Old 05-04-2006, 07:41 AM
   3rd Gear Howl.
Devoking's Avatar
New development here (started hearing it at about 4000mi.) that I have not seen reported before. My best description is that it is like a harmonic howl. Happens only in 3rd gear when it is just barely under a load, usually between 2500 and 3500 rpms. It stops if I accelerate from there or if you just let off the gas and let it coast. We are due to visit the dealer for some other minor fix-its and I hope I can re-create it for them. It doesn't do it all the time. Anyone else heard anything like this before?
Volley - ICOD GOTHIC................"Pontiac Pure Excitement".........
website link -
NASSOA - Officially recognized by GM
Founding Member #69
Devoking is offline
Old 05-04-2006, 07:53 AM
   Interesting...
twopolarbears's Avatar
Send a message via Yahoo to twopolarbears
...try it again, but monitor the speed you are at, not the RPM and the gear. is it 30, 35, 40? And see if you notice it at that speed in fourth gear, or in second gear.
I had a 95 camaro that did the same thing. Long story short, it was the rear differential gears 'humming' or 'singing' due to being offset a little. I actually had my bro in law tell me not to worry about it. He was a transmission guy. He said I could fix it, but based on it's age, and the miles I had on it, that I shouldn't worry about it, that I could put another 100k miles on it.
I'm NOT saying do that with your SOL if that's the case! I'd go get it fixed on a new car. But I'm willing to bet that with the amount of differential leaking problems I've read on here, that maybe you are experiencing same sort of thing. Any noticable leaks under the car, or on the diff itself? Something to think about anyway. Maybe your diff is low on oil, and the gears are 'dryer' than they should be. Hope this helps.
"If it jams, force it! If it breaks, well then, it needed to be fixed anyway!"
USAF 1985 - ?
Stationed: TX, MS, ND, FL, & Rep of the P.I.
Temp Duty: WA, MO, AK, ROK, JAPAN, AUS, THAILAND, GUAM, ITALY, SAUDI, TURKEY, FRANCE, ENGLAND, ICELAND, QATAR
twopolarbears is offline
Old 05-04-2006, 07:54 AM
AztekzRpurty's Avatar
Many people have, including me.
Mine would do it in 3rd and 4th, at different speeds of course.
Under a slight load at a certain speed, it would get really loud.
I dropped my car off at the dealer 2 days ago because of that, the clunk, a rattle from the rear when coasting at low speeds with the clutch in, and the leak.
They are replacing my whole differential. Other people are reporting that the newly designed carrier, (part number starts with 158), eliminates the howl and even the clunk. Can't wait till mine is done to see for myself.
AztekzRpurty is offline
Old 05-04-2006, 07:56 AM
Devoking's Avatar
No leaks so far. Tried to make it happen in other gears. Only does it in 3rd.
website link -
Founding Member #69
Devoking is offline
Old 05-04-2006, 07:58 AM
Well, like I said, mine was at certain speeds. 32 to about 39 miles per hour. But look at the other posts. Seems to be a 'hummer' of a problem for most.
USAF 1985 - ?
Old 05-04-2006, 07:59 AM
solli4me's Avatar
Thanks for the part # aztek. Gonna call my dealer. They've been sending me reminders to fill out the "Customer Satisfaction" survey. I'll be satisfied when they fix all the problems.
Amelia Clunkenquiet - she's cool and she's CAR.
My All American, Coast 2 Coast, Rt. 66 pics. 22 states, 9,000 miles in 4 weeks. http://www.solsticeforum.com/forum/f...ad-trip-20928/
Founder - KAPPAS for the Cause
Founding Member - MASC/MASSC
Founding Member - NASSOA
TEAM SOLSTICE 2008
Team Solstice! Folding@home Team
JOIN MASC/MASSC: mylyte@gmail.com
Join MASSC! mylyte@gmail.com
solli4me is offline
Old 05-04-2006, 08:37 AM
The new carrier number is #15825073
Thread is here. Interesting Differential Leak Development
Old 06-14-2006, 04:48 PM
mystein's Avatar
3891 miles on #10070 when the dealership test-drove it today regarding the "differential whine". They verified the whine in all gears under very light load but noted it to be extremely pronounced in 5th gear. My service manager is getting plans together for changeout of the entire carrier housing assembly.
2007 Mysterious 5-speed purchased 05/04/2007
Current Mods:
1. K&N Drop-in Panel Air Filter (until problems w/CAI's get resolved)
2. Solo-Performance Street Race exhaust
3. BSR Tune
4. GMPP CAI Kit
Planned Future Mods:
1. High Efficiency FMIC
2. Improved IC Tubes
3. Upgraded Turbocharger Kit from Hahn Racecraft and BSR Stage II or III Tune to accommodate the modifications.
mystein is offline
Old 07-18-2006, 03:57 PM
   My Sol just hit 4800 mi
I have the whine also. Its always does it, 30 mph in third & 4th gear under light load.
sgurski is offline
Old 07-18-2006, 04:18 PM
Shadow's Avatar
Send a message via Yahoo to Shadow
I've noticed this as well. I wonder if a leak is on it's way. I have about 4500 miles on it now. I'll keep my eye on the differential.
Mysterious/Ebony
Vin # 9126
DDM Stage II, DDM Pro-Beam, High Flow Cat, KS1, Lil Chromies, 5" Stubby Antenna, Black Center Wheel Caps, Dimming Home Link Mirror
Fully Loaded Except for XM and On-Star
Shadow is offline
Old 07-18-2006, 04:40 PM
archer's Avatar
search "whine" noise maybe it's the same problem. Also, you will hear it clearly if the top is up. I had no leaks but the whine, and the differential is changed, whine is gone.
archer is offline
Old 07-18-2006, 09:56 PM
Warthog's Avatar
We also have the growl started at 3000 mi. We are also blessed with the clunk. Had a whine at 200 mi that ended up being the serpentine belt the tech at the dealer had no explaination for that. Oh yeah got the "birds in the trunk" also
Mysterious, vin 110579 came home 2/06.
Warthog is offline
Old 07-18-2006, 10:01 PM
karilynhart's Avatar
I have the same whine...kinda sounds like an air raid siren
Had the diff replaced at 3200 mi now at 6500. I've just been turning the stereo up. We'll see if the differential has to be replaced again!
Mysterious/Ebony/Automatic/Polished Chrome
Fully Loaded...CAI/kappa shield/lil chromies
karilynhart is offline
