Power Wire Routing
The main grommet through the firewall from the engine compartment is huge. It is stuffed really tight with a big bundle of wires, but the flat areas around it provide about 3/4 to 1 inch of unused space all the way around the wire bundle. There is no problem with punching a hole through this area...except the rubber is pretty strong and you'll need something like an awl to get through it. There are two layers to the grommet, if you punch through from the interior you'll break through the first layer and think you're done, but you have to keep going to get through the outer layer on the engine-bay side. You might also be able to stretch the existing opening and use some silcone wire lube to get a cable that big through it, but I wasn't patient or strong enough to figure out how. As others have said, punching a hole will still be water proof because the rubber will stretch to fit the cable you are pulling through it, and it has two layers as well. If you are still concerned you could use some sealant or tape, but I saw no need to and have had no issues with air or water leaks.
[b]2007 MysteriousGXPAutomatic
