Old 05-07-2006, 10:09 AM
   Carrier Replacement Thread [related to rear differential leak or whine]
Chip's Avatar
It seems that the rear Carrier might be the root cause in the leaking differential issue for some cars? Maybe, maybe not? I would like this thread to serve a tracking thread for the replacement of the rear carrier. If you have had this assembly replaced on your car please post the following information. Copy and paste as needed.
Carrier Replacement:
When did you buy your car?
When did you put your car into service?
Did you have a leaking Diff.?
Did you have a pinion seal replaced before as a fix for the leak?
Date and mileage when was your first leak was noticed?
Date and mileage when Carrier was replaced?
Does your car have a limited slip differential? (LSD)
Which part no. was used in the replacement?
How long did the Carrier replacement take?
Did you have the driveline “clunk” before the carrier was replaced?
Do you have the “clunk” now?
Do you notice any other changes that might be attributed to the Carrier replacement?
Any leaks since the Carrier was replaced?
Chip is offline
Old 05-08-2006, 11:30 PM
Gizmo's Avatar
PLEASE USE FORMAT FROM POST #1 OF THIS THREAD TO POST YOUR DATA. Thank you.
Post#..Leak/Whine..Date Repl.Mileage.LSD.Clnk.VIN......Part#........UserNa me
....7..................................11392....Y. ...N...101113..10344863..2091351
.................................................. ............102986.................2late
...17......Whine......07/07/06...5000....Y....Y...............15825073..archer
...10....................05/18/06...5224....Y....Y...105913..15825073..AztekzRpur ty
....8....................................5039..... ....N...108178..15825073..beezel
.................................................. ............105531.................daveritag
...15......Whine......06/20/06...6000....Y....N...111230..15825073..Devoking
.................................................. .......................................Dj Pep (missing since 03/01/06)
....9.....................05/01/06....................................15825073..Fa rTooDeep
...16......Whine......06/19/06...9558...Y...lash.101411...15825073..gator99
...19.......Leak.......06/28/06...5142...Y....Y...102773...15825073..glider rider
...11.....................in shop....3100....Y....N...114226..................k arilynhart
.................................................. .Y....N...000948..................Mactown
.................................................. .Y...Occ.000369.................Rowan1008
.................................................. .Y....Y...106281..................scubaman
.................................................. .Y...Y...109131..................slychick
.................................................. .Y...Y...107020..................solstice4MLB
....19.....Both........07/11/06...8125...Y....N...000741...15825073..SolWhat?
Pinion seal part number not changed, still 88996592
Old carrier part number is 10344863
New carrier part number is 15825074 or 15825073 ???
Her name is MariSOL
Link- Gizmo's Modification Page
NASSOA Founding Member #77
Team Solstice 2008
I am Officially recognized by GM
Last edited by Gizmo : 07-11-2006 at 06:48 PM. Reason: added Leak/Whine column (reason for replacement)
Gizmo is offline
Old 05-09-2006, 05:22 PM
i thought the leak was related to the pinion bearing seal? the pinion is a completely different part than the carrier. so fixing the pinion leak would not require replacing the carrier, just removing and reinstalling it
94 Grand Cherokee 7"/35s
06 Red Solstice
Everything except onstar/chrome
TMac is offline
Old 05-09-2006, 06:04 PM
Chip's Avatar
In some cases the leaking diff.could not be given a long term "fix" by replacing a pinion seal or faulty vent valve. There have been several owners that have needed the entire rear "Carrier" replaced to remedy the issue. The purpose of this thread is to see how many owners have needed to go this route. I also believe there are two part numbers being used in this replacement. One Carrier assembly with a new number seems to be newly revised, while the other is the older original part #. I will try to track down both part numbers for the rear Carrier.
Found it:
Per windface: "#10344863 is the old number. #15825073 is the new one, with a revised front mount."
Chip is offline
Old 05-10-2006, 12:02 AM
Gizmo's Avatar
I think you're right, TMac.
Many of the carriers have been replaced because of a whining noise (from the carrier, dummy, not the driver! )
But some who have had their pinion seal leaks return have gotten new carriers too.
So I guess GM is still investigating.
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 05-10-2006, 03:53 PM
2091351's Avatar
When did you buy your car? N/A
When did you put your car into service? October 26, 2005
Did you have a leaking Diff.? Yes, I had drips on the floor
Did you have a pinion seal replaced before as a fix for the leak? No
February 13, 2006 7497
Mileage when Carrier was replaced? 11,392
Which part no. was used in the replacement? 10344863
How long did the Carrier replacement take? Less than One Day
Did you have the driveline “clunk” before the carrier was replaced? Never
Do you have the “clunk” now? No
Do you notice any other changes that might be attributed to the Carrier replacement? Another Leak
Any leaks since the Carrier was replaced? Not yet
[/quote]
#1113 42,575 Miles
DOCUMENTED ISSUE 10/26/2005 Delivery *** Ordered 2/13/2004
Envious/Black/ABS/Cruise/A-C/LSD/Mud Flaps/Tonneau/Mats/GMPP CAI/Stan's Real Tri-Y Header/MagnaFlow High Flow Cat/MagnaFlow Cat-Back/AirBag Adjuster/HighBeam Helper/DashHawk II
*Carrier Replaced @11,392 miles*
Club=Solstice Sky Club of Arkansas (solskyoa@sbcglobal.net)
NASSOA #24
Pure 2009 Solstice GXP Coupe on order 7/16/2008
2091351 is offline
Old 05-10-2006, 04:09 PM
beezel's Avatar
When did you buy your car? 01/14/06
When did you put your car into service? 05/01/06
Did you have a leaking Diff.? NO
Did you have a pinion seal replaced before as a fix for the leak? NO
Date and mileage when was your first leak was noticed? N/A
Mileage when Carrier was replaced? 5039
Which part no. was used in the replacement? 15825073
How long did the Carrier replacement take? 1 DAY
Did you have the driveline “clunk” before the carrier was replaced? NOT SURE
Do you have the “clunk” now? NO
Do you notice any other changes that might be attributed to the Carrier replacement? A LOUD WHINE
Any leaks since the Carrier was replaced? NO
beezel is offline
Old 05-10-2006, 05:22 PM
Gizmo's Avatar
Originally Posted by FarTooDeep
Got my new carrier (15825073 ) installed yesterday (05/01/06) and BINGO, no leak and NO MORE CLUNK. I was absolutely amazed at what a difference it made. I thought maybe my diff whine would be lessened but believe it or not, the car FEELS very different. Like there is more power in the 2-3k rpm range.
When did you buy your car? 02/17/06
When did you put your car into service? 02/17/06
Date and mileage when Carrier was replaced? 05/01/06
Did you have the driveline “clunk” before the carrier was replaced? Yes
Just to update FarTooDeep, until he posts to this thread, then I'll delete this one.
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 05-18-2006, 06:07 PM
AztekzRpurty's Avatar
When did you buy your car? 1/9/06
When did you put your car into service? 5/16/06
Date and mileage when was your first leak was noticed? 4500
Date and mileage when Carrier was replaced? 5/18/06 5224
Does your car have a limited slip differential? (LSD) Yes
How long did the Carrier replacement take? 2 days
Did you have the driveline “clunk” before the carrier was replaced? Big Time!
Do you have the “clunk” now? It's baaaaaccckkk. Took about 500 miles
Do you notice any other changes that might be attributed to the Carrier replacement? Old whine at 65mph is gone, new lesser whine at 30-40
Any leaks since the Carrier was replaced? No.
AztekzRpurty is offline
Old 05-18-2006, 06:56 PM
karilynhart's Avatar
When did you buy your car? 4-17-06
When did you put your car into service?5-16-06
Did you have a pinion seal replaced before as a fix for the leak? Yes
Date and mileage when was your first leak was noticed? 5-08-06, 2150
Date and mileage when Carrier was replaced? 5-24-06, 3100
Which part no. was used in the replacement? Don't know
How long did the Carrier replacement take? 8 days
Did you have the driveline “clunk” before the carrier was replaced? No
Do you have the “clunk” now? No (have automatic)
Do you notice any other changes that might be attributed to the Carrier replacement? No
Mysterious/Ebony/Automatic/Polished Chrome
Fully Loaded...CAI/kappa shield/lil chromies
karilynhart is offline
Old 06-12-2006, 03:38 PM
When did you buy your car? 2-8-06
When did you put your car into service?6-6-06 (666)
Did you have a leaking Diff.?Yes
Did you have a pinion seal replaced before as a fix for the leak?Yes
Date and mileage when was your first leak was noticed?5-08-06, 2150 on or about.
Date and mileage when Carrier was replaced? 5310 (still at dealer waiting for part)
Which part no. was used in the replacement?Don't know yet
How long did the Carrier replacement take?one week so far, Still waiting
Did you have the driveline “clunk” before the carrier was replaced?yes Do you have the “clunk” now?N/A
Do you notice any other changes that might be attributed to the Carrier replacement?Loud whine at slow speed while turning in parking lots
Any leaks since the Carrier was replaced?[/quote]Don't know yet
pilo is offline
Old 06-12-2006, 03:58 PM
dylan01's Avatar
Send a message via MSN to dylan01
When did you buy your car? 09-22-05
When did you put your car into service? 6-12-06
Did you have a leaking Diff.? Not sure, nobody really is either.
Did you have a pinion seal replaced before as a fix for the leak? Nothing
Date and mileage when was your first leak was noticed? 06-10-06, 1135 KM
Date and mileage when Carrier was replaced? N/A
Which part no. was used in the replacement? N/A
How long did the Carrier replacement take? In and out in about 8 hrs. No repair
Do you notice any other changes that might be attributed to the Carrier replacement? NO. Just a BRUTAL job with my fit problem.. they only made it worse
VIN 1715
2006 Pontiac Solstice
VIN 1,715
3,200 miles
CUSTOMIZED GXP DUAL EXHAUST
GXP REAR FASCIA
STUBBY ANTENNA
CARBON FIBER INTERIOR
dylan01 is offline
Old 06-12-2006, 09:50 PM
I am going to still go out on the limb and say that the faulty overflow valve is the croux of this whole Diferential problem.
The valve is not working properly and is letting gear fluid out when it should not, consequently as you drive the gear oil gets lower and lower and not lubricating the gears as it should, they overheat, the tolerances start to go south, the diferential starts to whine, the rest is history.
LatinVenom is offline
Old 06-12-2006, 09:54 PM
