Old 12-06-2006, 09:14 PM   #1 (permalink)
Chemist's Avatar
Chemist Mod: hard-wired garage door remote!
Well, it's done and it works! The guts of my garage door remote now resides in my windshield surround, wired into the mirror circuit, activated by a small Radio Shack switch!
Here are the tools and supplies I used:
Soldering iron, solder, wire, remote for door, wire stripper, screwdriver, and momentary switch from Radio Shack ($2.49).
I first disassembled the remote, removing the clip, then the screw holding the case together.
Here is the back of the circuit board with the locations (on mine) where the wires are soldered. The two to the switch are where the original switch on the board is soldered. Check these with a multimeter and see that the voltage goes from 12 V to essentially 0 when the switch is depressed. The two locations at the bottom are simply the battery terminals. Be sure to note which is "+" and which is "-".
This next picture shows the board taped inside the winshield surround trim piece. To the lower right of the circuit board is the Radio Shack switch which is placed through a hole made in the trim (Dremel rocks!). The switch is soldered to the (now) underside of the circuit board, and leads are soldered to the two battery terminals.
Here is a picture of the wires to the mirror, a small portion of the fabric tape that covers them split and pulled back, and two Posi-Taps installed on the blue w/white stripe (12 volt power) and black (ground) wires. (A BIG thanks to AztekzRPurty for putting me onto posi-taps! ). The red (power) and black (ground) leads from the circuit board are then fastened to these taps.
Finally, here is a pic of the finished install. The button is small and inobtrusive (note my tweety switch by the other visor!). The remote is powered from the car and so I never need worry about replacing the battery (or losing the remote, for that matter. )
IMPORTANT NOTE: THIS MOD WORKED AS SHOWN BECAUSE MY REMOTE IS 12V. Yours may 9V (or 3V or 1.5V), and you will need additional circuitry beyond my simple install.
I hope you have enjoyed our time together. There will be a quiz next week. NOT!
--Chemist
NASSOA Founding Member
Old 12-06-2006, 09:22 PM   #2 (permalink)
Sol Driving Member
GO_DRVN's Avatar
Great "How To" post Chemist. Nice detail and pictures...with that kind of detail you should be a professor.
Will you be in Canton for the 2010 Summer Solstice?
12 . . . Solstice Coupe List - October
Wicked 2009 Solstice GXP Coupe on order 24 October 2008 Produced 7 April 2009 Delivered 6 May 2009 VIN 1G2MT25X59Y000038 (Watched her come off the truck)
Original 2006 NA Ordered: 8 Sep 2005 Delivered to dealer 15 Dec 2005 (Watched her come off the truck) Traded 6 May 2009 #5357
GO_DRVN is offline   Reply With Quote
Old 12-06-2006, 09:29 PM   #3 (permalink)
Solcycle's Avatar
I'm interested in the Solstice outline decals you have covering the yellow warning signs on the visors. Could you post a better photo and where did you get them?
Looks cool and I'd like to do the same.
Solcycle is offline   Reply With Quote
Old 12-06-2006, 09:31 PM   #4 (permalink)
Sol Cruisin's Avatar
OK, call me a "mod moron", but my garage door opener uses a 9-volt battery, won't 12 volts cause trouble?
Ernie Guzman Pontiac in Houston are liars and profiteers!!
Power Train Mods Are Done!!! Dejon CAI, Dejon IC Pipes, EDAL, Magnaflow 3" cat-back
Misc. Mods: WindRestrictor 2, stubby, de-badged, engine cover painted, garage door opener, headlights smoked, egg yolks gone, Garmin Nuvi 660, custom trailer hitch, upolstering
To Do: Calipers painted, Back mud flaps, ECM tune? Boost Controller?
Sol Cruisin is offline   Reply With Quote
Old 12-06-2006, 09:39 PM   #5 (permalink)
Chemist's Avatar
Yes, 12V would be bad to a 9V remote. You will need some sort of resistor in line to the power source to lower the voltage. Had I needed to do that, I would have been stumped (until I could grill my Physics faculty on the "how to").
I will find out what I can and let you know.
--Chemist
Old 12-06-2006, 09:44 PM   #6 (permalink)
birdliver's Avatar
Well Done, Chemist! Your evolution into the "Ultimate Modder" is progressing nicely. I wouldn't be at all surprised to see your name placed in nomination for rookie of the year in the coveted "Tweetmeister" awards competition which are held in such reverence by those of us who continue to be dremel-challenged!
birdliver is offline   Reply With Quote
Old 12-06-2006, 09:44 PM   #7 (permalink)
Chemist's Avatar
I PM-ed you the vendor (not a supprting vendor here).
Here is a better (and much bigger ) photo.
--Chemist
Old 12-06-2006, 10:08 PM   #8 (permalink)
numbbers's Avatar
Well, I have two garage doors, and sometimes when I am leaving, I need to close both of them from the car. So, I guess I will have to use two switches. Although, I really wanted to use the blank switch location on the dash where the stabilatrac switch is located on the GXP. For now, I just have the opener velcroed to the floor mat right in front of the drivers seat. I just reach down and the button is right there.
Thanks, Dave Russell
Mallett #33
VIN #1G2MB35B27Y106697
Deep
Ebony Leather
Chrome
numbbers is offline   Reply With Quote
Old 12-06-2006, 10:47 PM   #9 (permalink)
Gizmo's Avatar
It is my honor to second that nomination!
Interesting to note the number of tweetmeisters located in the Republic of Texas!
Her name is MariSOL
In Spanish that means The Sea and The Sun.
VIN 6Y101319, delivered 10/15/05. 83,519 miles.
Old 12-06-2006, 11:03 PM   #10 (permalink)
Chemist's Avatar
I blush!
This was a simple mod because my remote is 12V. Please do note that it would require some sort of voltage reducer if the remote is 9V (or 3V or 1.5V). I will find and post a diagram of a more detailed circuit.
--Chemist
Old 12-06-2006, 11:06 PM   #11 (permalink)
ripple's Avatar
Send a message via AIM to ripple
Nice mod and how to indeed....Bravo..
I will be following your pedels how to this friday, need to keep myself busy until the header and cat arrive.
MAKO Sly Sand Steel, Power and Convenience Package A/C, LSD, ABS, 5 spd, polished Monsoon single CD
Mods: Little Chromies, Kappa Matts, Kappashield, GM CAI, KS Alum Pedals, B-series stubby antenna, Clear bra headlights & Fogs.
Shorty header and hi-flow converter (clearimage) Magnaflow Cat-back
Delivered 4.19.06
A new and improved thread from hell!
Ripple's personal thread from hell!!!
ripple is offline   Reply With Quote
Old 12-06-2006, 11:30 PM   #12 (permalink)
Gizmo's Avatar
I was happy to see that my remote (Genie) is virtually identical to yours, Chemist. That makes my job a lot easier, now that you have blazed the trail!
I was amazed to see the battery, so tiny yet 12 volts.
I'll be interested in hearing how well it works for the next couple of weeks. I know as little about electricity as about cars, so perhaps my worry is unjustified. But although the remote uses 12 volts, the same as the car, could there be a problem with excess amps reaching the remote? I suppose the fuse for the amperage going to the mirror reduces that problem, but is it reduced enough?
Her name is MariSOL
Old 12-07-2006, 06:01 AM   #13 (permalink)
Ex-Miata Man's Avatar
Chemist,
GREAT MOD!!! The Tweety era continues
AKA xmm
DEEP with Steel/Sand leather,
87,300+ miles on the odo and still goin' strong- Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"We saw the leaves !!!"
Ex-Miata Man is offline   Reply With Quote
Old 12-07-2006, 07:03 AM   #14 (permalink)
Your opener may be a Chamberlain like mine was. I could come over this weekend and show you where mine is and we can get it done.
I put mine in the triangle forward of the door handle. This way it can be pulled off if the battery goes dead without needing tools. It's also out of the way and out of sight unless you know it's there.
tweety is offline   Reply With Quote
Old 12-07-2006, 07:04 AM   #15 (permalink)
Originally Posted by Ex-Miata Man View Post
Chemist,
Not all these ideas were mine. Old ideas, new car.
