Old 10-27-2009, 11:58 PM   #1 (permalink)
1 LIL NDN's Avatar
leaky top
I came out from work today and had a puddle in my shifter Boot .It had been raining all day .Has anybody else had this problem? I unhooked it and rite at the middle it was aLL WET. Could the catch have been loose .top was not down sense Beginning of OCT. at the MM6 in MD.
1 LIL NDN (Go Naked)
1 LIL NDN is offline   Reply With Quote
Old 10-28-2009, 12:02 AM   #2 (permalink)
IBDRINKEN's Avatar
i had the same problem with the leaking and the top ripping at the buttress where it snaps down. Since then it has been replaced 3 different times and all of the seals have been replaced as well.
13.5@101.90
2.5" Stubby Black Antenna
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
DDM Probeam
DDM Race Backbone( Not Installed)
DDM Black Coilcover
JPM Center Console
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
IBDRINKEN is offline   Reply With Quote
Old 10-28-2009, 05:28 AM   #3 (permalink)
Venice's Avatar
There is a TBS #06-08-67-016A This TSB covers leaks at the shifter Boot area.
The fix is to Apply clear silicone sealer to the opening at the seam to smooth out the transition between the convertible top sections.
The TSB give you pictire of the seam.
Venice is offline   Reply With Quote
Old 10-28-2009, 06:28 AM   #4 (permalink)
1 LIL NDN's Avatar
Venice how do I find the TBS.never been there B4
Old 10-28-2009, 06:30 AM   #5 (permalink)
1 LIL NDN's Avatar
IBDRINKIN Hows your job working Out .You able to keep your Car?
Old 10-28-2009, 06:31 AM   #6 (permalink)
IBDRINKEN's Avatar
that was also tried on mine but didnt work
13.5@101.90
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
DDM Probeam
DDM Black Coilcover
JPM Center Console
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
Old 10-28-2009, 06:32 AM   #7 (permalink)
IBDRINKEN's Avatar
yes i still have both thank god
13.5@101.90
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
DDM Probeam
DDM Black Coilcover
JPM Center Console
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
Old 10-28-2009, 09:48 AM   #8 (permalink)
1 LIL NDN's Avatar
OK I checked this morning and it was DRY so maybe it was not connected tight or something on seal.Last night it rained Quite hard and steady for a few hours.
Old 10-28-2009, 10:43 AM   #9 (permalink)
Small Dealer's Avatar
This may be the situation and fix Venice talked about:
Subject: Water Leak Down "A" Pillar or Drips from Roof Header onto Shifter (Apply Sealer to Convertible Top Seam)
Condition
Some customers may comment on a water leak down the "A" pillar where the front top weatherstrip meets the windshield weatherstrip, or drips from the roof header onto the shifter.
Cause
This condition may be caused by the transition at the convertible top seams being too big for the seal to overcome.
Correction
INFORMATION POSTED ON SITE
