Old 05-10-2006, 10:12 AM
   Electrical and other problems
JewJenk's Avatar
Send a message via AIM to JewJenk
I have noticed a lot of posts regarding electrical gremlins that seem to come and go. Well today I was under the hood and went to reset the ECM, due to a post regarding the fact that some dealers give you a free tank of gas, REGULAR gas. As usual I check all of my nuts and bolts as the car is put together by automation. Some of them have to be snugged down. I was checking the fuse box under the hood and found that all of the fuses, relays and circuit breakers moved when I pushed them down, I believe that this could be a reason for some of the intermediate electrical problems. I also found hood latch bolts that were tight but not snug and easily turned.
Check it out on your Sol, it may cure some of the problems and stop minor squeeks and groans.
Don't get mad, get even....
JewJenk is offline
Old 05-10-2006, 11:03 AM
Gizmo's Avatar
Great post, JewJenk. That certainly might explain a lot of the electrical problems. Worth checking out.
And welcome to the Solstice Forum!
Thanks for honoring my Solstice Received Thread with your very first post to the Forum..
And a big CONGRATULATIONS on getting your beautiful Aggressive.
I've added you to the South Carolina list. Just click on the "Lists of Forum Members by States" link in my signature below, then on the "Southeast: AL, AR, FL, GA, KY, LA, MS, NC, SC, TN, VA" link in that thread to see your Solstice neighbors.
Welcome to the Solstice Owner's Club! Perhaps you will join us for the North American Solstice Gathering in Kansas City, MO July 14-16? If you need more information, please ask me.
Her name is MariSOL
Link- Gizmo's Modification Page
NASSOA Founding Member #77
Team Solstice 2008
I am Officially recognized by GM
Gizmo is offline
Old 05-10-2006, 11:55 AM
I'll be checking that out, hope it works. Yesterday I stopped to get some gas the car was off but the keyes were still in. as I opened up the door, the radio came on, nothing but white noise though... I kept waiting for my dad to talk to me from beyond the grave
jarhead is offline
Old 05-10-2006, 07:58 PM
JewJenk's Avatar
o'kay now, maybe some one can tell me what happened. And I don't know which one changed it, after reseating all the fuses, relays and everything else in the fuse box and resetting the ECM, I took the car for a drive. I used to have a type of clutch chatter on starting in first gear at low RPM. That is no more, the engine seems to run much smoother and faster, gear shifting seems smoother (manual) revs are quicker. Seems like a different car, and this is without the ECM flash. Also noticed that on startup, after the ECM reset, all the center yellow lights on the Hi-vac knobs, (three rounds knobs right below the radio) flashed together for about 30 seconds and then stopped. I would assume that this was the ECM reading all of the electronics.
Any comments...
JewJenk is offline
Old 05-10-2006, 09:42 PM
Gizmo's Avatar
Any comments...
Yep, looks like Gizmo the accountant stumbled upon the cheapest mod possible.
<---- Gizmo
I don't know why it works, but yes, disconnecting the negative on the battery and reconnecting after at least half an hour resets the settings back to OEM and the car seems to run better.
Now I'm sure the retune will be even better, and I intend to do that after I get my long tube headers and cat-back dual-exit exhaust. But for now, this seems to be a winner based on cost and effect.
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 05-10-2006, 09:58 PM
The Wizard of Giz comes through again.
Pop's car is Cool, Black Leather. 73,000 miles of permagirn and climbing.
popsintx is offline
Old 05-10-2006, 10:10 PM
midolo's Avatar
Any comments...
Similar experience here, including the flashing yellow lights! Gas mileage also improved by about 2 miles per gallon.
Cool/Ebony vin 11402 Everything but OnStar and Smoker's package
midolo is offline
Old 05-11-2006, 12:13 AM
IgotSol's Avatar
How do you reset fuses and relays
So Giz, its removing the neg connectors from the battery that resets ECM? Do I leave the pos in and just remove the neg? I've read somewhere the opposite. Taking the pos off and leaving the neg on for about 30mins. Does it matter? Would like your comment. Thanks.
My Sol is Cool!!!
Her name is Salma, like in Salma Hayek. Because she's got the same curves in all the right places!!!
IgotSol is offline
Old 05-11-2006, 12:18 AM
Gizmo's Avatar
The way I understand it (and remember, I'm an accountant!), if you leave the negative connected while you disconnect the positive, you run the risk of zapping all your electrical components.
So everyone says: always disconnect the negative BEFORE you ever disconnect the positive.
Yes, simply disconnect the negative for at least half an hour (I suggest you make it at least an hour) and then reconnect. Then drive aggressively, shift at higher RPMs, downshift when appropriate.
After you've run her for awhile, be sure to post to the ECM Reset List Thread with your evaluation. Reference is up above in my previous post. Thanks.
Her name is MariSOL
Team Solstice 2008
Gizmo is offline
Old 05-11-2006, 08:18 AM
JewJenk's Avatar
Just press down on all of the relays, fuse and anything else in the fuse boxes, you will probably have some or all of them move a little this in essence will seat them more securely in their respective slots. What this will do is stop any intermentent connections that might be interfering with the operation of the vehicle or/and electric components and causing problems.
JewJenk is offline
Old 05-11-2006, 04:19 PM
Dorf's Avatar
If you have the ECM redone and then take off the neg battery terminal for 30min, does it reset back to OEM or back to where you paid to have it retuned at. ???
Dorf is offline
Old 05-11-2006, 05:10 PM
Critterman's Avatar
The ECM ir ROM and will reset to what ever the latest parameter where. So you would get the mod you paid for after you disconnect your battery. Remember you don't send the battery with the unit so it is disconnected the entire time except when they flash it.
NOT WAITING ANY MORE!
Critterman is offline
Old 05-11-2006, 05:12 PM
Shadow's Avatar
Send a message via Yahoo to Shadow
... I was checking the fuse box under the hood and found that all of the fuses, relays and circuit breakers moved when I pushed them down...
Just to make things easy for others, can you describe where under the hood the fuse and relay boxes are?
Mysterious/Ebony
Vin # 9126
DDM Stage II, DDM Pro-Beam, High Flow Cat, KS1, Lil Chromies, 5" Stubby Antenna, Black Center Wheel Caps, Dimming Home Link Mirror
Fully Loaded Except for XM and On-Star
Shadow is offline
Old 05-11-2006, 07:54 PM
JewJenk's Avatar
It's the shoe box sized black box located on the passenger side right in front of the battery. On either end of the box there is two tabs. Push them outward and then pull up, this should get the cover off.
JewJenk is offline
Old 05-12-2006, 09:13 AM
Shadow's Avatar
Thanks JewJenk!
Mysterious/Ebony
Vin # 9126
Shadow is offline
