Misfire (though no CEL) issues, problem or paranoia
So I have a 2007 GXP and have been experiencing misfires, primarily at idle, though at cruise as well, and I'm trying to determine if there is a real problem here.
I've had a dashhawk for about 6 months, and I notice that when I come to a stop light for example, I may see the "Total Misfires" PID hit up to 40+ (about 1 MF per sec) in cylinder 4...though I would say the average is about 10-16 over a 30-60sec period. The car does physically shudder when this is going on but is fine once I start moving.
If I'm cruising on the highway, I will occasionally see 2-4 TMF (total misfires) popup on the dashhawk from time to time. Again Cylinder 4 is the primary culprit, with the occasional blip from the others.
Now for some notes.
1) I do have the updated GM plugs, I swapped these out few months ago, did not effect the problem at hand.
2) At the time I changed the plugs, I also swapped the coil packs around, again no effect.
3) I only run 93 Octane in the car
4) Happens with both the stock ECU and tuned (pcm4less) ECU. Was occurring well before the tune.
5) I have never thrown a CEL or code for misfires.
6) Checked the grounds, from what I can tell they are ok.
7) Again, primarily only at idle or coasting
I've been to the dealer about 3 times for this over the last year or so. Everytime I'm told that this is normal for a turboed car and not to worry about it. I have a hard time buying into that, but the car does seem to run fine other than this so maybe I'm paranoid.
Since this is still going on, I figured I would ask what do you guys recommend or think of this?
I'm going to pull the plugs again this weekend just to have a peek, but since I've already changed them, I'm thinking that if this is a concern, it would have to be an injector...which I'm not eager to replace in my garage. Should I just take a picture of the daskhawk readout the next time I see a mess of misfires or forget about it until I see a CEL?
2007 GXP
PCM4Less Tune
Dejon IC Pipes & CAI
