Old 12-10-2008, 07:32 AM   #1 (permalink)
JL Audio Clean Sweep
Does anyone have the JL Audio Clean Sweep in their Car? I have ordered it and just wanted to know if any other memebers installed it their cars. JL Audio: Products
mazda3jdm is offline   Reply With Quote
Old 12-16-2008, 07:36 PM   #2 (permalink)
jeff_b_wilson's Avatar
Haven't heard of any. Alpine makes a similar product, the PXE-H650, that I was considering but after talking to their tech support they convinced me that it wouldn't be particularly beneficial for a convertible. Acoustics could only be set for either top up or top down, not both.
Regards,
Bodean
(North TX, 2007 "Cool" GXP Automatic with Escort 9500ic, Custom Wind Restrictor, K&N air filter, Hahn BSR Tune & Hahn IC, Dual Horns, Kappasphere luggage rack (when needed), Flash2Pass, MagnaFlow muffler, Alpine PDX-5 amp with Pioneer Components & Blaupunkt rear and Sony Xplode Sub, DDM ProBeam & Backbone Brace, Werks front frame brace ADR Propulsion Wheels, Solo Hi-Flow CAT, Halo Demon Eyes), Hide-Away plates, Cherry dashboard, GM Roadster Hi/Lo HID's and Fog lights
jeff_b_wilson is offline   Reply With Quote
Old 12-17-2008, 07:31 AM   #3 (permalink)
Im only using it for a sub woofer so i dont think it matters
Old 12-17-2008, 07:36 PM   #4 (permalink)
It matters WAYYY more than you know. I've installed dozens of CleanSweeps. GM uses this great frequency attenuation system to keep speakers from blowing. If you install a standard LOC, you will notice lots of bass and treble at low volumes, that seems to "fade" as you turn the volume up. The CleanSweep will correct this even on just the subsonic frequencies. If you have the Monsoon system, install it after the amp. If it's just the standard system, put it where the factory amp would go and just tap into the rear speakers for signal if you're lazy lol. JL Audio also makes the RBC knob for the CleanSweep to control a sub independently of the other channels.
And stay away from the Alpine unit, it's way too big an bulky and does half the stuff the CleanSweep does.
If you know someone that sells JL Audio, you can get that CleanSweep from them for less than $200 easily.
Motivated Motorsports - "I get my knuckles bloody so you don't have to."
08 Sky Redline
04 Ion Redline
04 Cavalier LS
dont_blink is offline   Reply With Quote
