Old 03-19-2007, 08:29 PM
Supporting Tuner
Exhaust Depot's Avatar
Originally Posted by vtecnitian View Post
so what your saying that our cars are speed density,but ive asked this question in other forums aka skyforums and your the first person to day that they do not have a maf .and i know most gm's use a maf so just trying to verify because if it is a speed density ill be making myself some pipes with a bov i have a mandrel bender should be easy for me
The N/A has a MAF, the GXP has a MAP. I know 100% that the GXP is map cause thats the first thing i looked for prior to installing a bov.
I heard the N/A is MAF i think from this thread where someo ne turboed there N/A and had stumbling problems when it would vent. That = N/A.
Exhaust Depot is offline
Old 03-19-2007, 09:30 PM
shabby's Avatar
The gxp doesnt have a speed density system, it still uses a maf just like the base solstice. It does have a map sensor, but i doubt it uses it to calculate air mass like a speed density system normally does.
shabby is offline
Old 03-20-2007, 12:57 AM
Supporting Tuner
You my friend are 100% correct!
I saw a sensor on the intake and i assumed it was a temp sensor only because i saw a map sensor in the manifold and a temp sensor on the cold side pipe. I then noticed after reading your reply that there are 5 wires going to that sensor!
SOOOOO i took the sensor off and sure enough it was a large ginormious sensor which is a MAF.
The reason the car does nto stumble is because it has a combination of both which is good. MAP for the world.
