LinkBack (1) Thread Tools Search this Thread Display Modes
Old 07-19-2007, 12:04 PM
salstice's Avatar
Maybe I missed it somewhere in here, but what are the interior door assembly part numbers?
salstice is offline
Old 07-25-2007, 01:45 PM
karlozh11's Avatar
Hi all:
Somebody know the part number of the original doorīs hingeīs (lamborghini doorīs), itīs a original part?
thank you
carlos
mexico
karlozh11 is offline
Old 07-25-2007, 01:52 PM
PAO
PAO's Avatar
Originally Posted by karlozh11 View Post
Hi all:
thank you
carlos
mexico
dont beleive it uses the OEM hinge..but kit is a direct replacment is my understanding
Pontiac builds excitement...
NASSOA(TM)
PAO is offline
Old 07-26-2007, 09:08 PM
Administrator
SolsticeMan's Avatar
From here
http://sccaforums.com/forums/permali...ad.aspx#255712
if you ever wanted to backdate your GXP to a GXP Z0K:
GM PARTS BULLETINS & INFORMATION - TO ALL PONTIAC DEALERS
Subject: 2007-2010 Solstice GXP with manual transmission (RPO MA5) upgrade with an optional suspension (Z0K)
Message #: VSU20071527
We are pleased to announce to our customers the Z0K suspension upgrade for 2007-2010 Pontiac Solstice GXP with a manual transmission (RPO MA5). The necessary parts for this upgrade are available in the following attachment:
2007 Solstice GXP Z0K Optional Suspension.doc contents:
2007-2010 Solstice GXP Z0K Optional Suspension Upgrade
Suspension parts needed to install Z0K optional suspension on 2007-2010 Pontiac Solstice GXP
For manual transmission (MA5)
Part No. Name Qty
25849163 Front Spring 2 $96.14
25855621 Front Stabilizer Shaft 1 $315.00
25855626 Rear Spring 2 $71.32
25855622 Rear Stabilizer Shaft 1
25855623 Rear Stabilizer Shaft Insulator 2 $5.40
25855624 Rear Stabilizer Insulator Clamp 2
25877302 Rear Suspension Support Crossmember 1 $420.00
*****Disclaimer*****
Attention: For customers that intend to use their 2006 - 07 Pontiac Solstice equipped
with option code Z0K , please refer to service bulletin 06-03-07-003A, dated 8/24/06 for alignment specification, optimizing performance.
Warranty Information
The above modifications are considered to be a customer option and performed at customer's expense.
Prior to using your vehicle, refer to your warranty book or your dealership for information on the GM new vehicle factory warranty, and how usage may affect your warranty.
Please reference the 2006 -07 service info. If the customer does not add a secondary spring seat, per service info 1824659, the customer is in the optional set-up. The customer must add the secondary spring with the springs below to have the GM warranty apply. The ZOK vehicle leaves the plant with 2 spring seats per each shock module.
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 07-27-2007, 08:43 AM
SM.
I do not see any mentioned of shocks, any idea why?.
LatinVenom is offline
Old 07-27-2007, 12:05 PM
Administrator
Originally Posted by LatinVenom View Post
SM.
Presumably because the shocks are the same as the shocks on the normal GXP w/ FE3 suspension. Therefore, you don't need to replace them.
This makes sense if you think about it:
-If you run in AStock Autocrossing, you can use whatever shocks you want, and you can fool with the front stabilizer bar. Tuning shocks for a low volume application where most users will replace them anyway does not make sense.
-If you buy one and decide to run T2 Road Racing, you can use whatever shocks you want. ibid.
(I say whatever shocks you want, I should clarify that they have to have the same perch location and mounting, but if you can find a set of dbl-adj Penske shocks, for example, and they fit and have the same spring perch location, these are legal to use in AX and ClbRacing)
Old 07-27-2007, 02:48 PM
Small Dealer's Avatar
The current Parts Catalog (Pro Quest DVD July 2007) shows the 2008 Solstice FE3 Z0K shocks with different part numbers than the 2008 Solstice FE3 GTA (GXP) shocks.
Another interesting thing, if you take the missing number from the near consecutive string, it comes out to a shock (although possibly a number change is in motion).
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 07-27-2007, 02:55 PM
So 25855625 could be the shock missing part number?.
Old 07-27-2007, 03:00 PM
Could be. We should/could know more before the August 3rd deadline (another thread), I would guess.
But SolsticeMan's theory on shocks also makes sense.
Old 07-27-2007, 03:46 PM
Administrator
That may be true - remember both Z0K (base and GXP) cars come with shocks that have a 'manufacturing riser' that you remove as an option to change the carrying height to the intended height.
I imagine that the shock for the 2008 Z0K (independent of whether N/A or Turbo) are same part numbers, with a different one for the 'normal' GXP. Regardless, the shock internals should be identical (same C### on the body of the shock).
Old 07-27-2007, 03:51 PM
The updated message with parts information has been posted in the other thread.
Old 08-04-2007, 12:53 AM
VIN2020's Avatar
Exhaust gasket GM P/N 12589453 MSRP: $9.18
Exhuast manifold nuts GM P/N 11517031 MSRP of $1.
VIN2020 is offline
Old 09-23-2007, 05:29 PM
   Thermostat Gasket (O-Ring)
VIN2020's Avatar
Added:
3522676........Thermostat Gasket (O-Ring)............................................$ 5.90
12589453......Exhaust gasket............................................ ...................$ 9.18
10304424......Exhaust Inulator (Rubber hanger)
11517031......Exhuast manifold nuts.............................................. .......$ 1.00
10376721......Retainer (Metal one, used on grill and rear valeance)
10121502......Retainer (Plastic push retainer used for body parts)
15904089..... Trim between side panels and hood................................. $ 17.97
19149282......Wheel, Polished.......................................... ....................$ 649.11
12576410......Air Mass Sensor- 2.0L.............................................. ........$ 94.81
Originally Posted by VIN2020 View Post
All,
I plan on keeping a list of the Solstice GM (only) part numbers, so as you post the numbers and parts descriptions I will update this initial post.
This list should be important so others can take advantage of saving with on-line purchasing of these items.
List is sorted by description
Please keep the format like the following.
GM Part #......Description................................ .................................Dealer Price
89025003......A/C compressor
15264321......Arm, Rear Axle Lower Control Arm....................................$195.66
15264322......Arm, Rear Axle Lower Control Arm....................................$195.66
15264001......Arm, Steering Knuckle Upper & Lower Control Arm................$158.48
15822072......Arm, Steering Knuckle Upper & Lower Control Arm................$160.48
89025064......Bumper Cover, Nose.............................................. ......$ 289.80
19120721......Bumper Cover, Nose- GXP..............................................$ 355.90
15254986......Bumper front lip - GXP
89225065......Bumper, Rear bumper (- 7831)........................................$ 252.00
15867069......CONSOLE ASM-F/FLR EBONY
15867070......CONSOLE ASM-F/FLR LT CASHMERE
15916412......Dash TRIM ASM-R/WDO PNL EBONY/LT SIL &UW5&19I&67U.
15916405......Dash TRIM ASM-R/WDO PNL EBONY/BLACK &UW5&19I&41U.
15916413......Dash TRIM ASM-R/WDO PNL MD STL/M BLU &UW5&25U&31I.
15916414......Dash TRIM ASM-R/WDO PNL MD STL/L SIL &UW5&31I&67U.
15916415......Dash TRIM ASM-R/WDO PNL MD STL/D SIL &UW5&31I&42U.
15916406......Dash TRIM ASM-R/WDO PNL MD STL/BLACK &UW5&31I&41U.
15916427......Dash TRIM ASM-R/WDO PNL EBONY/YELLOW &UQ3&19I&34U.
15916426......Dash TRIM ASM-R/WDO PNL EBONY/M BLUE &UQ3&19I&25U.
15916428......Dash TRIM ASM-R/WDO PNL EBONY/EMRALD &UQ3&19I&38U.
15916429......Dash TRIM ASM-R/WDO PNL EBONY/VI RED &UQ3&19I&74U.
15916430......Dash TRIM ASM-R/WDO PNL EBONY/DK SIL &UQ3&19I&42U.
15916431......Dash TRIM ASM-R/WDO PNL EBONY/LT SIL &UQ3&19I&67U.
15916424......Dash TRIM ASM-R/WDO PNL EBONY/BLACK &UQ3&19I&41U.
15916432......Dash TRIM ASM-R/WDO PNL MD STL/M BLU &UQ3&25U&31I.
15916433......Dash TRIM ASM-R/WDO PNL MD STL/L SIL &UQ3&31I&67U.
15916434......Dash TRIM ASM-R/WDO PNL MD STL/D SIL &UQ3&31I&42U.
15916425......Dash TRIM ASM-R/WDO PNL MD STL/BLACK &UQ3&31I&41U.
15916407......Dash TRIM ASM-R/WDO PNL EBONY/M BLUE &UW5&19I&25U.
15916408......Dash TRIM ASM-R/WDO PNL EBONY/YELLOW &UW5&19I&34U.
15916409......Dash TRIM ASM-R/WDO PNL EBONY/EMRALD &UW5&19I&38U.
15916410......Dash TRIM ASM-R/WDO PNL EBONY/VI RED &UW5&19I&74U.
15916411......Dash TRIM ASM-R/WDO PNL EBONY/DK SIL &UW5&19I&42U.
15916416......Dash TRIM ASM-R/WDO PNL EBONY/WHITE &UW5&19I&50U.
15916417......Dash TRIM ASM-R/WDO PNL MD STL/WHITE &UW5&31I&50U.
15916435......Dash TRIM ASM-R/WDO PNL EBONY/WHITE &UQ3&19I&50U.
15916436......Dash TRIM ASM-R/WDO PNL MD STL/WHITE &UQ3&31I&50U.
15916437......Dash TRIM ASM-R/WDO PNL MD STL/EMRLD &UQ3&31I&38U.
15916438......Dash TRIM ASM-R/WDO PNL MD STL/V RED &UQ3&31I&74U.
15916418......Dash TRIM ASM-R/WDO PNL MD STL/EMRLD &UW5&31I&38U.
15916419......Dash TRIM ASM-R/WDO PNL MD STL/V RED &UW5&31I&74U.
10345219......Deflector (Rubber chin spoiler)........................................$ 21.24
15299260......Door, driver, no mirror (old)...........................................$5 63.64
15909689......Door, driver, no mirror (new)..........................................$58 0.55
15299261......Door, passenger, no mirror (old).....................................$563.64
15859723......Door, passenger, no mirror (new)....................................$560. 92
12603530......ECM (2006) Emission Control System Hardware (obsolete)....$383.83
12605843......ECM (2006 & 2007) Emission Control System Hardware........$383.83
12578182......Engine Crank
12596088......Engine Connecting Rod
12589453......Exhaust gasket............................................ .....................$ 9.18
11517031......Exhuast manifold nuts.............................................. .........$ 1.00
15779404......Fender LH (behind left front wheel).....................................$ 70.00
15779405......Fender RH (behind right front wheel)
19120266..... Folding top linkage Right Side
19120267 .....Folding top linkage Left side
15265486......GRILLE, Radiator Grille (?Back).......................................$ 35.00
15265487......GRILLE, Radiator Grille (?Black)......................................$ 35.00
15282192......GRILLE RH(Silver)........................................ ...............$ 35.00
15282193......GRILLE LH(Silver)........................................ ................$ 35.00
15254984......GRILLE large - GXP (Left?)
15254985......GRILLE large - GXP (right?)
89025309......Hood................................ ........................................$595.13
15909540......Headlight assembly driverside(same for GXP and NA)
15805581......Instrument Panel-Gauge Cluster........................................$ 207.20
15912960......Instrument Panel-PLATE ASM-I/P CSTR TR DK GRAY MET &VGL&19I.
15912961......Instrument Panel-PLATE ASM-I/P CSTR TR V DK STL GRA &VGL&31I.
15867060......Instrument Panel-BEZEL-I/P ASST HDL DK GRAY MET &19I.
15867061......Instrument Panel-BEZEL-I/P ASST HDL V DK STL GRA &31I.
15867067......Interior-Dash HANDLE ASM-I/P ASST V DK STL GRA &31I.
15254355......Interior-MOLDING ASM-Windshield UPR Garnish MD STEEL GRA &31I
1052358........LSD additive
15852707......LSD New relief valve Hex Chrome Free Vent
15233712......LSD OLD relief valve (replaced by 15852707)
15213620......Mirror, driver, electric.......................................... .........$124.15
