Originally Posted by
shabby
The gxp doesnt have a speed density system, it still uses a maf just like the base solstice. It does have a map sensor, but i doubt it uses it to calculate air mass like a speed density system normally does.
You my friend are 100% correct!
I saw a sensor on the intake and i assumed it was a temp sensor only because i saw a map sensor in the manifold and a temp sensor on the cold side pipe. I then noticed after reading your reply that there are 5 wires going to that sensor!
SOOOOO i took the sensor off and sure enough it was a large ginormious sensor which is a MAF.
The reason the car does nto stumble is because it has a combination of both which is good. MAP for the world.
