Old 06-02-2008, 12:42 PM
   Differential Being Replaced
Shadow's Avatar
Send a message via Yahoo to Shadow
I took my '06 to the dealer and demonstrated the harmonic whine I was getting frm the rear at different speeds and loads. They will be replacing the differential for me. I'm looking forward to leak free, clunk free operation after the replacement.
Mysterious/Ebony
Vin # 9126
DDM Stage II, DDM Pro-Beam, High Flow Cat, KS1, Lil Chromies, 5" Stubby Antenna, Black Center Wheel Caps, Dimming Home Link Mirror
Fully Loaded Except for XM and On-Star
Shadow is offline
Old 06-02-2008, 08:12 PM
   whine
GreatWhiteNorth's Avatar
was at my Pontiac Canada dealership today to get the pinnion seal recall done and
complained about the rear end whine. even brought a tape recording in case they didn't hear it while I was in. Have figured out on mine the differential needs to be hot say 15 to 20 minutes of driving before it will really start to whine.
Well everybody heard it but they said it was not that bad and they handed me the GM bulletin that says certain amount of whine is normal and to compare it against other vehicles @ the dealership. They did admit to changing one rear end as the whine was so bad even when it was cold. This is the first Canadian rear end I have heard that was changed because of the whine. No new differential for me but assurance that it has been noted in the official record and I may qualify for a goodwill repair in the future after the warranty runs out if the rear end gives me trouble.
GreatWhiteNorth is offline
Old 06-02-2008, 08:50 PM
bigblau's Avatar
They didn’t suggest turning up the radio?
bigblau is offline
Old 06-02-2008, 08:51 PM
Shadow's Avatar
I brought my car in, and told them that I needed a new differential because of a whine at certain speeds and loads. They said they would test it and get back to me. After about four hours, I got a call and they said that they found nothing wrong! They told me that three technicians took the car out and could not understand what I was complaining about. I went back to the dealership and asked that a technician take a ride with me so I could demonstrate the whine. Within 30 seconds of our test drive, the technician stated that the differential needed to be replaced.
Mysterious/Ebony
Vin # 9126
Shadow is offline
Old 06-05-2008, 11:00 AM
Shadow's Avatar
So I picked up the car yesterday after the differential was replaced. Everythign is running great! The diagnosis stated that there was metal in the differential fluid. The carrier was replaced. Part number 25858218. The best part is no more whine and no more clunk!
Mysterious/Ebony
Vin # 9126
Shadow is offline
Old 06-05-2008, 11:37 AM
Gizmo's Avatar
I'm glad that "SMOKIN" is back on the road again, Shadow, and better than ever!
I'm also glad they didn't try to get out of the warranty because of your Hahn Stage II.
Enjoy that wonderful car!!!!
Her name is MariSOL
Link- Gizmo's Modification Page
NASSOA Founding Member #77
Team Solstice 2008
I am Officially recognized by GM
Gizmo is offline
Old 06-05-2008, 11:43 AM
Shadow's Avatar
Yeah I'm glad too. In fact, when I drove with the technician he asked me wat mod I made to the car. He mentioned that when he tested it prior (without me) he stepped on the gas and knew it wasn't stock!
By the way Gizmo, how do you know that my plate is "SMOKN"?
Mysterious/Ebony
Vin # 9126
Shadow is offline
Old 06-05-2008, 12:26 PM
Gizmo's Avatar
Gizmo, Ex-Keeper of the Lists!
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 06-05-2008, 12:40 PM
AztekzRpurty's Avatar
Cool!
You got the same new diff I did.
Here's my experience, with a pic of the difference, 3000 Clunk Free Miles... WOOHOO!!
AztekzRpurty is offline
Old 06-05-2008, 12:49 PM
Shadow's Avatar
Originally Posted by AztekzRpurty View Post
Cool!
Aztek - I'm very familier with your thread. It was the one that encouraged me to complain about my whine. Thanks Dude!!!
Mysterious/Ebony
Vin # 9126
Shadow is offline
Old 06-05-2008, 01:51 PM
1KULSOL's Avatar
Send a message via Yahoo to 1KULSOL
You Lie ... you still keep LISTS
DDMWorks Supercharger kit #11 - STAGE II - DDMWorks 3 guage pod with PLX gauges (boost/afr/oil temp)- Koni Sport shocks f/r-DDM ProBeam-DDM upgraded brake kit(drilled/slotted rotors-ss brake lines-ceramic pads)-DDMWorks 4-1 long tube headers and hiflow converter-JPM padded center console-DDMWorks Backbone (in RED)-SOLO SQR-2 dual center exhaust-Norms Painted (SLY) rear valence-Kazera KZ-L wheels w/Bridgestone RE760 Sport tires (255/45/18)Waiting on Stage III and the STB (Shock Tower Brace)
1KULSOL is offline
Old 06-05-2008, 01:54 PM
Gizmo's Avatar
Yep, you're right.
And YOU are on it !!!!!!!!!!!!!!!!!!!
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 06-05-2008, 02:26 PM
Fformula88's Avatar
Yep, you're right.
Wow, that's kind of creepy!
We Build Excitement
Fformula88 is offline
Old 06-07-2008, 04:17 PM
Critterman's Avatar
