Old 05-11-2008, 11:29 AM
   Puff of White smoke???????
NightwingII's Avatar
A little while back passing a transport I pushed the GXP to around full throttle. I noticed in the rear view mirror a puff of white smoke. Now mind you it could have been dust but there was a bit a a very very small stutter in the gas petal as well.
Suggestions?
NightwingII is offline
Old 05-11-2008, 11:31 AM
silversolstice's Avatar
white is usually coolant. I doubt you have any coolant in your cylinders, was the car cold when you got on it?
Mileage as of July 9 12002 miles
silversolstice is offline
Old 05-11-2008, 05:55 PM
I sometimes notice some white smoke from the rear view of mine as well. Only a wisp and only at WOT.
It really shows up if the sun is shining from behind the car.
I believe that I have noticed the WOT smoke since the first time or two that I got on it.
No oil or coolant is getting gone at 5K miles, and the performance is super. So I believe that it is inconsequential.
I suspect that it has something to do with turbo charging and the large amount of fuel that must be getting injected at WOT.
"Where there is smoke there is fire"
So if there is a lot of fire there may be some smoke?
Good luck.
Rickey.
xmitterengineer is offline
Old 05-11-2008, 06:00 PM
JustMike's Avatar
Turbo Poof ... totally normal ... nice side effect too ... POOF your gone!
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline
Old 05-16-2008, 10:43 AM
Critterman's Avatar
white = excess fuel totally burnt
black = excess fuel unburnt
grey = excess fuel burnt just right
NOT WAITING ANY MORE!
Critterman is online now
Old 05-16-2008, 10:55 AM
spiky3480's Avatar
Right on the dot! It's normal...nothing to worry about. I asked my pops who has been a mechanic for over 30 years.
TEAM SOLSTICE 2008
ONCE YOU GO SOLO, YOU NEVER GO BACK
2007 Mysterious GXP- "Intruder"
Member of LISSC
Exhaust System Sound Clips
SOLO Performance Exhaust Sound Clips
Spiky3480 Modification Page
Mods: 64
Updated 7/21/08
spiky3480 is online now
Old 05-18-2008, 12:01 PM
This might be for new turbo cars, but as a rule you want to stay away from white smoke.
white is coolant.
Car Talk
Well, Jim, a good mechanic can often diagnose a problem simply by looking at the color of the exhaust that comes out of the tailpipe. For instance, black smoke means that the fuel/air mixture is too rich.
Ray: Blue smoke, on the other hand, means that oil is getting burned in at least one of the cylinders.
Tom: And white smoke generally means that a new pope has been elected.
Ray: Actually, Jim, white smoke means that coolant is getting into one of the combustion chambers. The white smoke you see is vaporized antifreeze coming out the tailpipe. And antifreeze is probably getting into the combustion chamber because you have a cracked head gasket.
Old 05-19-2008, 06:38 AM
Critterman's Avatar
white is coolant.
Car Talk
that is true if it is a steady stream of white smoke and it will be accompanied by a sickening sweet smell.
Old 05-19-2008, 09:49 AM
Jeff Donald's Avatar
I've had a cracked head gasket and the smoke from the coolant burning is non-stop, not intermittent. An occasional puff like Critterman describes is normal in most turbos I've seen.
Jeff Donald is offline
