Old 03-05-2008, 08:53 AM
   Adapters Cables For Monsoon Amp
jeff_b_wilson's Avatar
I just upgraded all seven of my speakers and to get the most benefit from them I want to replace the Monsoon amp with another 5 or 6 channel amp. I intend to keep the stock head unit. Originally I was going to tie in a JL e430, allowing it to drive the door and sub and let the Monsoon drive the rest, but the wiring is a mess and I eventually gave up and have just the Monsoon driving everything. I decided that the best solution would be to completely replace the Monsoon amp with a 5 or 6 channel amp. It sure would be nice if I could find an adapter plug for the amp inputs and outputs so I wouldn't have figure out my own wiring. Do y'all know of any that may be available?
Thanks &
Regards,
Bodean
(North TX, 2007 "Cool" GXP Automatic with Monsoon System, Escort 9500ic, Custom Wind Restrictor, K&N air filter, Hahn BSR Tune & Hahn IC, Dual Horns, Kappasphere luggage rack (when needed), Flash2Pass, MagnaFlow muffler, JLe430 amp with Pioneer Components & Blaupunkt rear, Crossfire amp with Sony Xplode Sub, DDR ProBeam, ADR Propulsion Wheels, Solo Hi-Flow CAT, Halo Demon Eyes), Hide-Away plates, Cherry dashboard
jeff_b_wilson is offline
Old 03-06-2008, 12:17 PM
Thanks &
Since there has been no response I am guessing that the answer is "No".
Regards,
Bodean
Old 06-15-2008, 07:16 PM
   JL Audio makes some
TbeaunTx's Avatar
JL Audio: Products
With these you could use a barrel connector to adapt to standard rca interconnects...or use female to male interconnects.
Better late than never I hope!
2007 MysteriousGXPAutomatic-Loaded
MB Quart Comp 6.5's lit red w LEDs, e-Dead, Lil Chromies, 15% Tint, Red lit GXP Windrestrictor, Black'd air bag light/visors, LED lights, stubby antenna, nixed-chix, license plate light hole covered, 3"Magnaflow Cat-back, Dejon BOV spring, Cry02 IC water sprayer, Militec-1, K&N drop-in, MBRP charge tubes & turbo shield, PS Resv insulated, GMR Tune, Fully Zaino'd.
TbeaunTx is offline
