Old 06-21-2008, 04:02 PM
   TSB# for top pinching & tearing
spider's Avatar
Thanks to Miner.
Originally Posted by Miner View Post
I took my Sly in today becasue the top was pinching on both sides and starting to tear the top. It started on just the drivers side but when it started on the passenger side too, I knew that it was time to take it in.
When I did, I said that thre was a seervice bulletin some where in regard to it and the service person told me he could not find any. I asked him if maybe he could look again and sure enough - Service Bulletin #06-08-67-017B jumped up at him.
As a result, my new linkages for the top and a new top are on order and the dealer will replace everything for me.
My dealer has been really good to me and continues to be but I have to say that it certainly helps to be informed about issues and service bulletins etc from this Forum.
I LOVE this Forum - well, ahem - intensely LIKE anyway.
Thank you for all the good information, folks!
Is there a place for these other than a couple of TSB lists that are closed ?
Top tsbs
diff
instrument lights
backfiring
etc.?
spider is offline
Old 06-21-2008, 10:07 PM
Small Dealer's Avatar
That information was first talked about in March of 2007 in threads about the top not stowing properly (windface) and a wind noise thread (eyeno) and a drive link socket replacement.
Windface's post is #8 in : Convertible top not folding down evenly
eyeno's post is #7 in : Convertible Top Problems...Normal?
The second thread includes the first edition of the bulletin.
Small Dealer is offline
Old 06-21-2008, 10:44 PM
Here is the latest version of the bulletin:
#06-08-67-017B: Convertible Will Not Stow/Difficult to Raise/Windnoise/Waterleak (Re-Install or Replace Drive Link) - (Apr 30, 2007)
Models: 2006-2007 Pontiac Solstice
2007 Saturn Sky
Condition
Some customers may comment that the convertible top won't stow or it is difficult to raise all the way. They may also comment that there is a windnoise/waterleak that has developed at the rear of the passenger or drivers window.
Cause #1
This condition may be caused by a drive link socket being out of adjustment and possibly coming off the convertible top link. Note that the threads inside of the ball-socket may be damaged from the disengagement from the link.
Cause #2
The threads on the drive link may be out of specification, causing the ball-socket to disengage from the link. Ensure that the diameter of the link where the threads meet falls between 5.794 mm (0.228 in) and 5.974 mm (0.235 in) when measured with a vernier caliper.
Correction #1
Replace the ball-socket with an all-metal ball-socket and adjust the folding top link ball-socket to 4-6 mm (0.157-0.236 in) from the base/shoulder of the threads, or with no more than four threads showing on the folding top link. Install the washer on the ball stud. Tighten the ball stud nut to 12 N·m(106 lb in).
Correction #2
1) Open the folding top to gain access to the folding top link.
2) Remove the nut and ball stud from the rear seal retainer support panel.
3) Remove the folding top socket from the folding top link.
4) Adjust the folding top link ball-socket to 4-6 mm (0.157-0.236 in) from the base/shoulder of the threads, or with no more than four threads showing on the folding top link.
5) Install the ball-socket to the folding top link. Tighten to 25 N·m (18 lb ft).
6) Install the washer to the ball-socket and install the ball-socket to the rearmost position in the slot on the support panel.
7) Install the nut on the ball stud. Tighten the nut to 12 N·m (106 lb in).
Old 06-21-2008, 10:59 PM
Miner's Avatar
Originally Posted by spider View Post
Thanks to Miner.
Top tsbs
diff
instrument lights
backfiring
etc.?
I still don't know what a TSB is but I am thinking T_____ Service Bulietin?
Actually, I found the bulletin number quoted on my work order so if the serviceman had not put it there, I would not have know the number.
But now we all know it!
Hope it does help some folks.
Miner - Sly, black leather, fully loaded except smokers and OnStar
(ordered Feb.27/06 - VIN1G2MB35B17Y118341 - Received Dec. 29/06)
My Modification Page
Miner is offline
Old 06-21-2008, 11:12 PM
spider's Avatar
Its stands for "technical service bulletin" Miner. So small dealer from what you show the TSB doesn't refer to miners problem. Is there a specific TSB for ripping/pinching?
spider is offline
Old 06-21-2008, 11:18 PM
Miner's Avatar
Thanks for the acronym translation.......I was close.
As to my top problem, hey - if I can get a new top and get some one acknowledging that the problem exists.........well that is a good start and who am I to tell them they may be wrong?
We will see what happens - I think it is going to be a process of elimation that will take a bit of time.
Miner is offline
Old 06-22-2008, 07:05 PM
Nothing has changed since the threads referenced and others were started, no service bulletins for a "ripping or pinching".
