My 07 N/A with Premium Headliner was built in Aug 06 and it does not have these tabs and my top is ripped. The dealer has a new top on order, but I'm not sure I want to replace my top, just want the problem corrected. The hinge mechanism is completely different on the 06's, I'm guessing it was re-designed to accomodate the extra headliner. Did you do anything with the ripped portion of your liner or has the catching stopped by just adding these nylon pieces. From what I can tell, my top is getting caught up in the tear and that's where I'm pinching. I'll have to go back over to the dealer and ask them about these tabs. Thanks again, guys!!
2007 Mysterious Steel/Sand
Every Available Option including On*Star and XM
2.5" Stubby Billet Antenna from ShortAntenna
Custom Illuminated Windscreen from Wind Restrictor
Black Calipers with Silver "Pontiac" logos
VIN : 107386
Mine is ripped pretty good & the nylon tabs did the trick. I'll probably patch the torn area anyway. Need to figure out which adhesive to use that is stretchable. Probably rubber cement or a good weatherstripping adhesive. Any suggestions.
Spray silicone works well for freeing up the glides for the butress fabric that pulls down over the window frame. If it moves freely it will have less tension at the area that gets torn. I thing grease will collect grit & make it worse
there might be two differant versions of that part, one with the tab one without
That may make sense, no sign of tab in illustration. Maybe that is exactly what it is, especially if tabs are pre-assembled to part before car assembly. Although based on the area we are talking about I would think it would be part # 8 or 9. The tab is definitely
mounted to the lower curved piece not the upper straight.
Mysterious 2007 N/A 2.4. "DarkSol" is the name. Chrome alloys, steel and sand leather interior,
5 spd, ABS, AC.
Mods: vertical billet front grille.
Venture shield clear bra
GM mud flaps (front only)
Carolina Custom leather armrest pads
Real carbon fiber license plate frame
Norm's Fiberglass Split Dual SMOOTH FINISH Rear Fascia
GM CAI (Grrrreat!!)
Solo Mach Split Dual Exhaust for N/A with Resonator (Amazing Sound! DarkSol now has DeepSol's voice)
Loving AZ
