Hey all, I finally got tired of waiting for the wiring harness to come out. So today I decided was the big day.
I followed AztekzRpurty's instructions
HOW TO: Aftermarket Headunit Replacement which was a great help. The disassembly went flawlessly. Thanks Aztek
The wiring was not the same on the connectors as Azteks, which is the wiring for the non-Monsoon setup. I figured I would add what I came up with to help others out with their Monsoons.
I went with the same install kit: Metra 99-3302
Metras version for the antenna adapter: 40-cr10 chrysler
Alpine CDA-9856 ( Has ipod control and can do either XM or Sirius )
Sirius Sir-Alp1 Sat. tuner
I ended up with the following wiring diagram based on Aztek's and a Saturn Vues wiring ( the Vue uses different colors ):
Connector 1:
pin 1: Red/White 12v constant
pin 2: Gray Dimmer control
pin 3: open
pin 4: Green Right Front Speaker -
pin 5: Green/White Right Front Speaker +
pin 6: Dark Green Left Front speaker -
pin 7: Tan Left Front Speaker +
pin 8: Black/White Ground
pin 9: Green/White GM Lan
pin 10: open
Pin 11: Blue Steering Wheel
pin 12: open
pin 13: open
pin 14: open
Connector 2:
pin 1: open
pin 2: open
pin 3: Pink Amplifier control
pin 4: Tan Right Rear Speaker +
pin 5: Blue Right Rear Speaker -
pin 6: Brown Left Rear Speaker +
pin 7: Brown/White Left Rear Speaker -
pin 8: open
pin 9: open
pin 10: open
pin 11: open
pin 12: open
pin 13: open
pin 14: White/Black ? Steering Wheel Ref.
pin 15: Green Amp Mute
pin 16: open
I didn't connect to the steering controls, amp mute, or Lan connections.
I didn't have to cut anything off of the top of the install kit, but I did have to remove the guide pin and make the cuts on the side mounting bracket area as Aztek did.
I used the plastic mounting brackets in the kit instead of the din mounting cage that came with the radio. This allowed the radio to be recessed so that the radio will set flush with the dash. Because of the depth of the radio I had to remove some of the plastic in the back of the mounting area with the dremel.
Radio
Ipod connected with Alpine High Speed Cable:
I put the Sir-Alp behind the glove box on the plastic tray and ran the ipod control cable into the glove box.
As I gets some pics ready, I will add them to this post.
Hope this helps the fellow Monsooners out there.
