does anyone know a website where I can find the part number for the ecotec 2.4 crank and conrods
I need the numbers so I can get a set imported to England for my ecotec 2.2 rebuild project with independent throttle bodies
We don't have the ecotec 2.4 vvt in europe yet, so can anybody help
Here are the part numbers right from the boxes that the grills are shipped in:
15282192 GRILLE RH
15282193 GRILLE LH
__________________ 08 GXP Orange Auto Loaded
07 GXP Yellow Auto Loaded
07 GXP Yellow Man Loaded
06 Red Auto Loaded
06 Red Man Loaded
06 Grey Man Loaded
06 Red Man Vista House Meet 1/15/06
Mt St. Helens Meet 3/25/06
WV Wine Tour 5/13/06
S Solstice CRG PreRun 5/28/06
S Solstice CRG Meet 6/24/06 6/25/06
Solli4Meet Mt. Hood 7/29/06
OR/WA FC Run 10/28/06
South Mt Run Phoenix, AZ. 1/14/07
Orygun Run 4/28/07
2nd S Solstice CRG Meet 6/23/07
TVR 9/22/07
LCD 10/27/07
3rd S Solstice CRG Meet 6/21-22/08
15282192 GRILLE RH
15282193 GRILLE LH
Just had mine replaced in my Sky...but pretty sure they would be the same part # for both Sols and Skys. This is the NEW and REDESIGNED A/C compressor. No more funky growling/groaning/whining noises when running the air.
Linda
2007 Sky - Silver Pearl
Black Leather/Black Lid
Automatic
LSD
Monsoon/Single CD
Painted Alloy Wheels
Originally Posted by nscrbug
P/N# 89025003 - A/C compressor
That is the same compressor number since the cars came out last spring. It is not a new number.
You may have had a compressor problem, although the Termal Expansion Valve (TXV), A/C line grounding out/clearance or low refridgerant level, are the more likely causes of air conditioning noise.
INFORMATION POSTED ON SITE
Well, perhaps the part # is not correct, which I apologize for...but I most certainly did have a compressor problem. The TXV and A/C line were checked and no problems were found. The compressor was deemed "defective from factory"...and there is indeed a newly redesigned A/C compressor available...I will try and find out what the correct part # is for it. I waited 3 months for this compressor...my dealer refused to put in the same old crappy compressor, therefore they kept rejecting the order and waited it out until this new design was available...which is why it took 3 months to get. The difference is like NIGHT AND DAY...no noise whatsoever.
Linda
Automatic
LSD
Monsoon/Single CD
Some more part numbers for you, Blake:
GM Part #......Description................................ .................................Dealer Price
15299260..Door, driver, no mirror (old)............................................. ...$563.64
15909689..Door, driver, no mirror (new)............................................. .$580.55
15299261..Door, passenger, no mirror (old)..........................................$56 3.64
15859723..Door, passenger, no mirror (new)........................................$560. 92
15213620..Mirror, driver, electric.......................................... .............$124.15
15229255..Mirror, passenger, electric.......................................... .......$124.15
15779404..Fender, driver............................................ .....................$ 70.00
Her name is MariSOL
VIN 6Y101319, delivered 10/15/05. 69,991 miles.
