Originally Posted by wcf59
thanks Maddog. I found it. How do the membrane switches mount without drilling holes? I like the idea of them being on the side of the console where they can be seen and easily reached.
It is double sided tape. It seems like pretty good stuff. Just make sure that you clean the mounting spot really well. I went through a bit og sitting and looking before I picked that spot. For example, I ride with my elbow on the center "arm rest" (in quotes because there is nothing restful about the stock arem rest) and the fingers of my right hand in the shifter well (usually playing with the leather waiting to shift). If you look at the picture, you will see that the switch is right where my thumb would be. Easy peezy. So, it's comfortable and no hunting for the button. And it's inobtrusive.
But as with every other mod, it is a matter of personal taste and what you want. That's why we do these little mods, right? To get it just how we want, not someone else.
Oh, forgot to mention the other reason I chose that spot, the ribbon cable that comes out of the bottom of the switch tucks under the trim very nicely right there.
