2KWK4U; Man...nice work! Your either real brave, real crazy, or just have way too much time on your hands. If I tried something like this... Well let's just say the results would not be pretty. Anytime I fool with something that isn't broke, I break it. How long did your exploratory surgery take and did the patient survive? Any scars?
Thanks! I'm all three (brave, crazy, 4-day weekend). This is pretty much standard practice for me. I take apart every new car I own within weeks of taking over the keys. I probably spent about 3 hours in total pulling things apart and poking around.
__________________ '06 #101409 - Sold to move to Germany
Thanks 2KW! Did you take any measurements of the base unit or "apparent" empty spaces while you were in there?
Aw crap! I KNEW I forgot to do something. Here's a couple more pictures of the head unit. The cavity it goes into is pretty much an exact fit (a little play, of course), but open at the top for ventilation. There's not even any more allowance on the left side for the internal amp's heat sink!
As for dimensions, I'd look at what crutchfield gives for other newer GM cars with the same head unit. I'd bet a paycheck they all use the same style recess in the dashboard.
In one of the above pics, you can see a white post on the back of of the head unit case. That post engages a hole in the back of the bay, and I think the head unit might bottom out in there.
In your dashboard adventures, did it look possible to move the airbag indicator to below the stereo?
I'm going to say "maybe." Anything is possible, but I don't know how easy it would be. In "dash3.jpg" (above) you can see that you would probably have to cut a web out of the dash carcass to put it there. Also you'll have to extend the wire harness, and fabricate a way to get the flat panel to fit the curved part of the IP trim (see IPtrim3.jpg).
I considered it briefly, because I thought the hole left behind from the airbag light unit would be a nice fit for a radar detector remote display. I might just eliminate the airbag light panel all together, though. Alot of GM cars put it in the rearview mirror. If I can find a self-dimming rearview mirror with map lights, compass, temp display, and passenger airbag light in a salvage yard, then I'll grab it and free up the space for my V1 remote display.
I love checking out your pictures. Great information. How do you get all those plastic panels off without breaking plastic or clips? When you put it back together, no squeeks or rattles? Next, could you attack the trunk? I'd love to see for sure what is under the Mayan Temple.
Very carefully! I have a panel-popper tool that I bought from the snap-on man ages ago when I worked as a stereo/alarm installer. I put a cotton wrag over the business end of that, and put it between the panel gaps, then hunt for the locations of the clips. When I find one, I say a little prayer and squeeze away
No squeeks or rattles upon reassembly! Needless to say I'm happy for that. Believe it or not, the trunk/Mayan Temple IS next up. I might get around to that one today.
Nice work.....now that you're in there, what's your take on how stuffs Engineered/Assembled. [i.e.] did you find things were put together in a logical well thought out way...no unneccessary parts....all the fasteners torqued down correctly...quality bits and pieces....etc etc............
YES, overall I was impressed with the quality of materials, design, and assembly. Especially for a first-year car, and ESPECIALLY for a GM. I did have my concerns when I took apart the rear bulkhead, because some of the clips there seemed to be "MacGuyvered". I found nothing of that sort up front.
As for the aftermarket head unit replacment and keeping the chimes.. there is a unit out there by Metra and I believe at least one other company to keep the chimes. Cost is around $60... Metra part number GMRC-01. Crutchfield and I think CircuitCity can get them (among your favorite online aftermarket stereo company).
I had one in a previous car. All the box does in plug inbetween the head unit and the factory wiring to "hear" the Data Bus signal. The box (which contains a speaker) then makes the correct sound for the signal. Problem is the box is buried inside your dash and can be harder to hear, or much louder and is no longer volume controlable. I know my Olds Alero I could control the volume of the "dings" with the stereo... I'm guessing you can still do the same.
Data Bus connections are standard on the radios... remember, it's a worldwide radio system now, so don't get too nervous if something doesn't like Solstice on the packaging just yet.
Thanks, rlhammon. Is the other company Pacific Audio Control (PAC) by chance? I've had good luck with their adapters in the past.
So can anyone tell us if there is a possibility of connecting an external CD changer?
Not for that reason, but because, and it's been mentioned before, that to truly do iPod integration (with working steering wheel controls and track info on the radio display) requires a CD changer port.
#17313 | Scarlett! | AC | ABS | LSD | Pwr | Conv | Single MP3 | Monsoon! | All but lost...
It's been so long since I've really done installs, and so much has changed that I don't know what to look for anymore. I'm going to give a weak "probably not" as your answer. Sorry I can't do better than that. Keep in mind that this is the base stereo, too. The upscale units may have more inputs/outputs. However, I still doubt there will be any offered with CD changer control capabilities.
