Engine Temperment during ECU relearn - Pontiac Solstice Forum
Wheel & Tire Center
Register Home Forum Gallery Owner Registry Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 04-26-2007, 11:02 PM   #1 (permalink)
MeanSol's Avatar
For those of you out there that have had to clear your ECU of codes through battery disconnects.. How does your car behave during relearn?
After you reattach everything do you start it up right away, or wait for the ECU to cycle (when the flashing climate control lights are done)?
Does it run rough or smooth afterwards?
Do you start it and go, or shut it off... wait for the ECU to shut off, then start again before driving?
Is there a standard method?
After resetting my ECU over 15 times now, sometimes it runs smooth on initial startup, other times like it is going to come apart, I am still going into limp mode. Now it is consistantly within 10 miles of home, after about my 4th WOT pull to 60mph.
Tomorrow I am just going to reset the ECU and leave everything else to see if it stays in limp mode. The MAF has been cleaned 2 more times after installing the AEM dryflow filter (thank you Werks) and I am still "limping" so unless the MAF is dead, I do not think that is the problem anymore.
I am starting to feel like I am
MeanSol
Team Solstice
MEAN GXP with the works, minus smoker, pedals, XM, Big Brother, and Onions
Current AAT topless outing record -10 degrees F at an average speed of 70mph for a total of 61 miles!
MeanSol is offline   Reply With Quote Quick reply to this message
Old 04-26-2007, 11:25 PM   #2 (permalink)
mikep77's Avatar
MeanSol
I've done it about 5 times, and when I start it, it's always fine. I never start it immediately afterwards though. It's usually about 15 mins of cleanup, then I start and go. It always runs smooth for me. It's not as responsive, but that's it. If the MAF were dead you'd get a code and a cel. Have you tried putting the old intake back on, to see if it changes anything? If it's still in limp mode after the stock one is back on, you might as well take it back to the dealer. When I took mine in, I just said that the check engine was on. I didn't feel the need to mention the CAI.
Solstice #1 - 2007 Solstice GXP 12/06 - 10/09 (Sold)
Solstice #2 - 2009 Solstice GXP Coupe 10/09
License Plate - CHGO SOL
Mod List:
DDM - Aeroforce Gauges, Pro Beam, Backbone, Pipes, Coil Cover
JPM - Console/Visor Covers, Doorpads, Handle, Loops
Solo - Solo Mach Shorty
Hahn - Intercooler
Werks - Polished Turbo Cover
GM - USB Radio, GMPP Tune & Intake, GXP Z0K Sways
Other - Kuda Phone & Ram Laptop Mount, Backup Cam
mikep77 is offline   Reply With Quote Quick reply to this message
Insurance
Please select your insurance company (Optional)
Powered by vBulletin®. Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
