P0234 Boost over pressure - Pontiac Solstice Forum
Old 02-04-2013, 02:05 PM   #1 (permalink)
I have a triple whammy going on and could use some help. Need to know what would cause all 3 at one time.
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
Already changed the gas cap. Weird thing is when this happens I lose all boost, no power at all (kinda like limp mode but doesn't show any limp mode lights) but if I turn off the car and restart, it resets and I have all power back. Until I accelerate again.
I'm baaaaaaack!
jrsno1fan is offline   Reply With Quote
Old 02-04-2013, 02:52 PM   #2 (permalink)
Dave@ddmworks's Avatar
With the P0455 code I would check your EVAP solenoid - here is a quick video how to:
Get that taken care of first, the others might require a tweak of your tune to remedy. However, I would also pull the MAP sensor on the drivers side charge tube and the MAF located on the intake and clean it with MAF cleaner and re-install.
Hope that helps,
Dave
Dave Michel
DDMWorks
Sales - 864-438-4949
Tech Support - 864-907-6004
WWW.DDMworks.com
Dave@DDMWorks.com
Dave@ddmworks is offline   Reply With Quote
Old 02-04-2013, 02:52 PM   #3 (permalink)
glake89's Avatar
I think your problem is here, from the SM-
Diagnostic Aids
• A restriction in the MAP sensor port will cause the sensor to be sluggish or unresponsive.
• The intercooler is connected to the turbocharger and to the throttle body by flexible ductwork that requires the use of special high torque fastening clamps. Verify that they are properly connected and tightened.
• The BARO sensor is integrated within the ECM, and it has a port on the housing that allows it to sense the ambient pressure. A buildup of contamination at this opening may hinder the operation of the BARO sensor.
• A restriction that exists in the exhaust system will hinder the performance of the engine and may cause a DTC P0106 to set. Refer to Restricted Exhaust .
This is for 0106. 234 and 455 both have relationship to MAP sensor leading me to suspect it.
been fixin' cars for 71 years
Some of what I know is from experience, some from listening or reading- most of it, I just make up
glake89 is offline   Reply With Quote
Old 02-04-2013, 02:53 PM   #4 (permalink)
Check for leaks at the turbo hoses, also the solenoid below the turbo, look at your MAF make sure is nice and clean.
Also Dave suggestion is also a must.
Old 02-04-2013, 08:00 PM   #5 (permalink)
Thanks all and Dave. I went and bought the solenoid tonight, I'll get it changed tomorrow and see what happens. Thanks for your insight.
I'm baaaaaaack!
Old 02-04-2013, 09:03 PM   #6 (permalink)
Sly Bob's Avatar
jrsno1fan. you tested the solenoid and found it to be bad?
Delivered on May 27, 2008
Sly Bob is online now   Reply With Quote
Old 02-04-2013, 09:31 PM   #7 (permalink)
No I don't have any way to test it, for $21 I figure I'll just change it and see.
I'm baaaaaaack!
Old 02-05-2013, 12:12 AM   #8 (permalink)
llllfly's Avatar
If you can blow air through it . It is bad.
Test kit lips.
Your are correct I put the new one on and
the old one as a spare in my emergency kit .
LLLFLY
08 PW SKY R/L 5-spd,The Wolf
Best of Show in Old Bridge,N.J.
Winner Goodyear Bimp flight 2010 NASSM
Winner best interior 2012 NASSM
DDMWorks:,WindRestrictor
llllfly is offline   Reply With Quote
Old 02-05-2013, 12:12 AM   #9 (permalink)
llllfly's Avatar
Test kit lips.
LLLFLY
Old 02-05-2013, 05:17 PM   #10 (permalink)
Thanks for all of the input. I got the EVAP solenoid changed and didn't have any trouble "hard" driving home 50 miles. But also figured out that I need a new fuel filler insert, the gas cap is not staying tight. Ordered from the dealership $6.
I'm baaaaaaack!
