I am just looking at LE5 via HPTuners. LE5 is pulse width modulated also.
Fan desired % starting at 196F is 6.25, 199F is 12.5...or about every 3-4 degrees for each % listed below.
0.00000 6.25000 12.50000 18.75000 25.00000 31.25000 37.50000 43.75000 50.00000 56.25000 62.50000 68.75000 75.00000 81.25000 87.50000 93.75000 99.98932
AC controls fan desired % vs AC psi. I'll save you the numbers.
No info on what ambient temperature for fan to come on when AC is on.
Thanks for highlighting this.
Norm
Originally Posted by info2x
The LE5 kappas command fan on low at 106C (223F) Fan on High is at 110C (230F)
The LNF Kappas have a PWM controlled fan and will command a 10% duty cycle starting at about 197F from my own experience.
In order for that to happen wouldn't the engine need to be off?
That being said the engine will cool off better if the car is left in drive while coasting since the RPM will probably be higher and under many circumstances the fuel is cut off, no fuel = no energy input to the engine and thus coolant.
