Sway Bars; DDMWorks Backbone Brace, LV Front Brace and Pro-Beam; MagnaFlow Performmance Exhaust; Performance AutoWerks High Flow Catayltic Converter, Street Perfomance InterCooler; DeJon Complete IC Piping Kit and Lower Intake Pipe; K & N Filter; Norm's Front Splitter; Extra Dark Tinted Windows. Lets not forget a heavy foot..........
SBUTCHER2 is offline   Reply With Quote
Old 04-02-2012, 05:25 AM   #5 (permalink)
timlange3's Avatar
Charlie, let me know how you do, I had my coolant flushed by the dealer on my 2007 GXP in January. Now my temp readout fluctuates between 195 and 207 where is use to always be 198-199.
Tim
WanderingSol
timlange3 is offline   Reply With Quote
Old 04-02-2012, 10:19 AM   #6 (permalink)
Tim-
If your temp is sporadic, you probably have an air pocket. There is very detailed info on that on here as it is not simple to fill the Sol and not allow air into system. It is also tedious to get air out. Something like driving one tire onto a 2x6 or something. If your temp is consistently higher, then the new coolant is not as good as previous coolant which would mean the mixture is different.
09 G8GT, Stryker, sport/prem
07 GXP, Mean, manual
03 Excursion Limited, V10, 2WD and 37s
94 Bronco XLT, 5.8L, very rusty and 35s
juspimpin is offline   Reply With Quote
Old 04-03-2012, 07:20 AM   #7 (permalink)
timlange3's Avatar
Yes, that was my first thought and I did the bleed process documented on the forum. I got fluid coming out of the line that connects to the top front of the engine, when I squeeze the large hose, it will blast out into the reservoir tank. This process lowered the fluid level in the tank by 1/4" inch. So now instead of the temps fluctuating from 190 to 220, they just go from 195-207. I'll try the bleed process again and see if I get anymore air out of it.
Tim.
WanderingSol
