Old 06-26-2008, 12:08 AM
   Magnaflow 16645 catback and Kappsphere Rebar
blueman's Avatar
Has anyone installed a Magna flow 16645 catback with a Kappasphere ReBar? I already have the ReBar installed. Like it alot! I was considering the Magnaflow catback and then realized that there could be a fit issue between the two. Anyone out there have any experience with this? Thanks in advance for the replies
blueman is offline
Old 06-26-2008, 04:08 AM
Deepbluegxp's Avatar
Send a message via Yahoo to Deepbluegxp
The bar doesn't work with the Magnaflow
Team Solstice 2008
Click My MODS link - updated 05 Audust 2008 - Added Side Marker / Turnsignal mod / See my car on cardomain.com
www.NASSOA.org Founding Member #48
Deepbluegxp is offline
Old 06-26-2008, 01:01 PM
anorth45503's Avatar
does the solo?
anorth45503 is offline
Old 06-26-2008, 01:29 PM
The Kappe bar doesn't work with many exhausts, if you want a brace that works with any, get the DDM brace
Team Solstice 2008
Old 06-26-2008, 01:44 PM
Hi, new to forum, reluctant to ask stupid questions. Have a GXP for about a month; loving it; anxious to try some of the mods you guys talk about. Finally figured out how to debadge and doing that.
Here goes: what does the Kappasphere/DDM bar/brace stiffen? What is its a purpose?
Thanks, Rallyracer
rallyracer is offline
Old 06-26-2008, 02:11 PM
At the repair shop :(
MSG_McKee's Avatar
The DDM was the only one I could install with my Magnaflow.
For information on the product just go to DDM's site (in the Supporting Vendors section).
2007 Aggressive GXP (Manual) loaded minus On* and Smoker's Pkg (Born 11/10/2006 and picked up on 11/22/2006)
Current sMiles: 21,111
Click Here To See My Mod Page
TEAM RED BULL & VODKA 2008
MSG_McKee is offline
Old 06-26-2008, 02:16 PM
Thanks, Rallyracer
Once you start increasing your horse power with a tune, wide open throttle will flex the car, the brace helps control that.
Team Solstice 2008
Old 07-02-2008, 07:26 AM
JewJenk's Avatar
Send a message via AIM to JewJenk
Have no problems with the magnaflow catback and the rebar. 2006 N/A
Don't get mad, get even....
JewJenk is offline
Old 07-02-2008, 11:31 AM
reBar didn't work with the GXP magnaflow, Cheers bought it.
Team Solstice 2008
Old 07-02-2008, 12:21 PM
spiky3480's Avatar
The reBar also does not work with the new stacked SOLO exhaust. I have to check the fitment of the DDM brace.
TEAM SOLSTICE 2008
ONCE YOU GO SOLO, YOU NEVER GO BACK
2007 Mysterious GXP- "Intruder"
Member of LISSC
Exhaust System Sound Clips/Videos- N/A and GXP Models
SOLO Performance Exhaust Sound Clips
Spiky3480 Modification Page
Mods: 70
Updated 8/13/08
spiky3480 is offline
Old 07-12-2008, 02:31 PM
blueman's Avatar
Just a update. The Kappashere ReBar will work with the Magnaflow exhaust on a GXP if you want to do a little slicing and dicing, I trimmed approxmately 3/8" out the drivers side web on the ReBar . I first trial fitted it on the car and marked the interference areas with a Sharpie. Then I used a hacksaw and die grinder to remove the offending material. Bolted it back up and took it for a test drive and everything worked fine. No squeaks or grinding noises. Checked the tailpipe and could find no evidence of any rubbing. I'm happy, hated to loose my ReBar when I added the Magnaflow!
blueman is offline
Old 07-12-2008, 05:31 PM
rtrumps's Avatar
Maganaflow and Rebar work for me.
Mysterious, Convenience Pkg, Premium Pkg (Ebony Leather), Power Pkg, Floor Mats, AC, Limited Slip, Polished Aluminum Wheels, Monsoon Speakers, and 6-Disc CD Changer w/MP3 Player.
139 of 1000
http://www.rtrumps.com/
Upgrades:
Tinted Windows
Kappa CAI
Clear Image Shorty Header
Clear Image High-Flow Cat
Magnaflow Catback
GXP Black grill
Kappa reBar
Gentex GENK42 Autodimming Mirror w/ Homelink
2.4L Big-Bore Throttle Body
ECM Flash
rtrumps is offline
