Originally Posted by
DNC
Didn't break it - I had begun to examine what I needed to loosen/remove to replace the air filter when I came across detached steel braided line. Examination revealed plastic nipple still attached to line - it fractured at base. Heavy braided line fixed to engine which moves attached to 1/8" plastic nipple on fixed piece I wasn't to shocked to see it had fractured. In retrospect my first photo of project shows cover in place, air filter in bag and braided line in awkward position.
The braided line your referring to that goes to the plastic nipple is the PCV line. If it was broke before you did any work under the hood, you would of set a warning light on your I/P and a code would of been set in the ECM. The engine would of run lean and you would of felt other drivability problems.
You never mentioned any of these conditions so one would have to assume that when you removed your engine cover that you accidentally damaged the part.
Don’t discredit your dealership for trying to cover their assets. If their GM rep came in and questioned the repair, they would debit the dealer for the repair and the dealer would have to pay for something you may of caused.
Accidents happen, if you did it, fess up, pay the price and be more careful next time
