Old 03-05-2009, 06:28 AM   #1 (permalink)
XM tuner location?
Did a search and couldn't find the exact info. Where is the XM tuner in a Sol? I understand it's in the trunk, but where in the trunk?
Thanks!
Craig
cw_racefan is offline   Reply With Quote
Old 03-05-2009, 09:03 AM   #2 (permalink)
Small Dealer's Avatar
In the right rear.
INFORMATION POSTED ON SITE
Old 03-05-2009, 10:56 AM   #3 (permalink)
crappa's Avatar
With your top up, your trunk lid up, standing next to the passenger rear wheel, look down inside trunk. You will see an elastic strap from the top that is bolted to the car. Remove the cone shaped bolt cover, the nut, then the strap. Now you can pull the trunk liner away from the body. Just rearward of the stud you just freed is a shinny box. That's it, part #4 as shown above.
My Mods Post (as of Apr 4, 2009)
Latest Mods since: Backbone brace, Black painted calipers w/white Solstice stickers, Black Pontiac wheel emblem stickers, A-pillar gauges, DDM Probeam.
What do I want to be when I grow up? In denial.
crappa is offline   Reply With Quote
Old 03-05-2009, 11:01 AM   #4 (permalink)
Great! Thanks for the info! Since I can't activate the XM as a secondary receiver on my Sirius account, I want to use the XM antenna for my Sirius PnP. Now all I have to do is figure out how to get the adapter cable inside the cabin! Should be able to figure that out once I get into it.
Thanks again!
