I have an 07 GXP, and mine does not work. i.e. It shows song, artist, etc, and i can control volume, but i can not select songs, or use forward, reverse to change the selection from the radio or steering wheel controls. I also can't do it on the iPhone, i have to use the shake to shuffle feature to change the tune because it locks into "accessory connected" mode upon plugging it in. I was told this only applies to the 07 model, that the 08 09 and most other GM versions of this radio have consistent programming, but the LAN code on the 07 is different. If you have an 07 and have different results, let me know because i may have had smoke blown up somewhere private. Either way, i bought my unit without warranty, so I don't have a return option.
PS, my iPhone is the 3G model...this may be different with the 1st Gen, or earlier code than OS3.x as well?
[b]2007 MysteriousGXPAutomatic
