Has anyone installed a Magna flow 16645 catback with a Kappasphere ReBar? I already have the ReBar installed. Like it alot! I was considering the Magnaflow catback and then realized that there could be a fit issue between the two. Anyone out there have any experience with this? Thanks in advance for the replies
Hi, new to forum, reluctant to ask stupid questions. Have a GXP for about a month; loving it; anxious to try some of the mods you guys talk about. Finally figured out how to debadge and doing that.
Here goes: what does the Kappasphere/DDM bar/brace stiffen? What is its a purpose?
Thanks, Rallyracer
Thanks, Rallyracer
Once you start increasing your horse power with a tune, wide open throttle will flex the car, the brace helps control that.
Just a update. The Kappashere ReBar will work with the Magnaflow exhaust on a GXP if you want to do a little slicing and dicing, I trimmed approxmately 3/8" out the drivers side web on the ReBar . I first trial fitted it on the car and marked the interference areas with a Sharpie. Then I used a hacksaw and die grinder to remove the offending material. Bolted it back up and took it for a test drive and everything worked fine. No squeaks or grinding noises. Checked the tailpipe and could find no evidence of any rubbing. I'm happy, hated to loose my ReBar when I added the Magnaflow!
