Old 09-30-2009, 09:00 PM   #1 (permalink)
eco
p0101
Okay so I have been able to duplicate the p0101 code mutiple times now, unlike the dealership. So i checked out the other posts with this fault and everyone was saying that thier oiled filters were causing the maf sensor to get oiled up and fouled, I have been monitoring my ltfts and they are at -20% and I have seen them as low as -25% which is rediculous. I took the maf sensor out and cleaned it with electrical parts cleaner and let it dry for over an hour, ltfts still going past -20% and still going into limp mode. I have a K and N drop in filter and I guess that it caused the oily film, I have had it in for 20k miles and it is just now giving me issues. Should I replace the maf sensor or look elsewhere. Also I was looking at the rear O2 sensor at the resistance its always at 0 and the front is at 900 until it warms up and goes to close loop and then it changes to 300 ohms, but the rear never changes from 0 and only goes into closed loop for a couple of seconds and then jumps right back to open. I appreciate any help. Also today I got a p2178 for rich at cruise or accel on bank 1. Any help is appreciated.
eco is offline   Reply With Quote
Old 09-30-2009, 10:09 PM   #2 (permalink)
GS Stage 1's Avatar
You may find some helpful information on this thread that I started when the P0101 kept coming up on my car:
GMPP Tune and P0101 code.
Old 10-01-2009, 05:49 AM   #3 (permalink)
SHiNY's Avatar
Send a message via AIM to SHiNY Send a message via Yahoo to SHiNY
This information was very helpful to me when I had this exact problem about 2 weeks ago. First the dealership thought it was a loose clamp, then it threw the same code again a day later so they replaced the sensor. Has been working perfectly since.
2008 Saturn Sky Redline - Manual
Silver pearl w/ red/black interior
Originally Posted by CHILISKY View Post
... will be staying long enough to shoot people as they leave.
SHiNY is offline   Reply With Quote
Old 10-01-2009, 08:09 AM   #4 (permalink)
eco
Ok, thanks. I have checked the clamps on the throttle body. the rear of the throttle body hose and also on the hard pipe were starting to slide so I repositioned them and tightened them back up. Still had issues. I think I will try and replace the maf sensor and if that doesnt work, I'm going to check out the intercooler and see if that is balooning like a couple people have had happened to them. Thanks for the help guys. I really appreciate it.
Old 10-02-2009, 02:56 PM   #5 (permalink)
eco
Alright so we figured it out. The hose that attatches to the throttle body had apparently been installed wrong from the factory, ie it wasnt pushed all the way up properly, and once tightened over time had worn a groove on the inside of the hose and had caused a leak. So the tech which was very helpful, unlike the last guy that worked on the car ordered a new one for me, but they are on back order. so hopefully it wont be too long. Thanks for all your advice and help.
Old 10-02-2009, 03:56 PM   #6 (permalink)
SHiNY's Avatar
Glad you were able to figure it out. Hopefully your parts come in soon!
Old 10-02-2009, 04:50 PM   #7 (permalink)
eco
lol. I think I'm just going to order charge pipes and an intake from dejon since it comes with a new throttle body elbow whidch will fix my problem and I want them anyways lol. Of course I'll get the upgraded silicone couplers and t-bolt clamps
Old 10-03-2009, 09:28 AM   #8 (permalink)
Mac
Mac's Avatar
Tightening wont work to long once they give , get a few T clamps and the issue wont. If they replace them with stock it will stripe out again. One of the vendors here i thought i read that sells the set for 25$ that is a good seal and they give the sizes needed as well
Mac is offline   Reply With Quote
Old 10-03-2009, 10:56 AM   #9 (permalink)
GS Stage 1's Avatar
This is EXACTLY the way mine looked when we discovered it. There was a very discernible wear pattern on the inside of the hose, where the lip of the intake had been sitting to high in the hose. The clamp was actually positioned on the edge of the lip. The hose was hanging down on the engine side, so when looking at it, you could not tell that the back side was slid down. I posted about it on the P0101 thread, but I have been kicking myself ever since. I should have taken a picture of the wear pattern on the inside of the hose, so folks could see what to look for.
Old 10-04-2009, 12:19 AM   #10 (permalink)
eco
I'm ordering the dejon chargepipes ad intakes tomorrow with the upgraded couplings and tbolt clamps no more boost leaks for me and hopefully some gains in power. Unfortunately it won't be in time to fix my car. Import face off is tomorrow in my home town and I was hoping to run some 12s to shut some people up, but there is always another time
Old 10-04-2009, 05:56 AM   #11 (permalink)
I1ULUZ's Avatar
What all have you done to be able to hope for a 12 second pass? What was your best pass before now?
Currently in the garage:
2007 Corvette A6 11.74@120
2009 Touareg TDI V6
Use to be in the garage:
I1ULUZ is offline   Reply With Quote
Old 10-05-2009, 07:52 AM   #12 (permalink)
eco
I have a tune and full solo exhaust with a catless downpipe. On bald factory tires and track temps in the mid 120's I ran consistent 13.1's with a 1.9 60 ft at 108 mph. I blew the tires off through second. I have 275's in the rear now that dead hook in second and on a cold night with my trap speed I know it will go in the 12's. If I dead hook in second I see no problem cutting a 1.8 and colder temps will give me a higher trap speed.
Old 10-05-2009, 08:20 AM   #13 (permalink)
I1ULUZ's Avatar
Who's tune? Name of the track interested in looking at the track conditions when you were running.
2009 Touareg TDI V6
Old 10-05-2009, 08:29 AM   #14 (permalink)
eco
I have the pcm4less tune. I have ran 13.1s with just a tune at No Problem raceway in Donaldsonville Louisiana. The 13.1 in 120 degree weather was at Montgomery raceway in Montgomery, Al.
