I bought a GM LAN interface from Best Buy (smart enough to leave it in the package), pulled the radio and saw the stock harnesses clearly don't fit in the interface. I could have trusted the pictures I've seen here, but I guess I wanted to see for myself. So I called Scosche and they
still don't have an interface yet. They also said they don't think Metra or AI have one yet either. Since our DIC is in a different place, the Malibu Scosche kit doesn't work either.
Oh, and for those that haven't taken their dash apart yet, but plan on it to change out the head unit, be warned the clips make a horrible sound when pulled out. It will sound like you just broke the dash. It made me panic, until I notice it was just the sound of the clips.
I also got a PM stating there's not a good speed wire anywhere in the car.
(1)Does anyone have access to the gauge cluster wiring to see where the speedo wire is? (I need that for the navigation unit.)
One more thing:
(2)where is the grommet in the front firewall (where I would run a 1 gauge power wire from the battery to the cabin)?
(3)Since the battery and fuses are on the passenger side, is there a hole on the same side I can drop the power wire through, or will I have to run it across the engine bay to the driver's side?
(4)Also is there a standard battery terminal post adapter I can use to connect said power wire?
I think that's all for now. Obviously I'm gearing up for a pretty intense install (DVD, nav, Sirius, Music Keg, speakers (maybe custom fit 6" or 6x8s in rear), sub (w/ custom enclosure), two or three amps, 1F capacitor...and none of it in the trunk if at all possible). Yes, me =
