How do you reset the ECU? - Pontiac Solstice Forum
Old 02-14-2008, 03:32 PM   #1 (permalink)
Midas360's Avatar
What is the recommended way to reset the ECU?
Also, I've done the wastegate mod and was wondering if the ECU needs to be resetted?
I've read that you can disconnect the negative on the battery for 30 mins and this will reset the ECU.
Thanks,
Midas
Midas360 is offline   Reply With Quote
Old 02-14-2008, 03:40 PM   #2 (permalink)
JustMike's Avatar
That does work. There are also two fuses that can be pulled. Advantage of the fuses is that the radio does not lose any presets.
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Friend me on FB
JustMike
Pontiac builds excitement...
Founding Member - Northeast
JustMike is offline   Reply With Quote
Old 02-14-2008, 03:43 PM   #3 (permalink)
lil goat's Avatar
You can also disconnect the cables inside the driver side fender for 30 minutes (no radio reset), no you don't need to disconnect for the wastgate mod.
Wester's Garage tune
RMR Style Bar.
HKS Coilovers
JL Audio 10" sub
Old 02-25-2008, 08:48 PM   #4 (permalink)
Common...you say two fuses...yet you do not tell us which ones?
imaj is offline   Reply With Quote
Old 02-26-2008, 05:19 AM   #5 (permalink)
JustMike's Avatar
Cause I had to search for it just like you could have? ...
Originally Posted by db49erfan1 View Post
42 and 43 for the ECM, per owners manual..
Removing the battery cable may wipe saved info throughout the vehicle..
Pulling the proper 2 fuses only affects the ECM..
#1922 12/03/05
Dover DE
Friend me on FB
JustMike
Old 02-27-2008, 07:33 PM   #6 (permalink)
Ahh....so you are one of those types...
Well, in my defense...you lead me and I am sure others to believe that you knew where they were.
Old 02-27-2008, 07:51 PM   #7 (permalink)
JustMike's Avatar
As apposed to the type that expects everything to be handed to them?
And maybe I just posted that as an example of how easy it was to actually find the information right here on the forum or heaven forbid the actual owners manual?
Any way hope you found the information useful.
#1922 12/03/05
Dover DE
Friend me on FB
JustMike
Old 02-27-2008, 08:25 PM   #8 (permalink)
Dark Tech's Avatar
Refering to a black rectangular box with cables coming out of it on top of a aluminum part with cooling fins that is in the fender well. That is your ECU.
Dark Tech's mods
Dark Tech is offline   Reply With Quote
Old 02-27-2008, 08:29 PM   #9 (permalink)
spiky3480's Avatar
Do they have to be pulled for a specific amount of time, or just pull out and put back in (that didn't sound good) ?
SOLO Performance
goingsolo2@hotmail.com
516-655-9002
2007 Mysterious GXP
Exhaust Sound Clips
Old 02-27-2008, 08:42 PM   #10 (permalink)
zzzybil's Avatar
spoon feed a picture
would yuh mind spoon feeding a picture ?...........
.. geezzzz how bout a video.............
read the manual >>
there's a book ???.........
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
gxp exhaust /magna flo - integrated dumptube
hi flo cat
HPTUNING -
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
SPEC 2+ UNsprung
YEAH I DID THAT !
Old 02-27-2008, 09:07 PM   #11 (permalink)
Dark Tech's Avatar
The reason why you unplug the ECU for 30 minutes is because there are capacitors inside of the ECU. THe capacitors have to discharge in order for the ECU to erase the driving habits that you have created. Your vehicle will still function properly when you plug the ECU back in but, "you will make new driving habits for the car without driving it soft like we all should of been doing in the first 500 miles." Or you can get a HPtuner and don't even have to unplug anything.
A dashhawk has a feature to reset fuel trims. You could also do it that way.
Dark Tech's mods
Old 02-28-2008, 02:16 PM   #12 (permalink)
I did find the info. very informative! Thank you!
YOu know that first sentence is funny. Since I am an only child...I have heard that a lot.
Old 02-28-2008, 04:19 PM   #13 (permalink)
JustMike's Avatar
As the oldest of three brothers I used to say it a lot ....
#1922 12/03/05
Dover DE
Friend me on FB
JustMike
Old 08-12-2010, 10:04 AM   #14 (permalink)
beecee's Avatar
So if I pull those fuses for 30 minutes or more will it reset it even though I have the Gmroadster tune? I'm getting horrible knocking since I got it and have it at the shop right now getting serviced and maybe having the spark plugs replaced. My mechanic said I shouldn't have to replace the spark plugs at 55k miles since the manual says replace them at 100k.
I just want to get it off my car since it's not working out.
I've got a 2008 GXP.
2008 Mysterious GXP (MoMo)
My cardomain page
VIN 100541 - Drove it home 7/13/07. As of today; 3/8/13, 76,000 Miles
Daily driver.
I'm at WalMart riding the ponies, bring quarters!
beecee is offline   Reply With Quote
Old 08-12-2010, 10:39 AM   #15 (permalink)
MarkRat's Avatar
Beecee,
Pulling power to the ECM will not erase installed tunes.
Mark
MarkRat is offline   Reply With Quote
